Like Tree137Likes
Old 12-31-2005, 07:46 AM   #976
speedemall's Avatar
Trader Rating: 54 (100%+)
Default ball diff
Whats the strongest thing i can use to completely lock my mini ball diff? thanks!
speedemall is offline   Reply With Quote
Old 12-31-2005, 10:19 AM   #977
Customworksking's Avatar
Trader Rating: 73 (100%+)
Unhappy ball
u can't lock it sorry I tried.........trust me I know I won a tcs race with my mini
Team Xray | RC America| Hudy |Jaco |AKA
Customworksking is offline   Reply With Quote
Old 12-31-2005, 11:38 AM   #978
asw7576's Avatar
I used TA03 ball diff and I removed it after I found out the pinion wear out quickly.
If you insist to lock the front diff, use gear diff and epoxy the gear. That's better and cheaper than TA03 ball diff.
Old 12-31-2005, 04:24 PM   #979
NOZ69's Avatar
IMO... Your better of using the Ball Diff, I didn`t like the way my mini drove with a locked gear diff. Excessive wear on tyres, broken Uni`s & ect.
In my gear diff i just used "Shoe Goo"...worked great, & whats even better was when i wanted to change back to the gear diff it just peeled away from the bevels SO i didn`t have too replace them either
Cheers
FT TC4, LRP TC Sphere, LRP X-11 13.5
SC10 4x4
M03M Suzuki Swift
Power by Feral
Sanwa MX-3 FHSS
NOZ69 is offline   Reply With Quote
Old 12-31-2005, 04:43 PM   #980
i don't understand where to put the "Shoo goo" in the diff ? .... do I just open up the case and put a crap load of of it in there ? or is there a specific place to put it ? --- basically , i need some assistance in all area's relating to , putting shoo goo in the gear diff .
Sorry , and thank you ,
Associated T4 Kyosho Optima Mid
Tamiya MO3 Mini Cooper
Tamiya Falcon
Mr.Pink is offline   Reply With Quote
Old 12-31-2005, 04:57 PM   #981
NOZ69's Avatar
OK... When you take your GEAR DIFF apart, you have the aluminium gears that go inside the big plastic gear..
You lay the plastic gear on your bench & put in the aluminium gears but leave the last round one out for the time being. Fill with Shoe Goo (I used a tooth pick to get the glue in all the "nooks & crannys") then put the last round aluminium gear in & the plastic cover piece & let dry.
The best part as i said about using Shoe Goo is that when you want to change back the gears just gear away from the glue.
Cheers
SC10 4x4
M03M Suzuki Swift
Power by Feral
Sanwa MX-3 FHSS
Old 12-31-2005, 08:25 PM   #982
FW-05RR's Avatar
I need help with painting the roof of my Rover Mini Cooper shell. It came with masking tape for the windows but none for the roof Anyways I want to paint the roof white but I'm really confused as to how to go about it. Is there a templete out there already made that I can download.. I really don't want to screw my paint job up someone that has painted their roof on their mini's white can you give me any hints as to how to do it..
thx
FW-05RR is offline   Reply With Quote
Old 12-31-2005, 09:51 PM   #983
Slotmachine's Avatar
Send a message via MSN to Slotmachine
thx
MASKING TAPE!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!
HOBBYWING NORTH AMERICA /FALCON SEKIDO/ TEKNO RC TEAM/VBC Racing America/VP-PRO RACING TIRES/2010 R.O.A.R. VTA National Champion Driving a T2R PRO/NANO-TECH Batteries Paul Rush
Slotmachine is offline   Reply With Quote
Old 12-31-2005, 10:08 PM   #984
rayman's Avatar
Cheers
Doesn't locking your diff make the car have less steering? I just use a ball diff.
rayman is offline   Reply With Quote
Old 12-31-2005, 11:18 PM   #985
FW-05RR's Avatar
thanks for the tips
Old 12-31-2005, 11:57 PM   #986
Birky's Avatar
thx
1. Mask the windows and roof off on the inside of the body.
2. Paint the body the colour you want.
3. Remove ONLY the masking tape on the roof. This will leave the roof clear.
4. Paint the roof white from the inside.
5. Remove the window masks once you have finished painting.
Or you could just follow Proline Painting Method: http://www.prolineracing.com/howtotips/painting-A.html
Smash 'EM! F1 Racing: WA's Home of Fun in Formula 1 RC Motorsport.
Birky is offline   Reply With Quote
Old 01-01-2006, 07:36 AM   #987
rccollect's Avatar
Talking Using ACTO-TUNED M-SP motor?
Just caught the Mini bug and bought a XB M-03 rolling chassis off a guy. Just curious as to anyone having tried this motor as it seems to have less weight due to its shorter length, wonder if there's any advantage in this design or its just plain old marketing at work?
rccollect is offline   Reply With Quote
Old 01-01-2006, 05:55 PM   #988
speedemall's Avatar
ACTO MOTOR SPECS:
Timing Adjustments:
Usable timing is from 4th gradation from the center and greater. Note the different directions of the timing for the M-01 and M-02 chassis.
SUITABLE PINION GEAR: 18T
**NOTE: Use 16T pinion for 60D size tires.**
Old 01-01-2006, 08:59 PM   #989
would a P2K motor fry my ESC ? on my M03
xXcoolrollinXx is offline   Reply With Quote
Old 01-02-2006, 06:45 AM   #990
rccollect's Avatar
ACTO MOTOR SPECS:
Timing Adjustments:
Thanks for the specs but I wanted to ask if anyone tried it and found it better than the olde silver can?
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 04:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-01-2011 11:08 PM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 08:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 06:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 07:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
