Like Tree44Likes
Old 08-14-2009, 05:42 AM   #9826
Ray k's Avatar
Trader Rating: 46 (98%+)
Originally Posted by Geppetto View Post
Please recommend a servo for my new Mini (M05). I don't want to spend a lot of money, but I want a reliable servo. Metal gears, bearings are probably good for Minis, I assume???
All you need is a Futaba 3004, $20.00
Ray k is offline   Reply With Quote
Old 08-14-2009, 07:16 AM   #9827
Trader Rating: 35 (100%+)
Thanks guys. I haven't begun to build the kit, and I wasn't even sure if the Mini required a "standard" sized servo or smaller.
Geppetto is offline   Reply With Quote
Old 08-14-2009, 12:19 PM   #9828
#88driver's Avatar
On asphalt, how are you guys curing traction rolls? Sorry if it has been asked before.
Colton Jaynes
*RC America*Hudy*Xray*Jaco*KO Propo*SMC*EA Motorsports*
rchobbiesstore.com
#88driver is offline   Reply With Quote
Old 08-14-2009, 03:32 PM   #9829
Dan
Dan's Avatar
Trader Rating: 45 (100%+)
Running an S3004 servo too, although I think its dying because its buzzing like mad. Don't need a lot of "servo" for the Tamiya mini. I had a faster servo in it once but had to turn down steering expo since the mini was too twitchy on the slightest movement of the wheel.
Dan is offline   Reply With Quote
Old 08-15-2009, 05:26 AM   #9830
edwintklee's Avatar
Trader Rating: 23 (96%+)
Originally Posted by cannon View Post
Hitec = rubbish
A very por quality servo
Just stick to Futaba or KO
sanwa no good also??
i dunno much about F3004, but i have tried F3003 on my minis, its worked fine until 1 day i found that its unable to return to the center position, but it will return if you on and off, but when running and you hit something(lightly) its just wont maintain straight any more. after the incident., i have tried with my 3 others F3003 all same, the problem its fix when i change to a ko propo digital servo.
I am a Red Star, Blue Star, Fans......
edwintklee is offline   Reply With Quote
Old 08-15-2009, 08:11 AM   #9831
monkeyracing's Avatar
Speaking of servos, has anyone else had a problem mounting their servo in the M-05? I've tried 3 different servos, and in all cases the wires coming out of them interfere with the posts that hold the servo in place.
Am I doing something wrong?
Jim
Stab it and steer.
monkeyracing is offline   Reply With Quote
Old 08-15-2009, 08:38 AM   #9832
tamiyarcracer's Avatar
Send a message via Yahoo to tamiyarcracer
Jim
I just put the wires between the 2 servo posts and put the screws in. It was tight but it worked.
tamiyarcracer is offline   Reply With Quote
Old 08-15-2009, 11:09 AM   #9833
Starteur's Avatar
OK Guys here's another one for you!
I bought a black chrome frame, it has been used a bit outside, so it's scratched on the bottom it is missing paint, is there a way I can fix that?
Thanks again
Starteur
Ride it like you stole it!!!!!!
Tamiya TRF417V5 SEDAN Racer - Tamiya 416X VTA Racer - Tamiya TRF 416X USGT Racer -Tamiya M05 V2 PRO Racer.
Starteur is offline   Reply With Quote
Old 08-15-2009, 04:17 PM   #9834
Default m chassis alloy dampers
Hi all
I am just in the process of setting up my m chassis tamiya alloy dampers what is the best to use a three hole or 2 hole plastic piston end?
thanks
green mini is offline   Reply With Quote
Old 08-15-2009, 07:53 PM   #9835
Mr_Gleeman's Avatar
Trader Rating: 16 (100%+)
Originally Posted by green mini View Post
Hi all
thanks
Hi green mini, for me and I think a lot of the guys on this forum use the three hole piston end. The reason is I can control what oil weight to use and can make the damper more fluid or less depending on the track.
My suggested starting point would be three hole piston ends all round with 50 weight oil front & 40 weight oil rear.
John
Mr_Gleeman is offline   Reply With Quote
Old 08-15-2009, 10:41 PM   #9836
scribbler's Avatar
I've always used the hitec metal gear high torque servo's, but they're bulky and heavy in a mini.
I was thinking of switching to a Futaba S9551 Low profile digital. Any opinions? Any problems?
scribbler is offline   Reply With Quote
Old 08-15-2009, 11:19 PM   #9837
cannon's Avatar
I have the 9551 servos in every car I own ... quick, reliable .. enough said
www.feralbatteries.com ........... new website
cannon is offline   Reply With Quote
Old 08-16-2009, 01:29 AM   #9838
Mr_Gleeman's Avatar
I second that!
John
Old 08-16-2009, 03:01 PM   #9839
dannyboy15's Avatar
Send a message via MSN to dannyboy15
Default cornering
i have got an mo3 mini a couple of weeks ago and i race it every friday my only downfall it corning, it pritty much keeps going in a straight line it is compleatly standered apart from a sport tuned motor which is now the fastest mini in a straight line at the club.
p.s it also is running 10th scale touring car wheels.
thanks in advance
dan
dannyboy15 is offline   Reply With Quote
Old 08-16-2009, 09:06 PM   #9840
Jam-ehz's Avatar
Send a message via ICQ to Jam-ehz
Just performed a M05 conversion on my spare stock M03.. very easy to do, maybe $40 of parts and you have a whole new car..
The only 2 tricky parts that you can't take from your M03 are the step screws that hold the steering rack together, and the threaded steering rod. I ended up chopping the heads off of two long 3mm screws and CA gluing them into a Carbon Fiber rod with a 3mm hole. It's solid and very light.
It's incredibly responsive, I'm finding, even just on my street! I have a ball diff in mine, and it's crazy how much rear traction I have now that the servo's back there.
I wonder if people will "fine tune" their rear weight by swapping out different weight servos..
I'm now waiting for a CF/aluminum steering rack that actually uses bearings in the links, and a sway bar kit, since the old one won't work.
-=≡ Tamiya TA05 TRF415MSX F103R M-03R M-04 M-05 ≡=-
-=≡ CRC Carpet Knife 3.2 OFNA LD3 Pro Fastcats Spektrum ׀ווlı ≡=-
Jam-ehz is offline   Reply With Quote
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 04:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-01-2011 11:08 PM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 08:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 06:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 07:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
Currently Active Users Viewing This Thread: 3 (1 members and 2 guests)
miha
