Like Tree19Likes
Old 08-09-2009, 10:17 PM   #9781
Dan
Dan's Avatar
Trader Rating: 43 (100%+)
Originally Posted by $$$... View Post
Ok, just got myself a set of Tamiya M-chassis aluminum shocks. Are there any tips to building them or just as per the instructions? they will be going on an M-03 for mainly asphalt. Any tips appreciated.
The instructions are pretty straightforward. Just remember to use the clear O-rings instead of the black ones for the bottom shock cap. The instructions weren't clear on that section, but other than that, they go together pretty easily. Don't forget to check out the marked springs so you have the right ones for the front/rear.
Dan is offline   Reply With Quote
Old 08-09-2009, 10:56 PM   #9782
Mr_Gleeman's Avatar
Trader Rating: 16 (100%+)
Originally Posted by cannon View Post
I thought the same as you but I found it is just as quick if not quicker than the M03.
You follow these steps:
1. Take the front bumper off
2. Disconnect the servo rod
3. Separate the steering linkage by taking out one screw
4. Remove one of the screws from the underside of the rear chassis part . This screw is the one that screws the rear section to the front.
5. Take out the 4 screws in the front right half of the chassis
You can now slide the right hand section of the front chassis section off.
It took about 5 minutes to do
No doubt I have left something out but it is very easy to do
True, true not that much different to an MO3 granted. But WHY in Gods name so many different size screws, what a pain in the proverbial backside
Mr_Gleeman is offline   Reply With Quote
Old 08-09-2009, 11:14 PM   #9783
monkeyracing's Avatar
I think they may have over engineered this one. It's not so bad to take apart though. There's just a few more steps involved.
Jim
Stab it and steer.
monkeyracing is offline   Reply With Quote
Old 08-10-2009, 08:25 AM   #9784
Mini Racer 95's Avatar
does the m05 un screw like the m03
Austin
Mini Racer 95 is offline   Reply With Quote
Old 08-10-2009, 08:41 AM   #9785
Core Creations's Avatar
Trader Rating: 92 (100%+)
Send a message via AIM to Core Creations
I lightly sanded all the contact points where the 3 main chassis pieces connect and then greased it also (per the manual) and I can take the drivers side of the chassis off and access the gears in 2 maybe 3 minutes. It's actually easier for me than the M03 and it goes back together easier.
Core Creations paint thread
Mini Mafia Kansas Chapter - where the monster minis grow!
Core Creations is offline   Reply With Quote
Old 08-10-2009, 09:33 AM   #9786
There are a few extra screws to deal with. I can show you next race day if you'd like.
Jim
Stab it and steer.
Old 08-10-2009, 04:45 PM   #9787
caltek1's Avatar
Trader Rating: 33 (100%+)
Default MO5 Chassis Parts
I ensured that all burrs were removed and then sprayed the rear chassis part with Nulon Ezi-Glide Clear Silicone lubricant. This lets the parts slide out easily. I also use this on my mini gears.
Works for me.
Regards,
Calvin.
caltek1 is offline   Reply With Quote
Old 08-10-2009, 05:10 PM   #9788
x2. Silicone spray is great for gears, plastic stuff that needs to move around and now for the chassis joints as well.
Jim
Stab it and steer.
Old 08-10-2009, 08:47 PM   #9789
yah sure that would be great thanks jim
Austin
Old 08-10-2009, 09:27 PM   #9790
Thank you all for the input on getting to the tranny. I've been putting it off for 2 days. Next time I'll actually try to do a task before commenting. But you guys saved a lot of thinking. I'm sure all the newbie owners appreciate it, as I do.
Granpa is offline   Reply With Quote
Old 08-11-2009, 01:14 AM   #9791
iti20090's Avatar
Default Useful M Chassis tires
After leaving some Harris RC Team Powers tires lying around for many months as I was too slack to adjust the shock height of the rear of the car, I tried these on the back of the M03 and these locked the rear end down amazingly well, even on the cold morning asphalt track we race. Having cured a long standing rear end traction issue for me, I am keen for another set for the new M05.
Harris RC no longer list the Team Powers Mini tire and Google could not help - would the "Sorex" be a re badge of the same tire or would it be better to give the Spice or RP a go instead?
Kind regards
Dave
Originally Posted by caltek1 View Post
iti20090,
RP 55mm
No one else makes 60mm diameter tyres for mini other Tamiya. Although I think the new HPI tyre for the Cup Racer might be close. You would have to visit the HPI website.
Other 55mm diameter tyres for mini: Pit Shimizu: Ride: RP: Spice: Kamikase: Sweep: Solaris: HPI: ABC Genetic: Cross:
We use these in combinations for mini racing here in Australia.
Regards,
Calvin.
iti20090 is offline   Reply With Quote
Old 08-11-2009, 01:20 AM   #9792
cannon's Avatar
Trader Rating: 35 (100%+)
Kind regards
Dave
Dave,
Of late we have successfully been using the Cross 36 Square tyre on the rear. It certainly locks the rear in place. Just a one lap warmup and they are away. The Croiss 36 is softer than its rating as we found out when trying to use it on the front
www.feralbatteries.com ........... new website
cannon is offline   Reply With Quote
Old 08-11-2009, 01:27 AM   #9793
caltek1's Avatar
Dave,
I run the same Cross rear tyre as Greg and this works a treat. Another option is to get a pair fo Spice 36/32 and fit a 5mm med insert. This should work similar to the Powers.
Regards,
Calvin.
Old 08-11-2009, 11:29 AM   #9794
Originally Posted by axle182 View Post
Jim thats the combination i run on both my m04 and m03's, its perfect for carpet. If your stuck using tamiya tires only, put Type A's with hard inserts in the back and its very close, but the Type A's wear out very very fast. Thats why i LOVE these 3 racing tires. And I agree, they look disturbingly cheap (and they are cheap! lol) and they have a very hard feel to them, but i have no idea how they grip so well.
And they're run flats, this is what I noticed when I got home!
tamiyatorg.blogspot.com/2009/08/hey-theres-giant-hole-in-my-tire.html
not allowed to link or post images because I'm too much of a n00b
torg is offline   Reply With Quote
Old 08-11-2009, 01:13 PM   #9795
Low_E's Avatar
Send a message via MSN to Low_E
there you go:
thou shall think twice or trice before hitting thee SEND-button
Low_E is offline   Reply With Quote
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 04:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-01-2011 11:08 PM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 08:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 06:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 07:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
