Like Tree200Likes
Old 08-05-2009, 07:45 PM   #9736
niznai's Avatar
Originally Posted by monkeyracing View Post
Almost true...3Racing makes 60D tires for minis. I don't know how they are on asphalt, but they're sticky as anything on carpet, and they're cheap.
They look like a complete joke, but are actually a decent tire.
Jim
Are these the tires you're talking about:
http://www.rcmart.com/catalog/rc-min...?cPath=35_1386
Cheers
Team Greasy Weasel
The best upgrade to any car is some driver skill.
niznai is offline   Reply With Quote
Old 08-06-2009, 12:17 AM   #9737
monkeyracing's Avatar
Yup, those are the ones. I ran some tonight on the M-05. Our track is indoor, on fairly sticky carpet. I used the 3Racing tires on the back and the Tamiya S-Grip Radials on the front. It proved to be a really good combination. Nicely balanced.
The only thing about the 3Racing tires is that they look like the kind of thing you'd see on a cheap rc toy from Walmart. Don't let appearances fool you, they're quite good.
Jim
Stab it and steer.
monkeyracing is offline   Reply With Quote
Old 08-06-2009, 09:40 AM   #9738
axle182's Avatar
Trader Rating: 18 (100%+)
Send a message via MSN to axle182
Jim thats the combination i run on both my m04 and m03's, its perfect for carpet. If your stuck using tamiya tires only, put Type A's with hard inserts in the back and its very close, but the Type A's wear out very very fast. Thats why i LOVE these 3 racing tires. And I agree, they look disturbingly cheap (and they are cheap! lol) and they have a very hard feel to them, but i have no idea how they grip so well.
Aaron "AJ" Freind
axle182 is offline   Reply With Quote
Old 08-06-2009, 10:11 AM   #9739
Dan
Dan's Avatar
Trader Rating: 47 (100%+)
Originally Posted by MiniU4IA View Post
So a front wheel drive M03 Mini Cooper capable of drifting if set up properly?
Perhaps with a Dbox?
Errmmm....no...
Dan is offline   Reply With Quote
Old 08-06-2009, 02:22 PM   #9740
Mini Racer 95's Avatar
so the 3-racing tires dont ware as mutch as m or s grip tires
Austin
Mini Racer 95 is offline   Reply With Quote
Old 08-06-2009, 02:28 PM   #9741
Default Diffs
what is the main difference between the ball diff and the gear diff
and is there anymore types of diffs
Austin
Old 08-06-2009, 05:36 PM   #9742
CSaddict's Avatar
While we are talking diffs. I just assembled my Manta Ray ball diff. How tight do I tighten the diff when its assembled? I have it pretty tight right now and its still smooth and doesn't really give much resistance.
CSaddict is offline   Reply With Quote
Old 08-06-2009, 06:41 PM   #9743
Heya Austin, you got PM.
Jim
Stab it and steer.
Old 08-06-2009, 07:56 PM   #9744
Chiefy 707's Avatar
Gear diffs use gears for its differential action where ball diff's use balls. Open gear diffs aren't exactly adjustable. Sealed gear diffs are adjusted via diff oil. Ball diffs are adjusted via adjusting nut.
Other 'diffs' you can use are the one-way and the spool. The one way freewheels off power and locks up on power. The spool is always locked so the inner and outer axles always spin at the same speed.
Speaking of ball diffs. Is there a difference between the Manta ray diff and the TA03 diff? Does either one offer any sort of advantage over the other?
"It looks like a [insert car here]. It's just another [insert car here] clone!"
"Why did [insert manufacturer here] go with such a radical design? [insert manufacturer here] needs to stick with what works!" Shhhh, please.
HB/LRP/KO Propo/Protek/Associated/Tekno
Chiefy 707 is offline   Reply With Quote
Old 08-06-2009, 09:53 PM   #9745
tamiyarcracer's Avatar
Send a message via Yahoo to tamiyarcracer
the only real differences is:
Manta Ray has heavier metal parts, and it has a wider gear.
I prefer the TA03, it is lighter, and since the gear is narrower it gives les resistance. But that is probably more in my mind than I feel it.
tamiyarcracer is offline   Reply With Quote
Old 08-06-2009, 09:53 PM   #9746
niznai's Avatar
Oh, so you are running a rear wheel drive mini on carpet? You might be the person to talk to then. I have been trying to setup my M02 for carpet and it just doesn't work, I have to be really really easy on the throttle out of corners or it will spin out instantly. Any ideas?
I have tried all the tires and all combinations of inserts. SOme of them work but they all fall short of a really sticky tire out of corners. Some tires I tried are HPI cross pattern radials, Tamiya slicks (A-type 60D), radials Tamiya M, Tamiya S, Tamiya (normal), Tamiya XB kit tires (smaller diameter). INserts used are RS4 mini pro (kit) for HPI, hard foam and Sorex type A (touring insert cut to size) for Tamiya radials. On tarmac, I don't have problems, the car is very good. But on carpet, it's very fiddly with corner exits. I am using a lipo in the car compensated with lead to bring it up to 1350gr, lead is distributed evenly around the car, perhaps with a little bit of rear bias. Silvercan motor. Swaybars at both ends, Tamiya aluminium shocks, kit spring on the rear, on road tuning white spring on the front, two spacers (the largest) at either end, 40wt AE oil front, 30wt rear. Ball diff, largest motor pinion.
Am I asking the impossible? Is the RWD mini just like that and I have to live with it, or can I get it to behave?
Team Greasy Weasel
Old 08-06-2009, 09:57 PM   #9747
thanks to everyone for your help
Austin
Old 08-06-2009, 09:58 PM   #9748
is there other types of ball and gear diffs than the stock tamiya ones
Austin
Old 08-06-2009, 10:05 PM   #9749
caltek1's Avatar
Trader Rating: 36 (100%+)
Regarding ball diffs I have found that they might start off smooth and tight when first assembled, with or without extra cone washers, 1150 bearing etc. However after a few runs they becomenotchy, not sure why this is but it has happened to most of mine, even when using lots of anti-wear grease. Perhaps the balls get flat spots when they tensioned down. This is using only the balls provided in the ball diffs.
I am trialling a tight gear diff for now. This appears to remain smooth after many runs.
Regards,
Calvin.
caltek1 is offline   Reply With Quote
Old 08-06-2009, 10:09 PM   #9750
caltek1's Avatar
Mini Racer 95,
3Racing do a ball diff, you would be advised to stay away from it. Tech racing do a spool that fits inside the Tamiya gear diff. A Tamiya gear diff or ball diff can be made into a spool. Just need some superglue in a gear diff or pin/glue/screw a ball diff. The updated 3Racing ball diffs for the MO5 have not been released so no comment on there new products. Old one was a dog..
Later,
Calvin.
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 05:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-02-2011 12:08 AM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 09:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 07:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 08:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
AWS
