Like Tree198Likes
Old 08-04-2009, 01:05 PM   #9721
tony gray's Avatar
And....not a spool to be seen in the A main at Mini 50... Ball diffs everywhere!
tony gray is offline   Reply With Quote
Old 08-04-2009, 01:51 PM   #9722
cannon's Avatar
Trader Rating: 35 (100%+)
That was nothing to do with whether it was a spool or not ... just the quality of the driver. A spool posted one of the fastest individual lap times. Just the mong couldn't drive
But you also said that a M03L was no good .. but I seem to remember that it was TQ
Selective memory Tony
www.feralbatteries.com ........... new website
cannon is offline   Reply With Quote
Old 08-05-2009, 01:58 AM   #9723
iti20090's Avatar
Default RP30mini: RP Racing Mini Racing Tires (1 pair) 30 compound
Please would some kind soul confirm the outer diameter on these RP Mini tires?
Also, is there no other tire manufacturer producing a useful 60D tire in competition to the Tamiya 60D?
Kind regards
Dave
iti20090 is offline   Reply With Quote
Old 08-05-2009, 02:15 AM   #9724
Tim K's Avatar
A spool is fast, but a oneway in a mini is faster again
Tim K is offline   Reply With Quote
Old 08-05-2009, 04:06 AM   #9725
tony gray's Avatar
And a SWB won - your memory is just as selective Greg...
I'm more astounded to see Tim posting something!
Old 08-05-2009, 04:27 AM   #9726
cannon's Avatar
But it only just won. As we have said before it is interesting that the Vics like the SWB but in NSW it is the M03L or the M03M that is fast.
Looking forward to the Nats. Hopefully the SWB guys will come up for the event on the big track.
I have seen a one way used once. Yes very quick ... and very quick to hit the barriers without braking
Old 08-05-2009, 04:30 AM   #9727
caltek1's Avatar
Trader Rating: 36 (100%+)
iti20090,
RP 55mm
No one else makes 60mm diameter tyres for mini other Tamiya. Although I think the new HPI tyre for the Cup Racer might be close. You would have to visit the HPI website.
Other 55mm diameter tyres for mini: Pit Shimizu: Ride: RP: Spice: Kamikase: Sweep: Solaris: HPI: ABC Genetic: Cross:
We use these in combinations for mini racing here in Australia.
Regards,
Calvin.
caltek1 is offline   Reply With Quote
Old 08-05-2009, 04:35 AM   #9728
aussierevo's Avatar
Trader Rating: 14 (100%+)
I'm considering making the move into Mini, and was wondering if this would be a good brushless system to run.
http://www.rcmart.com/catalog/rc-bru...r-p-28425.html
would it provide the same or close enough performance to the hobbywing, or too much.
Speed Passion F1.
Hobbywing ESC and Motor, SMC Batteries
Meakin Park Club Member
Team ARGO RC - Like us on Facebook
aussierevo is offline   Reply With Quote
Old 08-05-2009, 04:42 AM   #9729
cannon's Avatar
If you are racing Mini in Australia you must use the Hobbywing
Old 08-05-2009, 04:47 AM   #9730
aussierevo's Avatar
ok, thanks for that.......looked like a good setup, ah well
Speed Passion F1.
Old 08-05-2009, 06:39 AM   #9731
monkeyracing's Avatar
Calvin.
Almost true...3Racing makes 60D tires for minis. I don't know how they are on asphalt, but they're sticky as anything on carpet, and they're cheap.
They look like a complete joke, but are actually a decent tire.
Jim
Stab it and steer.
monkeyracing is offline   Reply With Quote
Old 08-05-2009, 07:33 AM   #9732
axle182's Avatar
Trader Rating: 18 (100%+)
Send a message via MSN to axle182
The reason for tightening a diff on a mini is to reduce the dredded 'diffing out' on corner exit where the inside tire gets all the power and just spins, so your corner exit is slower. A spool would change the handling huge i would think. I get my mini to handle well, and adjust the ball diff rather tight so it wont 'diff out' on corner exit. I run the M03r alot tighter than the M04 as the 04 doesnt roll over on exit and diff out as much. Always think of what you trying to achieve when working on your diffs, and consider what the drawbacks are. A spool id guess would be hard to get a nice corner entry especially on carpet, and im sure it would be very hard on the drivetrain.
Also consider that on really low grip situations with a tight track, sometimes a loose diff will work better also, allowing you to hold a tighter line. Just wanted to throw in these suggestions, its not like any single one is the ticket
Aaron "AJ" Freind
axle182 is offline   Reply With Quote
Old 08-05-2009, 08:13 AM   #9733
mangoman's Avatar
Ummm the hobbywing is cheaper to buy here anyway.... (I'm assuming you are in australia)
hit up cannon from feral batteries :P
http://www.feralbatteries.com.au/category.aspx?id=%2052
You want the system second from the top.
Hot Bodies Cyclone!!!
www.smaracing.org
www.rchobbies.com.au - www.feralbatteries.com.au
craig mcphee ( WHERE'S MY BEER )
mangoman is offline   Reply With Quote
Old 08-05-2009, 02:00 PM   #9734
aussierevo's Avatar
thanks for that mangoman.....I will look into that.
Speed Passion F1.
Old 08-05-2009, 06:33 PM   #9735
Default Can my Mini drift?
So a front wheel drive M03 Mini Cooper capable of drifting if set up properly?
Perhaps with a Dbox?
MiniU4IA is offline   Reply With Quote
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 04:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-01-2011 11:08 PM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 08:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 06:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 07:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
