Like Tree200Likes
Old 07-28-2009, 08:34 PM   #9646
tony gray's Avatar
Our current viewpoint on the matter (for what its worth)
The M05 is NEWER and it is DIFFERENT - that doesn't necessarily mean that it's BETTER.
We've held off from doing a full comparison and review yet because at the moment we cant get an M05 within a second of our best M03 times.
That's not to say that it isn't possible, just that we havent been able to do it yet.
So we'll be holding off on a full review/comparo until we have more time with the car.
Bear in mind however, that down here in Aus we run the Hobbywing systems in our cars, and because we're going quite a bit faster than the silver cans used elsewhere, we're probably encountering issues that others may not necessarily have seen yet.
tony gray is offline   Reply With Quote
Old 07-28-2009, 10:41 PM   #9647
sim600's Avatar
Trader Rating: 15 (100%+)
Send a message via ICQ to sim600
Tony, what is your experience so far with the M05 steering setup. I heard the steering arms still need the tall ball studs (despite having the control arm raised), to stay level with the high-mounted steer rack. Are there any issues with durability or performance in this area?
sim600 is offline   Reply With Quote
Old 07-28-2009, 11:09 PM   #9648
tony gray's Avatar
Can't say that we see that as an issue at all.
We not keen on the whole steering set-up full stop (although it's better than we thought it'd be) but that part of it isn't a problem that we've seen.
Old 07-29-2009, 04:21 AM   #9649
sim600's Avatar
Thanks Tony,
However bad it is, I think I'll end up getting one in the end. You know how it is.
Old 07-29-2009, 04:58 AM   #9650
caltek1's Avatar
Trader Rating: 36 (100%+)
sim600,
With the standard MO5 kit using the plastic front knuckles you only use a short 5mm ball stud.
It is only when you fit the Alloy MO5 front knuckles that you have to use the tall 5mm ball stud. This is because the MO5 alloy knuckle is the same as the MO3R knuckle.
The plastic MO5 knuckle is of a completely new design and has the arm located towards the top of the knuckle.
Regards,
Calvin.
caltek1 is offline   Reply With Quote
Old 07-29-2009, 07:35 AM   #9651
sim600's Avatar
Ah okay. Got it. That clears everything up. Thanks.
Old 07-29-2009, 10:22 AM   #9652
CSaddict's Avatar
My lhs only has the m03L available right now. He says its like 1mm longer and the new body style mini. Aside from the body is there any reason not to buy this one? Do all the hoop up parts still work?
All the spec class guys around run the 03L from hs telling me and he feels it has better cornering manners being a bit longer.
So yes? Pick up the L?
CSaddict is offline   Reply With Quote
Old 07-29-2009, 11:53 AM   #9653
tamiyarcracer's Avatar
Send a message via Yahoo to tamiyarcracer
The M03L is only different by body and a chassis extension, you can convert a l into a short with the purchase of a body, and you can convert it to an M with a body, and possible a parts tree dependind on which kit you are looking at.
Typicaly the M03L seems lazier in the corners due to the longer wheel base, and tends to be a bit of a more forgiving car. It isn't as responsive as the short wheel base chassis.
if it is the Mini Coopers Kit, it should come with bearings, and should have the parts to allow the chassis to be a "S" "M" or "L"
tamiyarcracer is offline   Reply With Quote
Old 07-29-2009, 11:56 AM   #9654
CSaddict's Avatar
Well this will be my first on road car so being forgiving is a plus. Ill pick one up tomorrow. Thanks for the advice.
Old 07-29-2009, 12:15 PM   #9655
Make sure it is the 2006 Mini Cooper S kit 58400
Old 07-29-2009, 02:24 PM   #9656
CSaddict's Avatar
Will do. Thanks for the help.
Old 07-29-2009, 02:25 PM   #9657
tony gray's Avatar
You need to read this MINI FOR DUMMIES on our site. Should help
Old 07-29-2009, 04:23 PM   #9658
Originally Posted by caltek1 View Post
DEACON,
MO5 PRO does not come with aluminum front knuckles, these are a Tamiya Hop up purchased seperately. These do offer you three holes for steering linkage adjustment. The rear alloy hubs also have two holes which allow you to run differnt rear camber points. These are also another Tamiya Hop up part. if you decide to go this option then these use 1050 wheel bearings.
The plastic parts in the MO5 kit use 1150 bearings. I have not used the plastic parts on my MO5. I fitted the alloy from day one, so I can not make comparisons. Part numbers for the alloy bits are in this thread a few pages back.
Regards,
Calvin.
Thanks Calvin. I didn't realize that only the rear hubs are alloy. Seems a bit weird to include alloy hubs on only one end of the car???
My preference would be to race and be competitive without the alloy parts. There's still a few weeks before the MO5 is available here. I'll decide between now and then whether to buy the Pro or the standard kit.
DEACON is offline   Reply With Quote
Old 07-29-2009, 04:39 PM   #9659
CSaddict's Avatar
Actually I have been reading the site for 2 days. Love the Mentos trick. Is that real or do you get a kick out of seeing people try it? Its a great site with awesome info.
Old 07-29-2009, 07:00 PM   #9660
AUSSIE BOB's Avatar
Default true
Gday mate, Mentos is real allright, just think, would a Aussie take the Piss out of a Yank, dont think so !!!!!
Bob
AUSSIE BOB is offline   Reply With Quote
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 05:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-02-2011 12:08 AM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 09:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 07:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 08:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
