Like Tree136Likes
Old 07-26-2009, 02:02 AM   #9616
caltek1's Avatar
Trader Rating: 35 (100%+)
Chiefy 707,
Looks good. I know from our testing here in Aust, that the 17.5 in mini is slower than using the Hobbywing 13T BL systems we use. However I suppose that is what is legal for you to run. The 17.5's are about the same speed as a really good silver can but with better consistancy.
Good luck, looking forward to seeing your painted bodyshell.
Regards,
Calvin.
caltek1 is offline   Reply With Quote
Old 07-26-2009, 08:13 AM   #9617
Default Questions
What diameter/radius wheels are on the minis as standard, am i right in thinking its 26mm radius? What is the largest size i could get away with mounting on one? Im looking at getting one and kitting it out as a rally and something I would be interested in looking into would be larger wheels. The release date for the M-05 in the UK is late july at apexmodels.com
6677 is offline   Reply With Quote
Old 07-26-2009, 08:20 AM   #9618
Core Creations's Avatar
Trader Rating: 94 (100%+)
Send a message via AIM to Core Creations
Width on the Swift wheels (most popular) are 24mm wide and 37mm diameter. I am not sure what you can get away with without rubbing. I believe someone makes rally block tires for mini wheels.
Core Creations paint thread
Mini Mafia Kansas Chapter - where the monster minis grow!
Core Creations is offline   Reply With Quote
Old 07-26-2009, 08:58 AM   #9619
What would i need to buy out the box to run an M05? eg. batteries, chargers, esc...
Old 07-26-2009, 09:28 AM   #9620
niznai's Avatar
Plus radio, servo, speedo (if going brushless motor too).
Team Greasy Weasel
The best upgrade to any car is some driver skill.
niznai is offline   Reply With Quote
Old 07-26-2009, 10:07 AM   #9621
monkeyracing's Avatar
I've noticed a few things about the M-05 so far. First, a lot of the tuning logic that one learns on the M-03 doesn't apply. Try M-03 tricks, and your car will be a pig.
I tried the David Jun trick with the ball diff. I don't know if I did it wrong, but it sounded like a garbage disposal when I cranked it down. Still, I put it back in the car because it promised to be a little more grabby.
Jim
Stab it and steer.
monkeyracing is offline   Reply With Quote
Old 07-26-2009, 10:42 AM   #9622
The car is rarely to see the track with the exception of perhaps cocky mates that reckon toy level cars can beat it. most of my tuning will be in regard to ride height etc to get it going on dirt. Anyone got any ideas for dust protection?
Old 07-26-2009, 01:21 PM   #9623
caltek1's Avatar
Tamiya mini tyres are 60mm diameter.
Spice,ABC, Ride,Kamikase,Express,Kawada,Pit Shimizu etc are 55mm diameter.
I think Ride do a rally block mini tyre, check RCMart.
Regards,
Calvin.
Old 07-26-2009, 03:57 PM   #9624
Default M03l Value
Just a few opinions on what I can expect to pay for a M03l with a cheaper radio, ball bearings and a few other small options? Just an ballpark figure....75, 100, 125???
cbs440 is offline   Reply With Quote
Old 07-26-2009, 07:55 PM   #9625
Timbulb's Avatar
Default Used M-03
I recently purchased a used M-03. I removed all the brass and plastic bearings the previous owner had in the wheels. I'm gonna assume the tranny bearings are all gonna be brass or plastic as well. What is the process of getting into the tranny? Will I pretty much have to disassemble the vehicle totally? Is there any reference material you guys can direct me to on this? Thanks in advance.
Timbulb is offline   Reply With Quote
Old 07-26-2009, 08:05 PM   #9626
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
pretty much...gotta take the front end off and then remove the screws so it splits into 2 parts..
the manual can be found either at Tamiyausa.com or here - http://s195302033.onlinehome.us/CX/Man/TamVeh27.pdf
simple car once you take it apart and put it back together...I actually rebuilt mine from the ground up in less then 2 hours
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 07-26-2009, 09:40 PM   #9627
www.towerhobbies.com has a M-03L BMW Mini Cooper combo for $174.20-no additional goodies. Bearings, paint, etc are generally extra
bowl806 is offline   Reply With Quote
Old 07-27-2009, 05:02 AM   #9628
academygaz's Avatar
Just dropping this here, I have the August 08 issue of RC Magazine (JDM mag 'yo!), and theres a tiny photo in the ''New Stuff'' section:
Its a carbon fibre M03 chassis conversion from Option No.1 that puts the motor up front and possibly has the cells going down the spine of the chassis (I'd lay them across it though... ).
Can anyone read Japanese?
Quote, Leodis, 2007: ''I've been shopping online for 9 years and the only charge I've ever had to dispute with my credit card company was from TiR. Congratulations TiR. Even porn sites are more ethical than your company!''
RC cars - I haz sum.
academygaz is offline   Reply With Quote
Old 07-27-2009, 12:09 PM   #9629
tamiyarcracer's Avatar
Send a message via Yahoo to tamiyarcracer
Jim
Did you use a brand new 1150 bearing of great quality, I would not suggest a ceramic bearing either.
tamiyarcracer is offline   Reply With Quote
Old 07-27-2009, 01:09 PM   #9630
tony gray's Avatar
M03 chassis conversion Gaz?
There are ANY M03 parts on that at all?
tony gray is offline   Reply With Quote
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 04:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-01-2011 11:08 PM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 08:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 06:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 07:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
barts71m
