Like Tree104Likes
Old 07-21-2009, 11:32 AM   #9571
might as well post mine too
redbones is offline   Reply With Quote
Old 07-21-2009, 11:40 AM   #9572
Default Super Newbie question. Mini cooper
Hi all.
Okay so I am a super newbie with all this.
Will any Mini cooper tamiya body fit on a 'team Losi xxx-s' chassis?
MiniU4IA is offline   Reply With Quote
Old 07-21-2009, 11:47 AM   #9573
Originally Posted by MiniU4IA View Post
Hi all.
Tamiya used to make a 1/8 scale mini cooper kit that used the TG-10 1/10 scale chassis. If you can find that body then it should drop right on a XXX-S.
LigouriRd. is offline   Reply With Quote
Old 07-21-2009, 11:51 AM   #9574
Did they stop making it awhile back?
Probably impossible to find a new one now then?
Another question.
Whats the difference between a M-03 and the M-03 XB pro ready to run?
Old 07-21-2009, 12:20 PM   #9575
Another question.
XB is built up , with electronics , ready to run ( RTR)
gimpex is offline   Reply With Quote
Old 07-21-2009, 01:44 PM   #9576
Skitee's Avatar
I notice that you have also left off the stiffeners/roll bars at the rear of the chassis. Is there any particular reason for leaving it off? Is this only for certain track conditions or better for all conditions?
Xray T4 2017 ~ ORCA Vritra VX3 ~ Motiv RC 4.5
Xray T4 2017 ~ ORCA Vritra VX3 ~ R1 Wurks 13.5
Xray X12 2016 ~ ORCA Vritra VX3 ~ Orca TX 4.5
POWERED BY SPEEDZONE USA
Skitee is offline   Reply With Quote
Old 07-21-2009, 03:21 PM   #9577
caltek1's Avatar
Trader Rating: 35 (100%+)
Skitee,
It seems to be the fashion with a few of the Japanese drivers. I don't think it will let the chassis flex any differently, as the joint between the front and rear is very tight. It would be something you would have to try.
For Australian mini racing it would be illegal as not built per instructions and would mean you would have to add lead weights to get back to 1330gms. Nearly all who run mini use Lipo's so weight is already required to get up to legal weight. Perhaps when Tamiya release more Hop ups the requirement for additional lead weight might be reduced.
Seems like 3Racing are set to release a plethra of MO5 parts in during August. Check out there web site http://www.3racing.hk/products_list....=104&x=34&y=11
My thoughts,
Calvin.
caltek1 is offline   Reply With Quote
Old 07-21-2009, 03:27 PM   #9578
Originally Posted by tony gray View Post
Its out now...the 'Junior Burger' of the M05 world. The M05 Mini Cooper kit.
Want to know what it DOESN'T have?
rc-mini knows - Click HERE
Still not available in the US!
Geppetto is offline   Reply With Quote
Old 07-21-2009, 03:48 PM   #9579
caltek1's Avatar
Geppetto,
The kit was released last week in Japan. RC Champ had them.
Regards,
Calvin.
Old 07-21-2009, 04:29 PM   #9580
Ok, so I got the Mini bug since I purchased my '09 mini cooper.
'nother newbie question.
What's the difference between the Tamiya Mini kits out there: M-05, M-03 etc..
Old 07-21-2009, 06:26 PM   #9581
Originally Posted by caltek1 View Post
Skitee,
My thoughts,
Calvin.
The rear brace, though it looks cool, it doesn't do anything other than to add weight so I took them off. The chassis is plenty stiff without them. If I run my 3600nimh, the car at its current state weighs in at 1340g. Yes, even with the alum screws and taking all the unnecessary pieces off. The place where I race is pretty cool with mods as long as you follow the obvious ones(motor, batt, weight limit, etc). When we tried to limit what we can do, people started to drop out so it was lifted. We've got some very unique minis and pretty exciting to see what kind of ideas people come up with every race.
Seems like 3racing is going to beat tamiya to the hop up race. I already see the motor mount and the ball diff. I hope the diff is a "standard" one and not the over engineered version from the M03. I also see a front shock tower which will allow you to get back the original geometry from the M03. Though I prefer to have made from graphite instead.
Old 07-21-2009, 06:45 PM   #9582
caltek1's Avatar
redbones,
Next to no one runs NiMH batteries here in Australia. Lipo's are so easy to use and have great voltage for racing. As these are lighter additional weight is required.
Fortunately for your racing modifications are allowed and using the NiMH's will bring you back up to weight easily.
3Racing gear looks good, however previous experience with rear hubs, the parts are soft and do not take abuse very well. I hope the diffs are nothing like the one they made for the MO3. That was apalling.
Good to hear that you have some unique mini's in your club. So how did your experiment with moving the bottom of the front shock pan out?
Regards,
Calvin.
Old 07-21-2009, 07:40 PM   #9583
scribbler's Avatar
I've had ots of difficulties with the Manta ray ball diff. Is the other one more reliable?
scribbler is offline   Reply With Quote
Old 07-21-2009, 08:00 PM   #9584
scribbler's Avatar
3Racing has once again come out with an excellence selection of show, but no go parts. You have to buy two of everything just to make it through one day of racing. Very dissappointing. Its almost worth spending the larger amount for guinuine Tamiya hop up parts. You might spend more for their stuff but you only pay once.
Just my two cents. Feel free to disagree.
Old 07-21-2009, 08:02 PM   #9585
tamiyarcracer's Avatar
Send a message via Yahoo to tamiyarcracer
The TA03 ball diff is what I have always run. Only problem I have ever had with it is eventually you can strip out where the dogbones go into it. But out of all the diffs I have run I think maybe 1 or 2 have done that.
ifyou are going to be running it in a M05, I think tamiya will have a new one shortly, so, if it was me, I would wait.
tamiyarcracer is offline   Reply With Quote
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 04:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-01-2011 11:08 PM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 08:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 06:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 07:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
Currently Active Users Viewing This Thread: 3 (1 members and 2 guests)
MatsNorway
