Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 07-17-2009, 07:54 AM   #9541
DRAG_ON's Avatar
What parts needed to upgrade M03 into M05? i already have most of the hop up in my M03M.
1) will ta03 ball diff fit straight without modifications in m05?
2) Can i use the M03 universal on M05?
3) can Hollow carbon shaft being used on M05?
4) M03 stabilizer set reusable in M05?
5) Quick release battery hop up can be used for M05?
What parts do i need to get to be able to convert M03 into M05? thanks in advance
Freq:29.945, car no:29, W.A.R.C.M.C.C, http://projectm-design.blogspot.com/
DRAG_ON is offline   Reply With Quote
Old 07-17-2009, 08:02 AM   #9542
Best to get the M05 kit and just move the hop ups over. This way it would probably be cheaper and you get all the new parts. Think about it...
Ben.C is offline   Reply With Quote
Old 07-17-2009, 08:07 AM   #9543
Skitee's Avatar
1)YES
2)YES
3)YES
4)NO
5)YES
51389 - M-05 A Parts (Chassis)
51390 - M-05 B Parts (Steering wiper)
51391 - M-05 C Parts (Suspension arms) but M-03 will fit
51392 - M-05 D Parts (Damper stay)
51393 - M-05 F Parts (Uprights)
2500016 - M-05 Threaded Shaft(Steering)
Tamiya TA05 Ver.II R with Tamiya TBLE-01 & Tamiya TBLM-01 12T
Tamiya TA05MS with Tekin RS Pro & Team Orion 13.5
Tamiya TRF416 with LRP Sphere TC & Trinity Duo 4.5
Tamiya M03R with SJ FSSOP & Tamiya Sport Tuned
Skitee is offline   Reply With Quote
Old 07-17-2009, 08:24 AM   #9544
tamiyarcracer's Avatar
Send a message via Yahoo to tamiyarcracer
Hey Drag on,
1) Yes, the TA03 ball diff works without modification in the M05
2) Yes, the M03 Universal works in the M05
3) Yes, the Hollow Carbon shafts work in the M05
4) no, the M03 stabilizer set doesn't appear to work on the M05
50 Yes, the Quick release hop up will fit.
1 qty 50579 (3x10 step screw)
1 qty 50797 (Short Adjuster)
1 qty 51389 (A parts Chassis)
1 qty 51390 (B parts Steering)
1 qty 51391 (C parts Suspension arms)
1 qty 51392 (D parts Damper stay)
1 qty 51393 (F parts Uprights) (Bearing supports required from this tree)
4 qty 850 bearing for steering
There is something on every tree that is needed for the M05, that can not be had from the M03.
The screw set is very different, but if you have many screws laying around you might have what you need. and in many cases they call for a longer screw, but the 3x10 could be used.
A couple of ball connector nuts are used on the rear suspension
The only other things I saw that was drastically different was the steering tie rods, and the steering link (servo to belcrank) the tie rods use a 3 x 12 threaded shaft like a droop screw on the sedans, and the steering link is a 3 x 89 threaded rod, that you can probably make from something found at a hobby store.
I would suggest going through the manual for yourself. here is the link to the M05 PRO manual.
http://www.tamiya.com/japan/download...8443m05pro.pdf
If you have the M03R then your aluminum uprights (F=R) will drop right onto a M05
Hope this helps most everyone.
tamiyarcracer is offline   Reply With Quote
Old 07-17-2009, 09:04 AM   #9545
DRAG_ON's Avatar
Originally Posted by tamiyarcracer View Post
Hey Drag on,
thanks for everyone FAST reply, really appreciate it thanks
Old 07-18-2009, 06:33 AM   #9546
Kail's Avatar
Ok guys, get excited. M05 is indeed faster than M03 if set properly. I made a 0.7s gain today on both best and average lap. Gone was my under steer.
My M05 today can turn in sharper and more aggressively while maintaining a planted tail.
Kail is offline   Reply With Quote
Old 07-18-2009, 09:17 AM   #9547
Does anyone recommend these cars for bashing? The surface I want to run on is quite rough so really i need a high ground clearance car but this is the only car that I would be willing to make an exception for and take to a smoother surface. If these are any good for bashing what would you guys recommend, M-03,4 or 5. And earlier question, how good on rough surfaces involving gravel? If its bad theres alot of other places I can take it.
Oh yeah. I already know a place locally where I can pick up an M-03 although they aren't a proper hobby shop.
6677 is offline   Reply With Quote
Old 07-18-2009, 10:09 AM   #9548
Skitee's Avatar
I never had any doubt that the M-05 was faster.
Old 07-18-2009, 11:56 AM   #9549
would you mind sharing your finds?
redbones is offline   Reply With Quote
Old 07-18-2009, 01:08 PM   #9550
Kail's Avatar
redbones, it was as you said, trying to achieve 60-40 weight ratio.
Old 07-18-2009, 01:37 PM   #9551
lol really? how did you achieve it?
Old 07-18-2009, 04:07 PM   #9552
Default m05s, m05m or m05l
Hi all
I just was wondering those who have tested the m05 which chassis has been the most successful out of the 3 m05s, m05m or m05l what is the best shockers to run also?
thanks
green mini is offline   Reply With Quote
Old 07-18-2009, 10:29 PM   #9553
You guys think Tamiya will update the M04 too?
stocker is offline   Reply With Quote
Old 07-19-2009, 04:02 AM   #9554
caltek1's Avatar
Default MO5S/M/L
green mini,
I think it comes back to personal preference on which car length you want to run. All can be made to work well.
The MO5S has more after market body shells that can be used.
Regards,
Calvin.
caltek1 is offline   Reply With Quote
Old 07-19-2009, 04:55 PM   #9555
What size are the bearings that go into the M-05 rear uprights? They should be the same as the M-03R but the instructions do not give the size.
Crashby is offline   Reply With Quote
Currently Active Users Viewing This Thread: 3 (1 members and 2 guests)
1101
Forum Jump
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 08:37 PM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 8 01-01-2007 05:05 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 06:38 AM
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 1 11-08-2005 09:47 PM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 07:55 PM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
