Like Tree103Likes
Old 07-16-2009, 12:34 PM   #9526
axle182's Avatar
Trader Rating: 18 (100%+)
Send a message via MSN to axle182
Originally Posted by Kail View Post
Haha, your 1st para sounds a bit rude.We have been racing for a while and know what we are doing. We were racing on strict tamiya rules, hence only tamiya tires. Of course we all tried various tire combis to make the situation better.
My apologies, didnt mean it to come of that way at all. My whole post was meant along the same lines as redbones, found it funny that guys who were lucky to get the first set of 05's would say they gave up on them considering the 03/04's have years upon years of work to get them to handle. Keep at it guys and make sure you post your progress so we can all get faster with them. Mine is on order, fingers crossed it arrives before the new car hype is dead
Tamiya tires arent bad at all. Takes a few tricks to play with them. How is the TCS officials with glue on the outside tread? Personally on a dusty surface id be on S grip rear, hard inserts, M grips front, hard inserts, and CA glue the half to full outside tread blocks. that should rid you of traction rolling. Then you can work you way up with more steering. Of course forget this post if the TCS officials dont allow CA on the tires....
I cant wait to get mine, ive really looked forward to this car. If money was better, id have one in my hands. Enjoy the new toys, and enjoy finding what will work on it
Aaron "AJ" Freind
axle182 is offline   Reply With Quote
Old 07-16-2009, 01:14 PM   #9527
Kail's Avatar
Its cool Yup yup, understand your point, thats why I stuck to the M05 and was trying various ways to improve it. The track condition I experienced was horrifying. Within the day, with only less than 10 degree change on the track temp, the cars behaved very differently, so much so as to cause a 1.4s laptime difference on a 16s lapper. It was weird when M grips yielded less grip than S, traction roll was non-existent at all. Hence, the best combi was front are rear S with hard insert.
Well, I will test out some new stuff at our proper track tomorrow to see if there is anything I can do to improve the car. So far, I have been frustrated, unable to make the break through on the car even though I tested 2 days straight and a couple more days with more than 1000 laps put in on the 20s lapper track. Funny thing is, no matter how different the car felt, the best lap time was the same for each of the different settings. Even the consistency of lap times were similar, only 0.2s difference between average and best lap.
My verdict so far is that the M05 on a prepared surface is as fast as an M03, less twitchy and slightly more consistent than the M03.
Test limitations: Tamiya tires and Lightly tuned motor as per TAC rules.
Kail is offline   Reply With Quote
Old 07-16-2009, 03:08 PM   #9528
hmm, your more likely to benefit from Grahoo's mods for TGP than I ever will. They have a special way to make the dampers that gets them in the Amain consistently. It was even covered in the RCWorld magazine. Grahoo said that the damper works well for the M03, but not the case for the M05 due to the reason I posted before. But he has a prototype setting that seems to be working well, and tweaking it more. We'll see what he comes up with.
redbones is offline   Reply With Quote
Old 07-16-2009, 03:15 PM   #9529
Core Creations's Avatar
Trader Rating: 93 (100%+)
Send a message via AIM to Core Creations
Here's my M05....ready for battle! Sorry...the ESC is old skool...only one available at the moment!
Core Creations paint thread
Mini Mafia Kansas Chapter - where the monster minis grow!
Core Creations is offline   Reply With Quote
Old 07-16-2009, 04:16 PM   #9530
Clayton's Avatar
very nice work mate, the car looks awsome
Bro-Kin racing, Castle Hill Raceway
Clayton is offline   Reply With Quote
Old 07-16-2009, 04:18 PM   #9531
tamiyarcracer's Avatar
Send a message via Yahoo to tamiyarcracer
Hey Core,
What is the Aluminum steering rod from (servo - bell crank)?
tamiyarcracer is offline   Reply With Quote
Old 07-16-2009, 04:30 PM   #9532
madjack's Avatar
Trader Rating: 19 (100%+)
Send a message via Yahoo to madjack
looks good, so will you be making the trek west for TCS Finals Core?
madjack is offline   Reply With Quote
Old 07-16-2009, 05:06 PM   #9533
Originally Posted by tamiyarcracer View Post
Hey Core,
I can tell you but...you know the rest...
It's here...you need to use a die and thread about another 10mm (5mm or so each side) and then shorten it a little....but worth the work!
https://www.tamiyausa.com/product/it...oduct-id=53941
The new serrated wheel nuts are killer too!! No more nylon to wear out...and no way a wheel is coming off!!
https://www.tamiyausa.com/product/it...oduct-id=42143
Old 07-16-2009, 05:07 PM   #9534
That's the plan...I anticipate this will be a learning year for me as so many others have years on this track over me...but I'll try!
Old 07-16-2009, 05:21 PM   #9535
I was wondering if that was what it was.
Old 07-16-2009, 06:20 PM   #9536
Thanks for the info Calvin.
Sydewynder is offline   Reply With Quote
Old 07-16-2009, 06:31 PM   #9537
Originally Posted by racenut123 View Post
Some run BL Willy,but most are TCS guys.Instead of complaining,actually put a car together and actually come out and race!
John not complaining. What you said is exactly what it is. Most are TCS only and that's all they want to run, silver can.
I have a car put together for oh 5 years now. You even called it a 12th scale pan car with a mini copper body when you drove it. Then again foams on carpet isn't TCS legal. Nor is the Hobbywing system that seems to work very well for the guys in Australia.
Old 07-16-2009, 08:01 PM   #9538
madjack's Avatar
with a new racing surface at the end of the month it will be new to all the racers!
Old 07-16-2009, 10:11 PM   #9539
Kail's Avatar
I used his damper setting before. Its good. Ya, but for M05 it really does not work.
Old 07-16-2009, 10:16 PM   #9540
I'm going to try the zero rebound shock that Jilles Groskamp uses for his 416. Might be better suited for the geometry of the M05 front.
+ YouTube Video
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 04:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-01-2011 11:08 PM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 08:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 06:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 07:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
Currently Active Users Viewing This Thread: 7 (1 members and 6 guests)
dmcguire
