Like Tree137Likes
Old 07-15-2009, 09:29 PM   #9511
Originally Posted by caltek1 View Post
redbones,
In Japan you can obviously get away with major modifications to your mini. Here in Australia and USA, you can not make modifications to your chassis, otherwise you are Disqualified. I will stick to what is legal for us. I see no point in having two different cars, one for clubbies and one for events, when testing/driving are not the same. Seems counter productive to what you are trying to achieve.
My thoughts only. Each to there own. Here in Aust we can not even run a fan on our mini's, not that we have needed them. The Hobbywing 13T BL system works well and with the large cooling fins, seems to disapate the heat reasonably well. Although last weekend on the carpet after some long runs they were fairly warm.
Regards,
Calvin.
sorry to hear your regulations are stricter than TGP. Does that mean you can't even take off the rear braces which is the first thing many racers do? It doesn't do much and the chassis is still rigid without it.
Well, we don't have much rules where we race. Anything goes as long as the power source (HW13) is the same. The cool thing with mini is that lots of original ideas start popping up. The way the car handles about the same with different mods also create many unique cars which I think is cool. There is not one definite answer to make the magic mini.
We need everything we can since we race against 4wd minis in the open class. We get beat out of turns, but we can attain higher top speeds on the straight which balances things out.
redbones is offline   Reply With Quote
Old 07-15-2009, 10:05 PM   #9512
NT
NT's Avatar
Trader Rating: 21 (100%+)
[QUOTE=DRAG_ON;6070096]
Originally Posted by tony gray View Post
Mini 50 A finals (for M03) online now..
Not an easy venue to film in, but you'll get the idea.
Leg 1
/QUOTE]
nice and clean race in leg-1 race, 1st and 2nd place battle is that m05 ? very surprise i didn't see any traction rolls at all in the race............
Drag_On - they are all M03's on the track - the 05 is not legal in Australia yet. There were a few traction roll issues early in the weekend, but most people had them under control with tire and spring changes very quickly. The cars you see in the A Finals were VERY well sorted for a surface none of us had raced on before. We had a BLAST!
NT is offline   Reply With Quote
Old 07-15-2009, 10:07 PM   #9513
monkeyracing's Avatar
I got to drive the M-05 for the first time tonight. (grippy carpet, smooth as glass) I'm quite impressed with the balance it has. It didn't matter if I was running hard springs or soft, or whether I was using really sticky tires or crappy kit tires. The car just worked.
It can handle more in the corners before traction roll becomes an issue, and if it gets loose in a corner it almost seems as if it self corrects. I tried throwing it out of balance in hard cornering, but it was unfazed.
I did manage to get it to traction roll a few times by using very soft springs, sticky tires, loads of traction compound and too much speed. Other than that, it was stable.
Very impressive!
Jim
Stab it and steer.
monkeyracing is offline   Reply With Quote
Old 07-16-2009, 02:10 AM   #9514
tony gray's Avatar
For those of you who missed out on the M05 Pro (and that's most people because it was only a short production run) - fear not, because the standard M05 kit hit the streets today.
Price ex-japan (rc-champ) comes in at around $82 USD, plus freight.
tony gray is offline   Reply With Quote
Old 07-16-2009, 02:26 AM   #9515
cannon's Avatar
Trader Rating: 35 (100%+)
Great price ... pity that the freight charges from Champ always manage to be 30% of the item cost no matter what you order when shipped to Australia
www.feralbatteries.com ........... new website
cannon is offline   Reply With Quote
Old 07-16-2009, 06:53 AM   #9516
Kail's Avatar
Very impressive!
Jim
Haha M05 might work on high tractions tracks. However, during our last race outing at a very loose surface, many who tried M05 gave up on it. On a very loose surface, the M05 was a much tougher vehicle to drive fast.
Kail is offline   Reply With Quote
Old 07-16-2009, 07:17 AM   #9517
mild seven's Avatar
Trader Rating: 62 (100%+)
Send a message via MSN to mild seven
I didnt have much luck with m05 last night either. no matter what i did i just could not get the car to handle properly. it was very hard to drive through high speed corners. low speed corners were ok, could control the slide.
Someone suggested to me to try the 2.0 degree toe blocks on the rear instead of the standard 1.5 deg. I will have to try that next time.
mild seven is offline   Reply With Quote
Old 07-16-2009, 07:19 AM   #9518
Core Creations's Avatar
Trader Rating: 94 (100%+)
Send a message via AIM to Core Creations
What kind of setup were you guys running? Tires?
Core Creations paint thread
Mini Mafia Kansas Chapter - where the monster minis grow!
Core Creations is offline   Reply With Quote
Old 07-16-2009, 07:29 AM   #9519
axle182's Avatar
Trader Rating: 18 (100%+)
Send a message via MSN to axle182
I find it kind of funny guys talking about giving up on there 05 pros after such a short time! Ill GRADLY purchase it off you, and I guarantee itll handle on carpet and dusty surfaces. its going to time, suspension adjustments, different tires and different inserts to find the sweet spot, but i guarantee its there! Get back to testing!
At a complete guess (havent even seen one in the flesh yet) sounds like the added weight of the servo and elecs to the back has given it a bad slide characteristic. Personally, id add more lead to the battery area, and a little forward of that, to get back to the original balance. Go to super grippy tires on the back and hard kit tires on front, and work your way forward. Follow the rule, get it to understeer, get rid of the tail sliding, and slowly creep up on front grip. If your fighting slides all day long, you will be there a long long time
Aaron "AJ" Freind
axle182 is offline   Reply With Quote
Old 07-16-2009, 08:06 AM   #9520
Kail's Avatar
Haha, your 1st para sounds a bit rude.We have been racing for a while and know what we are doing. We were racing on strict tamiya rules, hence only tamiya tires. Of course we all tried various tire combis to make the situation better.
During that race, our surface was very dusty on an unprepared temporary surface. I did not have bad slide problems. However, I was having problems getting off power steering. I had to compromise on the car's stability to get it to have that little bit more steering. Well, I carried on with the 05 and won but I still think M03 handles better on loose dusty surface. The other guys who gave up on the 05(only for that race due to time constraints) had really good setups on their M03 for that surface.
Guys, remember M03 is still a very capable car and it is really hard to beat it when it does not traction roll. Hence, we shall not discount the M03.
Old 07-16-2009, 09:59 AM   #9521
If you are limited to running tamiya tires, then maybe the Mgrips radial work the best on dusty surfaces? The M03 is car that has been around for about 10 years. It's been tested, beaten, thrashed, and optimized to perfection. Still too early to give the verdict yet. When the M03 first came out, it could not beat the M01/02 until people started to figure it out. The fact that the M05's resistance to traction rolling will aid you in an event of rubbage as well(you win).
Old 07-16-2009, 10:18 AM   #9522
One interesting fact I found out is the front suspension geometry, thanks to Grahoo's tests. The M03's suspension travel's leverage increases as the car rolls. This means the front has a tendency to roll more. But the M05 is the exact opposite and the leverage decreases as the arm moves up. This is one of the factors why the car feels different. If you are thinking about optimizing the front suspension, keep this fact in mind.
The chart shows the amount of shock compression change as the suspension compresses. Note the M05's change increases versus the M03's decrease
source: http://blog.goo.ne.jp/taromaru32/e/5...6f2f7aa4d9692a
Old 07-16-2009, 10:28 AM   #9523
I didn't realize the M05 Pro was a limited production kit??? Interesting since the MO5 Kit (in any form) doesn't seem to be available in any shop in the US yet. I wonder what's the hold up?
Any word on release dates for the US?
Geppetto is offline   Reply With Quote
Old 07-16-2009, 10:32 AM   #9524
I think I saw it at www.towerhobbies.com
bowl806 is offline   Reply With Quote
Old 07-16-2009, 12:18 PM   #9525
MD
MD's Avatar
Trader Rating: 112 (100%+)
Tower is saying late July.
MD is offline   Reply With Quote
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 04:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-01-2011 11:08 PM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 08:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 06:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 07:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
Currently Active Users Viewing This Thread: 4 (1 members and 3 guests)
AngryRog
