Like Tree23Likes
Old 06-30-2009, 07:20 PM   #9346
tony gray's Avatar
Home club/track is Keilor.
But we run everywhere - Templestowe, Bendigo, Radical r/c indoor....
And next weekend - MINI 50 at the Melbourne Showgrounds.
tony gray is offline   Reply With Quote
Old 06-30-2009, 08:00 PM   #9347
Manny's Avatar
Originally Posted by redbones View Post
...... compatibility with a modern ball diff. It may be the same now, but there is more potential to be unleashed.
I thought that's what the bearing spacer was for! Is there a modern ball diff that will fit in this car?
Manny is offline   Reply With Quote
Old 06-30-2009, 08:55 PM   #9348
Kail's Avatar
Originally Posted by caltek1 View Post
Good to hear Kail. Was that using the box stock setup?
Regards,
Calvin.
I transfered my M03 shocks and did some ackermann changes. The box stock ackermann was not very aggressive during the turns. The car had a tail that was much more planted, less fighting with the car.
Kail is offline   Reply With Quote
Old 06-30-2009, 08:57 PM   #9349
Kail's Avatar
Originally Posted by tony gray View Post
Hey Leonard, good to hear you can get yours out on the track. I'd like to do the same but rain, wind, thunder and lightning is the weather here at the moment. With no letup expected until next week!
I'll get some indoor action with our car tonight but that wont tell us much....
I should fly up to Sing to test..
Indoor will be good too, to see the effects of traction roll. I am very interested in that actually.
Old 07-01-2009, 01:01 AM   #9350
cannon's Avatar
Trader Rating: 35 (100%+)
Mmmmm ... stay tuned. I may have found a new Tamiya ball diff that fits in the M05
www.feralbatteries.com ........... new website
cannon is offline   Reply With Quote
Old 07-01-2009, 01:12 AM   #9351
monkeyracing's Avatar
Dammit! Me and my lack of patience! I just ordered one.
Jim
Stab it and steer.
monkeyracing is offline   Reply With Quote
Old 07-01-2009, 01:27 AM   #9352
cannon's Avatar
OK I have been playing around with a rear diff from a Tamiya Dark Impact. The fit is almost correct. Obviously the plastic gear in the centre is wrong but a replacement gear for a 3 racing M chassis diff is a perfect fit. Now just need to find smaller diff balls to suit. The diff has a bit of left to right movement between the chassis halves but that may be able to be spaced out. If I can find something that is close with a first try there must be someone who can manage to find one even closer
Old 07-01-2009, 01:30 AM   #9353
caltek1's Avatar
Trader Rating: 33 (100%+)
Kail,
What ackerman change did you make.
Regards,
Calvin.
caltek1 is offline   Reply With Quote
Old 07-01-2009, 04:37 AM   #9354
Kail's Avatar
TA03 ball diff works fine as per the M05 manual.
Old 07-01-2009, 04:41 AM   #9355
414play's Avatar
Forgive my ignorance but doesn't the TA-03 one fit?
414play is offline   Reply With Quote
Old 07-01-2009, 04:43 AM   #9356
cannon's Avatar
Yes it does but Tamiya has designed the M05 to take a new diff that they are obviously going to release at some stage.
There is a good chance that Tamiya already has something that will fit that is a better and lighter diff than the TA03 diff
Old 07-01-2009, 04:48 AM   #9357
cannon's Avatar
The TA03 diff is an old design , both poor quality and heavy. Imagine putting in a diff something like a TA05 or 416 diff. Lighter , spools up quicker etc etc
The fact that Tamiya is using a bearing carrier in the M05 shows they are ready to use a diff with the standard 15 x 10 diff support bearing
Old 07-01-2009, 05:09 AM   #9358
Kail's Avatar
I see!
Old 07-01-2009, 07:19 AM   #9359
Old Tech's Avatar
It would be nice to see a ball diff that you can adjust without having to take the chassis apart like you have to do with the TA-03 diff currently.
Old Tech is offline   Reply With Quote
Old 07-01-2009, 09:40 AM   #9360
Barry White's Avatar
What's wrong with the 3 Racing one?
http://3racing.hk/products.php?products_key=2195
Barry White is offline   Reply With Quote
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 04:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-01-2011 11:08 PM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 08:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 06:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 07:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
