Question regarding rims for the M03. How is everybody's experience with the rims from Cross and/or 3 Racing? I see that they are priced per 8 pcs at a price similar to other manufacturers rims for 4 pcs, or even 2 pcs in some cases. Is this a "you get what you pay for" thing? I'm looking to run my M03 on a carpet track and figure on doing a little experimentation with tires so saving a little on rims until I get that "magic" set-up down is a nice thing.
This should fit the M-04 and probably now the M-05 too but there's absolutely no chance this will fit an M-03.
Tamiya TA05 Ver.II R with Tamiya TBLE-01 & Tamiya TBLM-01 12T
Tamiya TA05MS with Tekin RS Pro & Team Orion 13.5
Tamiya TRF416 with LRP Sphere TC & Trinity Duo 4.5
Tamiya M03R with SJ FSSOP & Tamiya Sport Tuned
I have not experienced any problems with the Cross rims or tyres. However for carpet I have used the Tamiya M Grips, kit tyres or S grips. The HPI M tyres work also on the front but have a smaller diameter.
For asphelt the Cross tyres and rims work very well on the rear of the car. I do not use the foam insert, but replace this with a spice 5.5mm insert.
The 3Racing wheels are a good deal. They hold up well and seem quite durable.
Jim
Originally Posted by caltek1
Old Tech,
Orion 3200, Yeah Racing 3200, Team C 4000, IP 4000, Core3250
Thanks for the info.
My friend told me that the YeahRacing 3600mah won't fit in the mini. But the dimensions are pretty much that same from the 3200. How true is this?
