Like Tree2Likes
Old 05-12-2009, 12:19 PM   #9046
fordmike65's Avatar
Trader Rating: 28 (97%+)
Originally Posted by Hyde View Post
I thought you didn't want one since you just got the m03 welcome to the mini adiction lol
I knew you were gonna comment! But can you blame me?!?! That thing is beautiful!!!
fordmike65 is offline   Reply With Quote
Old 05-12-2009, 12:42 PM   #9047
little_sister's Avatar
Send a message via AIM to little_sister
Originally Posted by monkeyracing View Post
How does one use an Orion style lipo with those battery holders?
Like this!
RC18B - Brushless, set for indoor carpet offroad
SLASH - Spec
RC10B3 - 13.5 brushless
M03M - Spec Suzuki Swift
M11 2.4ghz
little_sister is offline   Reply With Quote
Old 05-12-2009, 12:46 PM   #9048
Why didn't Tamiya configure the battery holder to accept brick type li-po cells??
Ben.C is offline   Reply With Quote
Old 05-12-2009, 01:43 PM   #9049
monkeyracing's Avatar
Originally Posted by little_sister View Post
Like this!
Close, but no cigar. The M05 uses a different battery holder than the M03.
Thanks anyway!
Jim
Stab it and steer.
monkeyracing is offline   Reply With Quote
Old 05-12-2009, 02:32 PM   #9050
Hyde's Avatar
Yeah they have a ta03r type battery holder. Doesn't look good for those who have lipo
MyForum> www.uncovertruth.forumotion.com
Hyde is offline   Reply With Quote
Old 05-12-2009, 02:48 PM   #9051
b3buggy's Avatar
Looks like the pillar for the m03 battery holder is still there to me.
I doubt they would rule out the orion style lipo from this chassis, would be a bad move by tamiya.
Ross
RCR Racing - Worcester MCC
b3buggy is offline   Reply With Quote
Old 05-12-2009, 08:02 PM   #9052
fordmike65's Avatar
I hope this isn't too far off the current topic,but has anyone seen a BMW 2002 body made for the M-chassis? I know a M02/04 would be more scqle. thanks-Mike
Tamiya mini cooper-2002_rally_car%5B1%5Du.jpg   Tamiya mini cooper-perry%25252002%5B1%5D5.jpg
Old 05-12-2009, 08:28 PM   #9053
gtfour93's Avatar
Trader Rating: 22 (100%+)
I believe ABC Hobby will have them available in the future. I'm gonna start on my new TAMIYA Mini Cooper body for the ABC chassis. It's going to be British Racing Green, with white roof and black fender flares.
gtfour93 is offline   Reply With Quote
Old 05-12-2009, 09:45 PM   #9054
niznai's Avatar
I don't think so because I am avidly hoping and searching everywhere I can and I found nothing. Amazingly enough there's very little done in the 2002 topic especially when you compare it to cars in its class like the Alfa 105 for instance. Just a few 1/18 cars. That's very little for a truly cult classic car.
The closest they have come to classic BMW shells is a 1/10 BMW M1 body made by Carson in Germany and a 1/5 BMW 3.5CSL body made by FG again in Germany. None of these cars however are in the same class of cult status with the 2002.
If a 2002 body was ever made, I think there would be a long, long, long line you would have to join to get one.
Team Greasy Weasel
The best upgrade to any car is some driver skill.
niznai is offline   Reply With Quote
Old 05-12-2009, 09:49 PM   #9055
NT
NT's Avatar
Trader Rating: 21 (100%+)
Instead of having a fast turning twitchy top heavy chassis tamiya I believe are trying to make it turn better without tiping over(and I've seen a lot of flips with this car) and the stearing is going to be more huge upgrade then the twitchyness this car has with the direct links. That type of stearing does good in pan cars for faster quicker turning something the m03 doesn't need.
Huge improvements all around this new car
Top heavy? Mustn't have the car set up - never had many issues with traction rolling, even after the use of lipos.
Why do you want a race car that is less direct (ie responds slower)? That'll make things worse again. The 03 was direct-ish, due to the slop in the linkages and the bump steer etc. I'd be concerned if it went even slower!
Anyhow!
NT is offline   Reply With Quote
Old 05-13-2009, 01:57 AM   #9056
Hyde's Avatar
Anyhow!
ALL The top end pro Touring Cars (and all other RC cars and trucks besides Pan cars) have Bell-Crank stearing systems in them. There is know problem in having this setup. Super little down side (to some) is slop.
Your concerned if it went even slower? Buy a faster servo problem solved.
Old 05-13-2009, 03:59 AM   #9057
looks like m05 will have less bump steer with parallel upper arm angle. lower cg. if comes with lower cg body then even better. m03 will start to lose
rccartips is offline   Reply With Quote
Old 05-13-2009, 04:08 AM   #9058
cannon's Avatar
Trader Rating: 35 (100%+)
Who knows. Not that much lower in the CG department and weight moved away from the driving wheels
www.feralbatteries.com ........... new website
cannon is offline   Reply With Quote
Old 05-13-2009, 09:33 AM   #9059
Originally Posted by stocker View Post
This is suppose to replace the screws on the arm hinges or the shocks ball connector?
A flanged tube and machine screw replaces a step screw ( MA2 or #50582). As you work thru the process, you should be able to figure out which way to insert the tubes to prevent binding and where you can use longer machine screws.
Nothing in the shocks mounting is touched.
Granpa is offline   Reply With Quote
Old 05-13-2009, 12:06 PM   #9060
Low_E's Avatar
Send a message via MSN to Low_E
i would like to order some new tyres for my M-03R.
In our local Tamiya-comp we can, obviously, only use Tamiya-parts ...
So I'm looking for some Tamiya Rims and A-tyres ...but what insets should I use.
I know these: 50686 (blue inserts) are soft.
but what is the difference between 53205 and 53255?
I once bought some Blue ones (50686) and some black inserts that were the same kind of material as those blue ones but a little harder. These were both a soft kind of foam.
Later on I bought some other black ones, which were more rubber-like than the previous inserts I bought, and I prefered thos rubber-like ones.
... but don't know the Tam-number of those M-inserts.
[edit]
Also ...
what is the difference between:
Tamiya M Chassis Super Slicks (#53222) and
Tamiya M-Chassis 60D Reinforced Tires Type A (#53340)
Tamiya M Chassis Slicks (#53215)
in terms of quality, set-up, use ...
thx
thou shall think twice or trice before hitting thee SEND-button
Low_E is offline   Reply With Quote
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 05:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-02-2011 12:08 AM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 09:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 07:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 08:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
