Like Tree103Likes
Old 05-11-2009, 01:22 PM   #9031
Hyde's Avatar
Originally Posted by stitchy View Post
Thanks Granpa. Is it possible to go straight to the machine screws or do I have to get new plastic pieces everywhere since the old stuff has already been "self-tapped?"
Its more easy just to go a couple mm with the tapping screw then go from there with a machine screw of choice.
I believe if you dont tap the thread first and start with a machine screw youll get a more snug machine screw.
People go aluminum hex machine screw to "save weight" but it really doesnt matter. Also by having a cool anodized hex screw just makes it look more trick.
MyForum> www.uncovertruth.forumotion.com
Hyde is offline   Reply With Quote
Old 05-11-2009, 02:05 PM   #9032
Hyde's Avatar
Originally Posted by tony gray View Post
No idea..... I know the ABC Mini bodies are a lot narrower in the centre section, but (assuming yours is a genuine Tamiya) I doubt there would have been any change in the Tamiya bodyshells.
It is genuine Tamiya and its narrow then my other mini cooper body
Im going to run it soon so I know choice then to run it with the funny looking doors
As for 4WD Minis, most of us at rc-mini find them only mildly interesting. They're just a shrunken down Touring Car and have none of the quirks and foibles of a FWD Mini chassis.
I report on them, and I have a lot of them, but I have to say I'd be lucky to drive one once a year. They're just not that interesting to us.
I feel you on that! I get sometimes bothered about the turning of the FWD so I've thought about 4WD but i already have a full 10th scale 4WD Touring Car so im going to stick with FWD
Old 05-11-2009, 07:05 PM   #9033
Yes you can. If you've used the self tapping screws, you don't need to tap the screw holes
The part # for the flanged tube you'll need for the suspension is 50593. You'll need 2 bags. They are brass so they need to be replaced every so often. Also I used longer screws on some of the suspension bits. You'll be able to figure it out as you do it.
Granpa is offline   Reply With Quote
Old 05-11-2009, 09:22 PM   #9034
This is suppose to replace the screws on the arm hinges or the shocks ball connector?
stocker is offline   Reply With Quote
Old 05-12-2009, 12:09 AM   #9035
fordmike65's Avatar
Trader Rating: 28 (97%+)
I believe a machine screw & brass flange combo will take the place of the kit supplied OEM shouldered self-tapping screws
fordmike65 is offline   Reply With Quote
Old 05-12-2009, 01:57 AM   #9036
tony gray's Avatar
This.........
would be an M05...
tony gray is offline   Reply With Quote
Old 05-12-2009, 02:48 AM   #9037
Skitee's Avatar
I like it and I think the servo, ESC and receiver moving to the rear of the car will actually give the car better balance. The only thing that's bothering me is possibly excessive slop in the steering system.
Xray T4 2017 ~ ORCA Vritra VX3 ~ Motiv RC 4.5
Xray T4 2017 ~ ORCA Vritra VX3 ~ R1 Wurks 13.5
Xray X12 2016 ~ ORCA Vritra VX3 ~ Orca TX 4.5
POWERED BY SPEEDZONE USA
Skitee is offline   Reply With Quote
Old 05-12-2009, 02:55 AM   #9038
academygaz's Avatar
Difference in specs (the non-Pro isn't ballraced, though that'd be expected).
M05:
After 10 years since the release of the first M-series R/C car, Tamiya is now releasing the latest M-05 chassis with the popular Rover Mini Cooper racing version body.
# This is a 1/10 R/C assembly kit.
# Length: 315mm, Width: 167mm, Height: 135mm.
# The very popular Mini Cooper Racing car comes loaded on the new M-05 chassis.
# The servo, receiver, and ESC are mounted on the rear of the newly designed monocoque frame for better weight distribution and a lower center of gravity.
# The 3-piece tie-rod steering linkage offers sharp cornering performance.
# Sticker sheet included.
# Includes 60D radial tires and silver Rover Mini Cooper wheels.
# ESC and type 540 motor included.
# 2-channel R/C system, battery pack & charger are separately required.
# A wide variety of Option Parts for M-05 chassis machines and bodies are already available for further customization.
M05 Pro:
Tamiya is proud to introduce the release of a new chassis to the very popular M Chassis range, the M-05 PRO chassis kit. The new chassis layout features new servo, receiver,and ESC positions for improved weight distribution and a lower center of gravity. Further-more, a 3-piece tie-rod steering linkage offers sharp cornering performance. This machine handles extremely well on straights and proves its worth with its excellent high-speed cornering ability. Body shells and numerous Option Parts for M-03 chassis machines canbe loaded onto this machine easily.
# Full ball bearings.
# Length: 299mm, Width: 165mm, Tread: 138mm.
# Includes three chassis extension attachment allowing you to make either a short, middle, or long wheelbase chassis car. (Wheelbases: 210mm, 225mm, & 239mm.)
# A number of high precision parts such as aluminum rear uprights, aluminum ball connectors, setting spacer, three kinds of springs, high-torque servo saver, and aluminum servo horn are included.
# CVA Super Mini Dampers (clear) and TRF short damper springs (soft, medium, hard 2pcs each, white) are included.
# Motor and body are not included.
# ESC, 2-channel R/C system, battery pack & charger are separately required.
# A wide variety of Option Parts are available to further customize your machine.
Quote, Leodis, 2007: ''I've been shopping online for 9 years and the only charge I've ever had to dispute with my credit card company was from TiR. Congratulations TiR. Even porn sites are more ethical than your company!''
RC cars - I haz sum.
academygaz is offline   Reply With Quote
Old 05-12-2009, 03:44 AM   #9039
tony gray's Avatar
How can a "3-piece tie-rod steering linkage" offer better performance than direct links to the knuckles like the M03 has!!!
Gimme a break....
Old 05-12-2009, 06:45 AM   #9040
cartix's Avatar
Trader Rating: 33 (100%+)
Think about this.
With the servo now in the rear, wheelspin will probably be more pronounced.
Cars and boats, lots!
cartix is offline   Reply With Quote
Old 05-12-2009, 06:50 AM   #9041
monkeyracing's Avatar
How does one use an Orion style lipo with those battery holders?
Stab it and steer.
monkeyracing is offline   Reply With Quote
Old 05-12-2009, 08:30 AM   #9042
niznai's Avatar
Gimme a break....
I think what they mean is the steering is going to be more adjustable to various track/setup conditions than before. The three link steering is pretty much like the touring cars and I can say their steering is way better than any mini I have seen. True, the pan-car type steering (the M03 has) can be better but the M03 mini is not a pan car. And when you add all the slop everywhere I don't think it matters much what steering you have.
Team Greasy Weasel
The best upgrade to any car is some driver skill.
niznai is offline   Reply With Quote
Old 05-12-2009, 09:01 AM   #9043
Hyde's Avatar
Gimme a break....
Instead of having a fast turning twitchy top heavy chassis tamiya I believe are trying to make it turn better without tiping over(and I've seen a lot of flips with this car) and the stearing is going to be more huge upgrade then the twitchyness this car has with the direct links. That type of stearing does good in pan cars for faster quicker turning something the m03 doesn't need.
Huge improvements all around this new car
Old 05-12-2009, 10:10 AM   #9044
fordmike65's Avatar
This.........
would be an M05...
All I have to say is that's a damn nice looking M-chassis. Put me down for one
Old 05-12-2009, 10:58 AM   #9045
Hyde's Avatar
I thought you didn't want one since you just got the m03 welcome to the mini adiction lol
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 04:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-01-2011 11:08 PM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 08:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 06:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 07:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
