Like Tree18Likes
Old 04-08-2009, 06:57 AM   #8791
Kail's Avatar
Originally Posted by AiR2k View Post
Here is a video for you Mini-fans from our Finnish Mini Cup.
The video is full coverage of 10min final. Nice racing. Minis are very entertaining RCs to drive.
http://www.youtube.com/watch?v=bBLWag1DM_g&fmt=18
In Finland we have pretty good Mini-scene. Because of our rules, we drive almost stock cars, which keeps racing inexpensive and even.
hehe nice... No traction roll from any of the cars.
Kail is offline   Reply With Quote
Old 04-08-2009, 07:38 AM   #8792
cartix's Avatar
Trader Rating: 33 (100%+)
Originally Posted by mjw View Post
On Sunday I was entered in a 1000 lap Mini enduro held at Fastcats (fastcats.ca). It was the second year for this event. We entered our 4 person team with the only SWB Mini out of 13 entries and had high hopes after a close 5th place finish last year, but it didn't go so well. We ended up 9th, but we were still running at the finish, after having all sorts of problems like losing an upper link screw (and then the outdrive came out), loose servo screws, dead ESC, wheel coming off, etc... We came back from every problem though and finished the race 271 laps down from the leader. The top two cars were seperated by 3.377 seconds after 1000 laps (6 hours, 24 minutes with a mandatory stop at the 500 lap mark). We had a good time, but the poor Mini is in rough shape. I learned a few more things that would have made the car more durable, like a one-way is murder on the front end after 729 laps Just like after last years event, I'm looking forward to next year
I'd post the LiveRC results, but I can't link other sites because of my low post count.
Mike
Sounds like fun What size was the track? Did you change motors?
Cars and boats, lots!
cartix is offline   Reply With Quote
Old 04-09-2009, 11:11 AM   #8793
mjw
mjw's Avatar
Cartix,
It's a 92'x48' track. The motors were a hand out silver can and we were not allowed to change them. It's a great event and I hope they have it again next year. No air cooling was allowed with the motors either. We had a heat sink from a TC4 modified to fit the end of the can with a fan on it. We ripped that out quickly and didn't have any motor problems. the motor came off the track at around 90 to 100 deg. F, depending on where you took the temp (used two different temp guns too).
Mike
mjw is offline   Reply With Quote
Old 04-09-2009, 04:36 PM   #8794
tony gray's Avatar
And a Happy Mini Easter to all.....
Finally (and about time some would say) an update to the Minifans page as an Easter present to all the mini freaks out there.
Check them out HERE
tony gray is offline   Reply With Quote
Old 04-11-2009, 02:53 AM   #8795
edwintklee's Avatar
Trader Rating: 23 (96%+)
tony,
need your opinion, you did mention that HB ezrun esc + 13t motor work best on a M03, i totally agree, recently due to our local race ruling, best is we use 11.5t bl motor(SP, or other brand.) i got myself a SP 11.5t, i notice its speed not so much different with 13t,
but 11.5t motor looks so more hi tech compare to a HB 13t motor. why is it slower that a 13t?
or is it i did anything wrong you can think off?
thanks in advance..
I am a Red Star, Blue Star, Fans......
edwintklee is offline   Reply With Quote
Old 04-11-2009, 03:10 AM   #8796
cannon's Avatar
Trader Rating: 35 (100%+)
Originally Posted by edwintklee View Post
tony,
thanks in advance..
It is all about gearing. The 13T can cope better with the restricted gearing from a Mini. To be fast the 11.5 needs a taller gearing.
www.feralbatteries.com ........... new website
cannon is offline   Reply With Quote
Old 04-11-2009, 03:37 AM   #8797
tony gray's Avatar
Greg's on the money there, it's all about gearing. I bet you went with the 20t, right? I suggest it's probably the wrong choice...
You gotta remember too, the HW 13T is a 380 size motor (not a 540) so direct comparisons are difficult to make.
Have to say your rules are a little strange. 11.5? HMmm...
Old 04-11-2009, 07:57 AM   #8798
monkeyracing's Avatar
Jim's Tech Tip of the Day"
Do not fill your gear diff with 10,000wt silicone diff oil. No matter what anyone says, it will not stay where you put it. You will however, have a very quiet transmission.
Jim
Stab it and steer.
monkeyracing is offline   Reply With Quote
Old 04-11-2009, 04:19 PM   #8799
tony gray's Avatar
Jim, this surprises you in what way?......
If I may quote from our M03 Build-up article.
"Stuffing the casing with anti-wear grease or anything else just results in it leaking all over the place after a while"
Old 04-11-2009, 05:56 PM   #8800
Erwin lewi's Avatar
any info about upcoming M05 mini ?
www.hobiland.net ,081-660-3518
www.multimakmurperformance.com
NA / standar jalur kiri
Turbo jalur kanan
NOS jalur paling kiri (bahu jalan)
Erwin lewi is offline   Reply With Quote
Old 04-11-2009, 09:13 PM   #8801
edwintklee's Avatar
11.5t should go lower gearing am i right? than for the tips
if i wanna go faster than a 13t motor on a m chasis i should go with a HB12 t than?
Old 04-11-2009, 09:32 PM   #8802
caltek1's Avatar
edwintklee,
For a 11.5 motor to work you need to fit a larger pinion than what is available on the mini. The limited gearing available by using the 16,18 or 20 will not let the motor rev out harder.
A brushed 27 Turn motor or any of the colt motors will be faster.
As TG quoted
"You gotta remember too, the HW 13T is a 380 size motor (not a 540) so direct comparisons are difficult to make".
Not sure what speedie you would be using with your 11.5 SP motor, but if you increase your timing that will give you more RPM at the expense of torque.
Can you run the HW system and/or the 11.5? I know I would stick to the cheaper option of using the HW. Seems a more expensive way of running mini.
Regards,
Calvin.
caltek1 is offline   Reply With Quote
Old 04-11-2009, 10:24 PM   #8803
Well, there's a guy in town here who's had great luck with this method and he's not had any leakage....hang on....he's one of you crafty Aussies! I've been had!
(j/k Aaron, I know you wouldn't do that)
Jim
Stab it and steer.
Old 04-12-2009, 07:49 AM   #8804
I'm currently running a sport-tuned motor in the mini class at my club, and doing reasonably well, I usually finish 2nd overall, and the guy to beat is using an ezrun 3000kv system (and is a very good driver ).
The class allows standard silver can, sport-tuned, 17.5 brushless, or Ezrun 3000kv. I'm thinking about getting an ezrun system to try and get a bit more performance from the car, but is it worth considering a 17.5 brushless system instead? The 17.5 would be sensored compared to the ezrun sensorless system, so may provide smoother control, but the 17.5 motors I'v looked at (Novak, Tekin, Nosram) seem to have a lower Kv rating, around 2200-2300 at most. But then again, the 17.5 is a 540 size motor, so may have more torque than the 380 (internal) size ezrun motor.
Of course, I could just get an ESC that can run all types of motor (brushed/sensorless brushless/sensored brushless) and try both a 17.5 sensored and a 3000kv sensorless motor, but that's not gonna be cheap...
Toon is offline   Reply With Quote
Old 04-12-2009, 09:27 AM   #8805
Starteur's Avatar
Hi again guys,
As always I rely on you guys to get the right infos, so here is the case:
I just won a droop gauge with blocks at our recent race and would like some
instructions,i.e. how do I use it?
What should I be looking at droop specs for my mini?
thanks
Ride it like you stole it!!!!!!
Tamiya TRF417V5 SEDAN Racer - Tamiya 416X VTA Racer - Tamiya TRF 416X USGT Racer -Tamiya M05 V2 PRO Racer.
Starteur is offline   Reply With Quote
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 04:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-01-2011 11:08 PM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 08:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 06:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 07:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
