Like Tree163Likes
Old 04-05-2009, 01:42 AM   #8776
monkeyracing's Avatar
Originally Posted by evanwest94 View Post
Buy what? Dead eBay page.
Jim
Stab it and steer.
monkeyracing is offline   Reply With Quote
Old 04-05-2009, 03:59 AM   #8777
academygaz's Avatar
Originally Posted by tony gray View Post
It's fairly obviously just a 'quick fix' to enable the fitment of a wider range of bodyshells because the M03 still has severe limitations in that area as we all know.
Thats the problem, Tamiya are known in M-Chassis for keeping 1/1 realism, if a real car is FWD, then the RC will be FWD....but what FWD cars are out there that need a low nose chassis, AND are proportional to need an M-Chassis? Kei sportscars (Nissan Figaro ) at a push? I can't think of many. Most like HPI's Datsun 510 and 240Z (if Tamiya made their own versions) would go on the M04M already.
Having said that, with a different length steering rod, I guess you might be able to mount the steering on the M05 at the other end to make it RWD?
Quote, Leodis, 2007: ''I've been shopping online for 9 years and the only charge I've ever had to dispute with my credit card company was from TiR. Congratulations TiR. Even porn sites are more ethical than your company!''
RC cars - I haz sum.
academygaz is offline   Reply With Quote
Old 04-05-2009, 05:32 PM   #8778
Ladies and gentlemen, please allow me to introduce "EISENSCHWEIN!" (iron pig)
Stab it and steer.
Old 04-05-2009, 07:44 PM   #8779
Core Creations's Avatar
Trader Rating: 95 (100%+)
Send a message via AIM to Core Creations
Another spare for sale...
Tamiya M-03R TCS Ready!! Blue Edition!! M03R TRF
Core Creations paint thread
Mini Mafia Kansas Chapter - where the monster minis grow!
Core Creations is offline   Reply With Quote
Old 04-07-2009, 02:42 AM   #8780
tony gray's Avatar
Jim, I always said no-one could make one of those NSU shells look good.
And...I see no reason to change my mind after looking at that!
tony gray is online now   Reply With Quote
Old 04-07-2009, 05:14 AM   #8781
Here is a video for you Mini-fans from our Finnish Mini Cup.
The video is full coverage of 10min final. Nice racing. Minis are very entertaining RCs to drive.
http://www.youtube.com/watch?v=bBLWag1DM_g&fmt=18
In Finland we have pretty good Mini-scene. Because of our rules, we drive almost stock cars, which keeps racing inexpensive and even.
http://www.finRC.com
AiR2k is offline   Reply With Quote
Old 04-07-2009, 10:13 AM   #8782
Hyde's Avatar
iswere there ever a 64pitch gear set for the m03? or any type of taller gears made?
i know 64p would be the only way because of lack of room!
MyForum> www.uncovertruth.forumotion.com
Hyde is offline   Reply With Quote
Old 04-07-2009, 01:10 PM   #8783
tony gray's Avatar
Tobee Craft make a set of alternate gears that enable you to use up to a 24 tooth pinion from memory.
And they are absolute junk. Even noisier than the stock gears (if that's possible) and a complete waste of time/money.
Eagle Racing make a set of 'Speed-Tuned' gears, and they're about as useful as the Tobee ones too...
(BTW, pitch has no bearing on actual size of the gear - a 12t 32dp pinion is pretty much the same size as a 24t 64dp pinion, all that changes is the amount of teeth)
Old 04-07-2009, 02:59 PM   #8784
Hyde's Avatar
thanks tony for the info,
so even tho the ER gear set are better then the tobee gears.... witch will make the car faster with a silver can? can people still buy the ER gears??
the club race i raced on the weekend allows any hopup from any company, chassis lightenting, and I'm sure gearing it different then what tamiya is. only rule is silver can.
i need to go faster! i had all alloy arms and everything in the book. but i took off the alloy arms because they were getting trashed on the track! (scrached and pins came out) so I'm using all stock arms.
Old 04-07-2009, 09:48 PM   #8785
mangoman's Avatar
Wow how good is the pace car/rolling start and the hill
Hot Bodies Cyclone!!!
www.smaracing.org
www.rchobbies.com.au - www.feralbatteries.com.au
craig mcphee ( WHERE'S MY BEER )
mangoman is offline   Reply With Quote
Old 04-07-2009, 10:54 PM   #8786
niznai's Avatar
If you have access to a precision lathe you can make your own shaft for the idler and secondary gears and use 48 pitch to achieve whatever fdr you want. You would need to keep to the diff driving gear though.
Team Greasy Weasel
The best upgrade to any car is some driver skill.
niznai is offline   Reply With Quote
Old 04-07-2009, 11:01 PM   #8787
Xtant3150c's Avatar
Kewl Vid.
How's the getting taken out before the race even starts
space for rent
Xtant3150c is offline   Reply With Quote
Old 04-08-2009, 01:29 AM   #8788
mjw
mjw's Avatar
Default 1000 lap Mini Enduro
On Sunday I was entered in a 1000 lap Mini enduro held at Fastcats (fastcats.ca). It was the second year for this event. We entered our 4 person team with the only SWB Mini out of 13 entries and had high hopes after a close 5th place finish last year, but it didn't go so well. We ended up 9th, but we were still running at the finish, after having all sorts of problems like losing an upper link screw (and then the outdrive came out), loose servo screws, dead ESC, wheel coming off, etc... We came back from every problem though and finished the race 271 laps down from the leader. The top two cars were seperated by 3.377 seconds after 1000 laps (6 hours, 24 minutes with a mandatory stop at the 500 lap mark). We had a good time, but the poor Mini is in rough shape. I learned a few more things that would have made the car more durable, like a one-way is murder on the front end after 729 laps Just like after last years event, I'm looking forward to next year
I'd post the LiveRC results, but I can't link other sites because of my low post count.
Mike
mjw is offline   Reply With Quote
Old 04-08-2009, 04:23 AM   #8789
At first the jump was pretty tricky, but after a while with right "flow" it wasn't that hard. But I just have to say; if Mini isn't in good setup, jumping with it is real nightmare. Damn, I was out of control in practice.
Old 04-08-2009, 05:18 AM   #8790
I was there too. That jump wasn`t too bad if you slowdown a littlebit before that. But when heat is on anything can happen when you race close to close with Mini`s
Only bad thing for me was three different driver stands when you change it and hope you can still make proper result
But still enjoyable..
Racingfactory.fi -> GM - LRP - Futaba - Tamiya Mini M03 - Tamiya 415MSX MRE - Tamiya 416 WE
Cruisaaja is offline   Reply With Quote
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 04:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-01-2011 11:08 PM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 08:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 06:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 07:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
