Like Tree18Likes
Old 04-01-2009, 04:55 PM   #8731
monkeyracing's Avatar
That pretty much sums it up. If two drivers are of equal ability and one can afford a $50 battery, while the other can afford a $200 battery, chances are that the $200 battery is going to make all the difference.
We had the battery wars not so long ago here in the touring car classes. Essentially, if one could afford to keep spending, they could be reasonably assured of winning.
Jim
Originally Posted by axle182 View Post
So if its driver, take out the "we must have an expensive lipo to beat David" mentality in racing and your set. A local club up our way have done just that, its amazing to go to the track, and not be bewildered by the latest peice of so called technology that everyone is using now. They run stick packs, and have limited the lipos you can use also (based on price). Works a treat.
I can see the need for a 4000mah lipo if your doing 30 min finals, but for everyone else on this thread, 5-10 min heats, Orion 2400 is the hot ticket. Cheap, very reliable, car is fast, area to put the led across the bottom of it, and did i mention cheap? Allows you to buy more tires!
Stab it and steer.
monkeyracing is offline   Reply With Quote
Old 04-01-2009, 11:01 PM   #8732
Next question: Which way do you install the ball diff in an M-03? Any have pictures?
Jim
Stab it and steer.
Old 04-01-2009, 11:18 PM   #8733
Skitee's Avatar
You install the ball diff with the tension adjustment nut on the front left
Xray T4 2017 ~ ORCA Vritra VX3 ~ Motiv RC 4.5
Xray T4 2017 ~ ORCA Vritra VX3 ~ R1 Wurks 13.5
Xray X12 2016 ~ ORCA Vritra VX3 ~ Orca TX 4.5
POWERED BY SPEEDZONE USA
Skitee is offline   Reply With Quote
Old 04-01-2009, 11:45 PM   #8734
Cool, I think I did it the right way. I'll have to take the car apart again to check.
While we're on the subject, has anyone noticed their transmission seems noisier with the ball diff rather than the gear diff? I installed mine earlier tonight, and it makes a bit of a racket compared to the gear diff.
Jim
Stab it and steer.
Old 04-02-2009, 12:02 AM   #8735
tony gray's Avatar
Same amount of noise Jim, but there's now more empty space inside the tranny so it echoes around and therefore sounds 'worse'...
tony gray is offline   Reply With Quote
Old 04-02-2009, 12:09 AM   #8736
Drifting101's Avatar
101, what your wanting is superb rear grip, and understeer, and then progressively find more front grip, right to the point you start to roll. Have you added lead? <probably the most important question in mini. I would recommend taking a good look at your car, adding alot of lead down low. What motors are you running? Black can?
I mentioned my setup for carpet a while back, take a look.
Hobby wing 300kv system, My mini weighs 1482grams the lead is wrapped around the battery so as low down and close to were the weight was taken as possible
Originally Posted by niznai View Post
Try changing the camber to more negative and drop the car lower.
Mini is 5mm in the front and3mm in the rear. Also taken the spacer from the rear M03R turn buckle to give more camber
::Mi4::17.5::::::M03R::HW 3000kv::::::T4::7.5::::::HB Cyclone D4::5.5::
"Why follow, when you can lead?"
Schumacher
Drifting101 is offline   Reply With Quote
Old 04-02-2009, 02:36 PM   #8737
tony gray's Avatar
Matt,
you need to go back to basics. Given that you can't even use the same tyres that others use (at TFTR) you obviously have something wrong.
Do something weird - like swap your shocks front to back.
Play with the ride height, often 1mm change at one end or the other can effect a huge change. You need to go through the car, one change at a time and note what difference it makes - if any.
You need to get something more 'normal' with your tyre setup too. Basic set-up, hard front, softer rear. Same goes for shocks springs too.
Lastly, you will almost certainly need to change your driving style. M03's are going a LOT faster than they used to. And the 'keep the corner speed up' style doesn't apply so much any more. Often now the 'point and squirt' works better.
Old 04-02-2009, 05:39 PM   #8738
CC#34's Avatar
Default servo dimensions
Hey,
Can anybody tell me what the largest size servo (dimension wise) is that I can put in a mini m03-L? I have a JRRacing z9000T or a Hitech HS-5985MG that I would like to use if possible. Have'nt gotten my mini yet, so I can't just test it out.
CC#34 is offline   Reply With Quote
Old 04-02-2009, 05:53 PM   #8739
KHoff7's Avatar
Originally Posted by CC#34 View Post
Hey,
Any "standard" size servo which those are so they will work.
Awesomatix USA / Middle River Hobbies / Sweep / Psycho Cells Racing
Karl Hoffmeister
KHoff7 is offline   Reply With Quote
Old 04-02-2009, 06:27 PM   #8740
CC#34's Avatar
cool. Thank you! Should I upgrade ESC? currently I have the stock 540 motor and stock tamiya ESC. I want to keep it spec legal.
Old 04-02-2009, 06:32 PM   #8741
KHoff7's Avatar
You can if you want but it will not make any noticeable difference and is not needed.
Karl Hoffmeister
Old 04-02-2009, 07:44 PM   #8742
niznai's Avatar
You said you're traction rolling. Does that mean you're rolling over, or just lifting wheels a bit?
I think your 3mm is a bit low and you probably have very limited if any droop. That means your car is more like a brick than a car with suspension. Remember that grip is a game of give and take. If your car rolls instead of the chassis rolling and the suspension taking some deflection that means the suspension is too stiff. As suggested above a review of your suspension all around might provide some information. I think your suspension is too stiff right now. I like my cars soft and given that you have plenty of power I think it would be a good idea (and you can afford it) to sacrifice some speed for driveability. Your times are going to pick up if you're smoother rather than having to fight the car in corners.
Team Greasy Weasel
The best upgrade to any car is some driver skill.
niznai is offline   Reply With Quote
Old 04-02-2009, 07:59 PM   #8743
RobS's Avatar
Just thought I'd share my setup with you guys (indoor carpet), kinda of out of the ordinary compared to the rest of you...
Front:
Red Springs
15wt Oil
1 Hole Piston
5mm limiter on shock shaft
Black Sway Bar
M-Grip Tires, Hard insert
Front one way
Rear:
Yellow Springs
15wt Oil
2 Hole Piston
Black sway bar
Kit tires, hard insert
The car pushes a little more then I would like, but the way it is makes it very consistent to drive.
Rob Say
Action Hobbies Kingsville
"In racing you never really lose. You either win, or learn."
RobS is offline   Reply With Quote
Old 04-02-2009, 09:59 PM   #8744
More diff questions! (I'm away from racing for a couple of weeks, so I've got lots of time to tweak and tune)
I built a gear diff last night with a couple of extra shims in it. As mentioned (much) earlier in this thread, I glued the shims to the diff case, and then built it up as usual.
The problem is that the moment I start to get any "limited slip" action as I tighten down the screws, the diff gets very notchy. I've tried loosening and tightening the screws one by one, little by little, but I either have a loose diff or a really notchy one.
Any tips on this I may have missed?
Jim
Stab it and steer.
Old 04-03-2009, 05:24 AM   #8745
monkeyracing get rid of some of those shims they are tightening the diff action too much
MiniMike is offline   Reply With Quote
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 04:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-01-2011 11:08 PM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 08:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 06:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 07:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
