Like Tree48Likes
Old 03-31-2009, 10:11 PM   #8716
cannon's Avatar
Trader Rating: 35 (100%+)
That is the reverse of what most are running around here.
Try Shimizu 30 on the front and a Spice 32 on the rear or a soft Shimizu on the rear
www.feralbatteries.com ........... new website
cannon is offline   Reply With Quote
Old 03-31-2009, 10:12 PM   #8717
MTX3-B's Avatar
Originally Posted by cannon View Post
More a combination with the capacity of the lipo. Higher capacity lipos "stretch" the discharge curve so that at the end of the race the higher capacty lipos are stil holding higher voltage than a lower capacity one
thanks for the clarification.
4WD -- TT01-E; TA-05; HMF 416 WE
FWD -- FF03 PRO
2WD -- M03-M; M05 PRO; X-EVO
MTX3-B is offline   Reply With Quote
Old 03-31-2009, 10:17 PM   #8718
Drifting101's Avatar
I don't have the money right now
::Mi4::17.5::::::M03R::HW 3000kv::::::T4::7.5::::::HB Cyclone D4::5.5::
"Why follow, when you can lead?"
Schumacher
Drifting101 is offline   Reply With Quote
Old 03-31-2009, 10:35 PM   #8719
monkeyracing's Avatar
Agree .. the IP4000 25C is a good lipo for Mini.
Also available is the Ace Power 4000 25C or the Ace Power 3200 30C
All will fit the Mini
Stuff like this is the whole reason I believe in spec racing, right down to the batteries. Once it becomes a battle of who can afford more, then it's not racing anymore.
Stab it and steer.
monkeyracing is offline   Reply With Quote
Old 03-31-2009, 10:38 PM   #8720
cannon's Avatar
Monkey
So you are saying that you cannot have different manufacturers? There is a bit of a difference between the lipos but 4000 is pretty close to the maximum they can get to fit in the confines of the M chassis
David Jun winning by two laps is more to do with the driver
Old 03-31-2009, 11:12 PM   #8721
mangoman's Avatar
Originally Posted by Drifting101 View Post
My mini is forever traction rolling what are the methods to stop it?
Did you build your shocks to limit shock travel?
Hot Bodies Cyclone!!!
www.smaracing.org
www.rchobbies.com.au - www.feralbatteries.com.au
craig mcphee ( WHERE'S MY BEER )
mangoman is offline   Reply With Quote
Old 03-31-2009, 11:51 PM   #8722
try adding super glue to the sidewalls of the front tyres
i was having the same problems with my M grip tyres , stopped it with the superglue trick
sidecarphil1 is offline   Reply With Quote
Old 04-01-2009, 01:39 AM   #8723
Yes to 57.5 which is what Tony P runs
Schumacher
Old 04-01-2009, 07:40 AM   #8724
axle182's Avatar
Trader Rating: 18 (100%+)
Send a message via MSN to axle182
Monkey
So if its driver, take out the "we must have an expensive lipo to beat David" mentality in racing and your set. A local club up our way have done just that, its amazing to go to the track, and not be bewildered by the latest peice of so called technology that everyone is using now. They run stick packs, and have limited the lipos you can use also (based on price). Works a treat.
I can see the need for a 4000mah lipo if your doing 30 min finals, but for everyone else on this thread, 5-10 min heats, Orion 2400 is the hot ticket. Cheap, very reliable, car is fast, area to put the led across the bottom of it, and did i mention cheap? Allows you to buy more tires!
axle182 is offline   Reply With Quote
Old 04-01-2009, 07:43 AM   #8725
axle182's Avatar
101, what your wanting is superb rear grip, and understeer, and then progressively find more front grip, right to the point you start to roll. Have you added lead? <probably the most important question in mini. I would recommend taking a good look at your car, adding alot of lead down low. What motors are you running? Black can?
I mentioned my setup for carpet a while back, take a look.
Old 04-01-2009, 08:48 AM   #8726
edwintklee's Avatar
Trader Rating: 23 (96%+)
but have to keep adding glue...too
I am a Red Star, Blue Star, Fans......
edwintklee is offline   Reply With Quote
Old 04-01-2009, 08:56 AM   #8727
axle182 do you know what weight your mini is?
My club rules state min of 1150 grams, mines 1260 grams using YR 3200 lipo with weights across its length grips rolls quite bad when the tyres warm up.
BILKO1 is offline   Reply With Quote
Old 04-01-2009, 09:10 AM   #8728
niznai's Avatar
Try changing the camber to more negative and drop the car lower.
Team Greasy Weasel
The best upgrade to any car is some driver skill.
niznai is offline   Reply With Quote
Old 04-01-2009, 11:40 AM   #8729
axle182's Avatar
Sorry for the long delay in reply, had to search out the min weight in the rules, as i only remembered i was 100g over. the min was 1200, so i must have weighed in around 1300g with a 2400 Orion Lipo. i know a few people commented how heavy the car is. Also i didnt put any lead outside the wheelbase (meaning its between the front and rear axles) i didnt add anything in the bumpers. All of it was down low too. I placed electronics on the top.
If your grip rolling when the tires heat up, id suggest you go to a harder tire, dont use as much sauce if you us it, and id definately try the CA glue trick. It definately works but add it in small increments. Too much and you can through the tires out, unless you can get the CA off easily.
Old 04-01-2009, 01:49 PM   #8730
Thanks for the reply I've got some slightly smaller wheels/tyres to try out from ansman and abc hobby 51mm compared to standard 60mm should help acceleration and the ride height is lower to
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 04:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-01-2011 11:08 PM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 08:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 06:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 07:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
