all tamiya gears are either bigger or smaller pitch gears.
32pitch tamiya is a little smaller then reguler 32pitch
tamiyas 48pitch is a little bigger then reguler 48pitch.
has something to do with it being from japan
[M01|M03R|TC5R|XX-4|SandScorcher|SuperChamp]
Do not seek death..
Death will find you.
But seek the road which
makes death a fulfillment.
i want are REALLY good stup for a tarmac high grip smooth track please
we are using the GM purple 27 turn motor now and i'm struggling for rear end grip off power , it just wants to swap ends
have you put you're electronics in the rear chassis case? that puts some balance on the chassis as well as weight on the rear wheels.
do you guys have a spec tire? can you use any tires??
Do not seek death..
Is there anything you can do to decrease front grip a little? Tire prep? Suspension tuning?
I've found quite often that this sort of behaviour has a lot to do with the grip relationship between the front and rear wheels and often has nothing to do with weight bias.
1. Try stiffer front springs
2. Reduce the rear droop
3. Remove rear swaybar if installed
4. Install front swaybar or go with a thicker one if one is installed
5. Raise the front ride height or lower the rear ride height
You have too much weight transfer to the front during off power.
+1 good post. Im not a fan of putting any weight past the axle lines. If you want to add weight (its a VERY good idea) id place it around the battery area or just behind it. Im currently running my electronics high over the battery, and a tonne of lead in the rear compartment, stuck to the bottom. if you want to run your elecs in the rear compartment, personally, id stick lead to the bottom of the compartment first, then stick your elecs to the lead.
Tony and the rest of the guys here are always spot on with these little things. Go to your local tire shop and ask for a few sticks of the stick on tire weight lead. Add alot of lead to that mini (in the right places) and you will be amazed. My mini absolutely flies, and its 100g over our min weight with a lipo.
I think they're actually metric pitch which is why they never match imperial sizes like 32, 48 and 64. I just don't know what exactly, but I know that .4 pitch (metric) as used in TA05 cars for instance is very close to .64 (imperial) pitch. Some people even mix pinions and spurs of the two (not my choice) albeit it doesn't work at any spur/pinion radius (i.e. the larger the spur/pinion the better the mesh of the two pitch gears). At smaller radius (smaller numebr of teeth) the mesh is quite rough and ultimately impossible, because curvature becomes too different.
i have my reciever in the rear but the speedo is behind the servo as it's tiny LOL
i have altered the suspension tonight
it was set really low and stiff as we were racing on carpet a couple of weeks ago , i dont have roll barsor a ball diff but am thinking about buying them , do they really work on the M chassis ???
and failing that i will add some weight , i'm a little reserved as to adding weight as i think it may slow the car down but i will try your advice on saturday
TRF416 World Edition |LRP SPX Stock Spec | Speed Passion 3.0 10.5 | Spektrum DX3s | LRP 5300 Lipo
M05 | TRF dampers | Yeah Racing Lipo | silver can |GM sx6 speedo
F103 15th Anniversary | 13.5 LRP | Flightmax Lipo | EZrun speedo | M body (Jordan F1 colours)
If you have ever heard the famous mini wheel spin as they exit the corner, the key to going faster is more weight. I added a tonne for carpet, if i was racing asphalt, id go heavier again, and find the stickiest tires i could find!
HMMMMMMMMMMMMMMMM !!!!
ok cool i will try a lot of thing's
lead is cheeper than a ball diff
Another question for the knowledgeable. there seems to be a maze of tires and inserts available for minis from Tamiya. Would anyone care to comment what each (or combination) is best for? I am interested for the moment only in Tamiya brand stuff.
One of the factors with the wheelspin is the weight transfer in the chassis while cornering. When you hit a corner in a mini, the weight doesn't just transfer to the outside, it also tends to transfer diagonally to the outside rear wheel. This will tend to unweight the inside front wheel, allowing slippage.
One could also attempt to tune this out by stiffening the rear suspension or allowing a little more droop in the front to allow the wheel to remain in contact with the carpet.
Judging by the specs you posted a few days ago Aaron, this seems to be one of the factors that had your car hooked up. The weight doesn't hurt, either, but I don't think it's the only variable.
