Like Tree198Likes
Old 03-09-2009, 10:36 PM   #8506
monkeyracing's Avatar
I use the 3 Racing CVDs. They're cheaper then the Tamiya parts, and work just as well. I've got a set of the Tamiya ones as well, but haven't used them much.
These are the kind of thing that will only get noticed by a REALLY retentive tech inspector and we don't even have those at my club.
Jim
Stab it and steer.
monkeyracing is offline   Reply With Quote
Old 03-09-2009, 11:02 PM   #8507
NT
NT's Avatar
Trader Rating: 21 (100%+)
We have a really retentive tech inspector at our State level events!
NT is offline   Reply With Quote
Old 03-09-2009, 11:52 PM   #8508
tony gray's Avatar
Guilty as charged.......
tony gray is offline   Reply With Quote
Old 03-10-2009, 09:43 AM   #8509
Is the 5mm or 6mm clamp type alloy wheel hex used for m03? The rear axle seems to be almost max-ed out on threads on the stock plastic wheel hex, so I'm guessing the 5mm one?
stocker is offline   Reply With Quote
Old 03-11-2009, 12:12 AM   #8510
gtfour93's Avatar
Trader Rating: 22 (100%+)
I just use the aluminum pin type wheel adapter (53056) on mine and it works fine. Same size as the plastic type. On the other hand, the ones with the locks are much better, to keep them from falling off.
www.activrc.com
gtfour93 is offline   Reply With Quote
Old 03-11-2009, 12:15 AM   #8511
Drifting101's Avatar
I run the 5 mm
::Mi4::17.5::::::M03R::HW 3000kv::::::T4::7.5::::::HB Cyclone D4::5.5::
"Why follow, when you can lead?"
Schumacher
Drifting101 is offline   Reply With Quote
Old 03-11-2009, 12:45 AM   #8512
tony gray's Avatar
And I use the bog-standard black plastic kit ones and always have....
Old 03-11-2009, 01:06 AM   #8513
I have had 2 with cracks, they are still functional of course. Do you experience that? Or maybe I tighten the 4mm nut too tight?
Also, how do you prevent them from coming out with your wheel when the wheel is removed? Mine sometimes do and the pin drops out...
Old 03-11-2009, 01:20 AM   #8514
That is the only reason I run clamps
Schumacher
Old 03-11-2009, 01:43 AM   #8515
tony gray's Avatar
NEWS NEWS NEWS NEWS..
Quite a few of the Asian shops are already advertising the HPI Switch FWD Mini kit (well actually it's a Fiat 500)
But the word is that it is NOT actually released yet.. All HPI have told our source is that it will be out before the end of the month. Initially RTR only with the Fiat 500 shell. Toyota IQ and Alfa Mito to follow, and kit form - eventually...
Recommended retail is 26040y ($264 USD) as shown above. But we're told that street price will be more likely around 18500y ($188 USD)
Old 03-11-2009, 05:51 AM   #8516
1. Probably.
2. You could put a tiny dab of grease on each one, or in the hole.
Jim
Stab it and steer.
Old 03-11-2009, 07:39 AM   #8517
axle182's Avatar
Trader Rating: 18 (100%+)
Send a message via MSN to axle182
you can run the 6mm hexes, i do on some of mine, its obviously good to get the nut onto the nylock, but if you dont its not the end of the world, just check that they are tight each time. also when using the locking hexes, when you put them on, just tighten them a little, then put your wheel and nut on and tighten down, then remove the wheel, and tighten the hex. Its very hard to seat the hex otherwise, if you tighten it down to where you *think* it should be.
axle182 is offline   Reply With Quote
Old 03-11-2009, 09:32 AM   #8518
MD
MD's Avatar
Trader Rating: 116 (100%+)
Tony Gray - I was told by HPI in the U.S. that the HPi mini will not be released in the U.S.
MD is offline   Reply With Quote
Old 03-11-2009, 09:57 AM   #8519
axle182's Avatar
would have to be brilliant move of the year......
Old 03-11-2009, 10:05 AM   #8520
The HPI reps were at one of our local races, showing the car. We were told that it would be out in March or April. True, they did not specifically say in the US, but why even bother to show the car if you weren't planning to bring it in???
Granpa is offline   Reply With Quote
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 04:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-01-2011 11:08 PM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 08:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 06:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 07:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
Currently Active Users Viewing This Thread: 4 (0 members and 4 guests)
