Old 02-02-2009, 08:37 PM   #8236
monkeyracing's Avatar
Hi Mango, actually, most of us here are running the silver cans. They're lasting from 1 to 3 years. That's practice nights and racing every week.
So, with the silver can, the stock speedy is fine. It can and does win races against cars equipped with higher dollar units. With the silver cans it's definitely about the driving more than anything else.
Jim
Stab it and steer.
monkeyracing is offline   Reply With Quote
Old 02-03-2009, 12:15 AM   #8237
tony gray's Avatar
For all of you who have been waiting for me to get off my fat ass and update the Minifans page...well, I finally did...
Click here to see them
tony gray is offline   Reply With Quote
Old 02-03-2009, 01:08 AM   #8238
Your ass isn't fat, Tony. There's just more of you to love.
My wife tells me the same thing. I don't believe her.
Jim
Stab it and steer.
Old 02-03-2009, 01:48 AM   #8239
Mark Flores's Avatar
Trader Rating: 28 (100%+)
Originally Posted by mangoman View Post
The only exception to that would be if you can somehow get your hands on one of the older black can motors.
Hi. What is the advantage of the older black cans over the newer ones?
Mark Flores is offline   Reply With Quote
Old 02-03-2009, 01:50 AM   #8240
cannon's Avatar
Trader Rating: 35 (100%+)
They last longer
www.feralbatteries.com ........... new website
cannon is offline   Reply With Quote
Old 02-03-2009, 02:11 AM   #8241
Drifting101's Avatar
Originally Posted by cannon View Post
They last longer
Also more consist in quality
::Mi4::17.5::::::M03R::HW 3000kv::::::T4::7.5::::::HB Cyclone D4::5.5::
"Why follow, when you can lead?"
Schumacher
Drifting101 is offline   Reply With Quote
Old 02-03-2009, 06:49 AM   #8242
Starteur's Avatar
4 Cell Racer:
There you go my friend
TAMIYA SPRING RATES
Spring Rating [lb/in]
Purple 22.72
Gray 20.91
White Short 17.24
Blue Short 15.27
White 14.82
Blue 14.08
Yellow 13.33
Red Short 12.90
Yellow Short 13.24
Red 11.86
All that info is on the rc-mini.net website.
Starteur
Ride it like you stole it!!!!!!
Tamiya TRF417V5 SEDAN Racer - Tamiya 416X VTA Racer - Tamiya TRF 416X USGT Racer -Tamiya M05 V2 PRO Racer.
Starteur is offline   Reply With Quote
Old 02-03-2009, 07:00 AM   #8243
Thank you very much once again Starteur, I knew I had seen the spring rates (better than stiffness lol) somewhere
So really the only difference between the 2 spring kits is there's a extra spring in the 53440 set?
4_cell_racer is offline   Reply With Quote
Old 02-03-2009, 07:14 AM   #8244
Starteur's Avatar
This is the Hop-Up Option Touring Car Spring Set (Short Type) from Tamiya.
This will work for the 1/10th scale cars from Tamiya.
FEATURES: Three tensions to the spring set either Soft, Medium, or Stiff springs. Steel construction
INCLUDES: Two red neon soft springs Two yellow neon medium springs Two blue neon stiff springs
SPECS: Length: 23mm (0.92") Diameter: 16mm (0.62") That's for 53333
and now for 53440
This is an on-road tuned hard spring set from Tamiya.
FEATURES: Features eight color coded springs. Soft, medium, stiff,and extra stiff spring tensions. These springs are ideal for high speed racing.
INCLUDES: Two soft springs(red) Two medium springs(yellow) Two stiff springs(blue) Two extra stiff springs(white)
SPECS: Length- 26.3mm(1.03") Diameter- 13.4mm(0.53")
Hope this helps you
Starteur
Old 02-03-2009, 07:30 AM   #8245
Starteur buddy, I think we maybe getting crossed wires somewhere
I know the shorter spring set will have a different lb'age for the standard springs, it was just that the 2 other spring sets 53163 & 53440 I needed the info on.
Now 53440 has the extra stiff spring along with the normal red, yellow & blue springs
Now my question is are the red, yellow & blue springs from 53440 set rated the same lb'age as the red, yellow & blue springs from 53163? or is the 53440 set called On-Road Turned Hard Spring Set because of the extra pair of extra hard spring that are included?
Old 02-03-2009, 07:37 AM   #8246
Starteur's Avatar
This is for 53630:
These are Tamiya Soft On-Road Springs.
These springs go on the shocks of the car.
FEATURES: These springs are red in color The damper strength on these springs is Soft
INCLUDES: Two shock springs
REQUIRES: Installation onto shocks
SPECS: Height: .81" (20.6mm) Width: .65" (16.4mm)
This is for 53631:
These are Tamiya Medium On-Road Springs.
FEATURES: These springs are yellow in color The damper strength on these springs is Medium
This is for 53632:
These are Tamiya Hard On-Road Shock Springs.
FEATURES: These springs are blue in color The damper strength on these springs is Hard
This is for 53633:
These are Tamiya Extra Hard On-Road Springs.
FEATURES: These springs are white in color The damper strength on these springs is Extra Hard
Now you have it all, lenght, width, spring rates (those that I found), so now you know that they are not the same, so I hope this helps you make the right decision.
Best regards,
Starteur
Old 02-03-2009, 07:43 AM   #8247
Starteur's Avatar
This is what I found for 53163:
These are replacement Hop-Up springs for the Tamiya 1/10 R/C 4WD/FWD drive
touring & rally cars such as the following: Could be more in the feature
Toyota Celica GT- Four Rally
Skyline GT-R Nismo
Mercedes Benz 190 EVOII AMG
Schnitzer BMW M3
FEATURES: Neon Red (2 Soft Springs) Springs are made of different Neon Yellow (2 Medium Springs) wire composites Neon Blue (2 Stiff Springs)
SPECS: Each spring is .052" thickness 1.10" length .636" Outer Diameter .526" Inner Diameter
Maybe now with all the infos you can compare.
Starteur
Old 02-04-2009, 01:30 PM   #8248
Chris Furman's Avatar
Trader Rating: 112 (100%+)
Which HPI "foam" are you referring to? Do you have a part number?
Originally Posted by SirSwiftAlot View Post
I suggest having atleast a dozen different tire combonations with you at every track. Why you ask? Well weather is never the same and niether is track traction also when you travel to different tracks like us socal guys tracks are always different. So when your car in the morning is dialed come the afternoon you might be loose or have a push and thats when a simple tire change from stiff to soft or soft to medium can make all the difference in the world. Here is what I usually have with me when I go racing.
60 D Tires with tamiya rims:
No insert
HPI low bounce insert
HPI med bounce insert
HPI double stuffed foam/foam insert
HPI Foam and blue hard insert = HARD
HPI Foam and green insert = Stiff
HPI Foam and red insert = Medium
HPI Foam and yellow insert = Firm
Tamiya Super Grip Radials:
No insert
HPI foam insert
HPI double stuffed Foam/Foam insert
HPI Double stuffed Foam/Blue insert
All of the colors above are HPI sedan inserts and I run the HPI foam insert against the tire then the regular foam that would contact the rim and beleive it or not I don't cut the sedan insert down it takes a liitle bit of finess but you can get it in there. The advantage is that it gives you a taller tire which = Higher Top speed for big tracks.
Chris Furman is offline   Reply With Quote
Old 02-04-2009, 01:59 PM   #8249
razzor's Avatar
Originally Posted by tony gray View Post
And...Surprise, surprise, surprise... The 'New Release' list for Tamiya at the Nurnberg Hobby Fair in 2 weeks time in Germany contains this little gem.
58427 - Fiat 500 (M03M)
Finally a new shell for the MWB car...
Cant wait for it to be available
Casterracing ZX1.5R
casterracing EX-1 Pro, SP Silver Arrow
TOP Racing Scythe, SP 17.5, SP GT Pro 2.0
TOP Racing Scythe, SP 4.5 V2, Hobbywing Xerun 120SD 2.0
TOP Racing Scythe, SP 13.5, Hobbywing Xerun 120SD 2.0
razzor is offline   Reply With Quote
Old 02-04-2009, 09:08 PM   #8250
On-Road-Boy's Avatar
Im going to order a new MO3M on the weekend and was just wondering does it come with plastic shocks or oil filled, if so do these shocks work well on the race track?
Sakura XI HobbyWing-Spektrum-Savox
Sakura F113 HobbyWing-Spektrum-Savox-Venom
Team Pink
On-Road-Boy is offline   Reply With Quote
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 05:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-02-2011 12:08 AM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 09:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 07:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 08:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
SEO by vBSEO 3.5.0
