Like Tree198Likes
Old 12-29-2008, 04:56 AM   #7981
Originally Posted by xrayroooahhhh View Post
That's cause I set it up!!!!
I'm really starting to think that on our smooth carpet track.....you really don't need the oil dampers at all....my TT01 is "railed" running friction dampers....I think it's more important to get the right inserts....and springs!!!
R
I built my M03L. Only upgrades include ball bearings for the transmission and then super mini oil shocks. I am setup per rc-mini.net build instructions to run at a low race heigth with the control arms just about level with the ground. I put blue shocks up front and yellow in the rear.
So what is the key with adjusting springs/inserts on carpet?
k_h_d is offline   Reply With Quote
Old 12-29-2008, 09:25 AM   #7982
monkeyracing's Avatar
The photo page is up and running at karz.ca!
Have a look. It's mostly mini!
Stab it and steer.
monkeyracing is offline   Reply With Quote
Old 12-29-2008, 02:19 PM   #7983
caltek1's Avatar
Trader Rating: 36 (100%+)
Jim,
Great pictures on your website. Looks like you have a good turn out for mini. I also like to see a grid comprising so many different mini body shells. The track looks tight and would reward clean driving. I like the fact that you allow cars to be changed from FWD to RWD, something that is different to our rules.
I must finish building my MO4 and give it a test run ,before I turn it into a shelf queen. The Civic and miata cars look excellent.
regards,
Calvin
caltek1 is offline   Reply With Quote
Old 12-29-2008, 04:31 PM   #7984
Jim, that really looks great. YGPM
Granpa is offline   Reply With Quote
Old 12-29-2008, 06:32 PM   #7985
Super Moderator
charlie_b's Avatar
Send a message via AIM to charlie_b Send a message via MSN to charlie_b Send a message via Yahoo to charlie_b
Hey Socal Mini Drivers....
And more track pix....
If you guys aren't doing anything on New Year's Day(liek watching a parade) in Socal, please come on bye!
''Many of life's failures are people who did not realize how close they were to success when they gave up.''-- Thomas Alva Edison
CAL RACEWAY:CAL RACEWAY
GT10 SERIES:GT10 SERIES
CFX Paintworks:="https://www.facebook.com/CFXPaintworks?fref=ts
TEAM ASSOCIATED|REEDY|HITEC|PARMA|PROTEKRC|SWEEP|IWATA| RPM|AMAIN|CREATEX/WICKED/AUTOAIR PAINTS|CFX|CAL RACEWAY
charlie_b is offline   Reply With Quote
Old 12-29-2008, 06:52 PM   #7986
tony gray's Avatar
Now - Just WHAT is this thing? And what's it got to do with Minis?
Click HERE to find out if you really need a Speed Meter.....
tony gray is offline   Reply With Quote
Old 12-29-2008, 07:04 PM   #7987
Pretty damn cool machine, Tony. I had a similar idea for getting an idea of how fast cars were running based simply on output voltage from a motor/generator.
These guys did the math and got it sort of calibrated, too!
Way beyond my scope of smartitude.
Jim
PS: Damn Charlie, you've out-postered me! Now I need to notch it up a bit. Here's my last poster....
Stab it and steer.
Old 12-29-2008, 09:36 PM   #7988
Super Moderator
charlie_b's Avatar
Gonna check out your site now...i wouldn't mind coming down and drivin out there.
Old 12-30-2008, 07:54 AM   #7989
Beltran raceway is a great Mini track. Sure wish I could be there.
Charlie, let us know if you'll have any more events here.
Old 12-30-2008, 08:47 AM   #7990
MD
MD's Avatar
Trader Rating: 116 (100%+)
I don't know if any of you were planning on attending the first TCS race in California, according to the TCS forum the date has been changed so that it doesn't conflict with the Super Bowl.
MD is offline   Reply With Quote
Old 12-30-2008, 01:14 PM   #7991
SerpentCT4S's Avatar
Trader Rating: 94 (96%+)
Send a message via AIM to SerpentCT4S
I just got my Tamiya aluminum shock set.
What weight oil should I run? I am running a stock M03, not racing or anything, just driving it around.
I was also looking at the 3Racing site for some more upgrades. I came across the front and rear graphite rear stiffener. Where do these parts mount? Do they replace an existing part or is it a new part? A picture would be great.
SerpentCT4S is offline   Reply With Quote
Old 12-30-2008, 02:12 PM   #7992
Pictures of my M03L. Mostly stock with transmission bearing upgrade and super mini oil shocks and tuning shocks. This is the first RC car body I have painted. It turned out pretty sloppy but the intent was to look like my 2003 Cooper S. I can't wait to get out and join the local racers.
Tamiya mini cooper-img_0043-large-.jpg   Tamiya mini cooper-img_0051-large-.jpg   Tamiya mini cooper-img_0032-large-.jpg   Tamiya mini cooper-img_0038-large-.jpg
Old 12-30-2008, 02:49 PM   #7993
caltek1's Avatar
SerpentCT4S,
For the Tamiya shocks 50 wt oil front and 40 Wt oil rear. I use three hole pistons front and rear. Ride height should be around 5mm front and 5/6mm rear. The lower the car is the less likely to traction roll.
3Racing front and rear graphite braces go across the top of the front and rear chassis and use the screw holes used for the top mounting point for the shocks. These are not legal for TCS racing but will not worry you for driving around.
3Racing front and rear hubs are softer than the Tamiya hubs. They will not take abuse and bend easily. I have had one degree rear hubs become 10 degree rear hubs from being hit by another racer at full noise.
I advise you to visit http://rc-mini.net/joomla/index.php. There is alot of useful information on the web site.
Regards,
Calvin
Old 12-30-2008, 02:55 PM   #7994
caltek1's Avatar
k_h_d,
Make sure you have some extra tyres. The kit radials wear out quickly. I have found that the tuning on my mini is mostly done with the tyres and then springs if needed.
Not sure if you are running TCS, if so you might want some 60D S grips and 60D's. Here in Aus most run Powers, Spice or rides.
Regards,
Calvin
Old 12-30-2008, 03:06 PM   #7995
Originally Posted by caltek1 View Post
SerpentCT4S,
Regards,
Calvin
Thanks for the advice. I will take a look at the link you included.
I just got my shocks mounted back onto my car. I used 35 wt oil in all 4 and used the 2 hole pistons. These shocks seem shorter than the stock ones. I had to raise my body up one hole on my posts.
I might get the graphite braces. I dont plan on racing, so I dont have to worry if they are legal.
When I said aluminum hubs, I mean the wheel hexes. Instead of the plastic ones, I am going to get the aluminum ones.
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 04:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-01-2011 11:08 PM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 08:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 06:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 07:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
