Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 10-24-2005, 05:49 PM   #781
Big Daddy Boomer's Avatar
R/C Tech Charter Subscriber
Send a message via Yahoo to Big Daddy Boomer
Originally Posted by Customworksking
tcs 1st and tcs 3rd mini
Kevin is it time for me to dust mine off and start working on it?!?!?!?
See you at the novak buddy.
Boomer
Big Daddy Boomer is offline   Reply With Quote
Old 10-24-2005, 08:19 PM   #782
tomdav's Avatar
Originally Posted by asw7576
I think too many o rings for suspension is not suggested, especially if you run in bumpy and dusty tracks. Why ? First of all, you reduce the volume of oil inside ( the plush feelling is gone ). Secondly, you need some droops to make the cooper stick to the ground and feeling stable during cornering. I suggest to use Tamiya shorter spring set OR simply remove the adjustable collar so the front and rear suspension could have some droops ( droop = the amount of shock collapse as soon as the tires touch the ground ).
You mean how much the shocks extend when the car is lifted. The mini has no upstops unless you put o rings on the outside of the shaft. To much up and down travel makes the mini lazy. You dont want a lazy mini
Tom
Camas WA
www.davesrctracks.net
tomdav is offline   Reply With Quote
Old 10-24-2005, 08:59 PM   #783
Customworksking's Avatar
Trader Rating: 14 (100%+)
Default the boooooooooooom
same here Allen's 1st night is the 26th cant wait I got a new 1/12 to try and the MSX kit on the 415...C U soon...kevin
Novak & TCs Mini Cooper winner M03L,M03R,TRF 415,LRP,Futaba 3PK super,Mini Mafia ILLINOIS Chapter Team ,Xray | RC America| Hudy |Jaco | Schumacher U.S.A.
Speed Passion
Core R/C
Customworksking is offline   Reply With Quote
Old 10-24-2005, 09:58 PM   #784
The o-rings work for me. When you build a set of trf shocks, they supply the o-rings to fit on the shaft under the piston to limit how far the shock extends.
For cars such as the m03 that don't have droop screws, o-rings/limiters are used to adjust droop. Droop is the distance the chassis rises before the wheels lift of the ground.
Phenochilus is offline   Reply With Quote
Old 10-25-2005, 12:48 AM   #785
asw7576's Avatar
Maybe we have different car setup then. My home track is bumpy and little bit gripless. That's why I use large droop effect.
Old 10-29-2005, 07:49 AM   #786
ApexSpeed's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to ApexSpeed Send a message via AIM to ApexSpeed Send a message via MSN to ApexSpeed Send a message via Yahoo to ApexSpeed Send a message via Skype™ to ApexSpeed
Only a few things left to pick up for my new mini, and one of them is tires. Can anyone suggest a good starting point on tires for high bite carpet, with the part numbers for the Tamiya tires (TCS rules only)?
Thanks,
doug
The signature formerly known as ApexSpeed.com. And no, I'm no longer associated with the USVTA, but thanks for asking.
ApexSpeed is offline   Reply With Quote
Old 10-29-2005, 04:24 PM   #787
53340 60D SLICKS AND 53254 SGRIP
THE OTHERS DONT HAVE ENOUGH GRIP/STEERING I FOUND
Doomah is offline   Reply With Quote
Old 10-29-2005, 04:29 PM   #788
ApexSpeed's Avatar
Thank you! Which do you prefer on front or rear, or do you like either of them on all 4 corners?
Old 10-29-2005, 04:49 PM   #789
all depends on surface.just buy set of 4 each and mix and match find your best combo.
Old 10-29-2005, 06:21 PM   #790
rccardr's Avatar
For high grip carpet try M-grips in front with full size (26mm) HPI blue or black sedan inserts. Cut about 3/8 inch out of the insert and glue the ends together with rubber cement or shoe goo. In back use S-grips with a Tamiya narrow 24mm black or blue insert cut down like the front insert (even 60D foam works pretty well). Try hard blue short springs up front (the newish sedan ones, not the older bright blue ones) and either red or yellow springs on the back. Think low. Very low. That should get you started.
Later
Doc
I've never lost.
I've just been a little bit behind when time ran out...
rccardr is offline   Reply With Quote
Old 10-30-2005, 12:47 AM   #791
Wicked-Wayz's Avatar
Send a message via ICQ to Wicked-Wayz Send a message via AIM to Wicked-Wayz Send a message via MSN to Wicked-Wayz Send a message via Yahoo to Wicked-Wayz
Later
Doc
HPI inserts would not be tcs legal unless it has changed. Tamiya has a good variety to use that works great.
Peace Aaron(W-W)
Team Associated FT B44 - S&N's Trackside - Dirtheaven - Mini Acres
Schacht Design Works - RC Scoring Pro - LiveRc.com - RMS Graphix - MRT PTX
IRT Member #193, IRT Est: 1999 - Team Mediocre - "Just good enough"
1st Win: June 26, 2008 - Trackside Dirt Oval
Rest In Peace: Mom 44-07, J.Goetsch 80-09, S.Just 55-09
Wicked-Wayz is offline   Reply With Quote
Old 10-30-2005, 01:00 AM   #792
JoeyE's Avatar
This is my "M01". Old but still fun to drive.
JoeyE is offline   Reply With Quote
Old 10-30-2005, 01:01 AM   #793
Turbonium's Avatar
Send a message via Yahoo to Turbonium
the TCS rules allow any insert you want, just hafta stick with the Tamiya tire and wheel...
RCAmerica/Xray - EA Motorsports - Team Novak - RC Paints by Sonny
Turbonium is offline   Reply With Quote
Old 10-30-2005, 03:07 AM   #794
RED-LINE M03's Avatar
Trader Rating: 26 (100%+)
Default TRADE
Any one want to trade a highly tricked out MO3 for a Tricked out MO4
Thanks,
E
RED-LINE M03 is offline   Reply With Quote
Old 10-30-2005, 03:59 AM   #795
JoeyE's Avatar
My LHS has the Mazda Miata M04 kit that includes the TAMIYA esc in stock for $120USD. Pretty nice kit. Might have to get me one
Forum Jump
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 08:37 PM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 8 01-01-2007 05:05 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 06:38 AM
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 1 11-08-2005 09:47 PM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 07:55 PM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
