Like Tree81Likes
Old 12-19-2008, 12:30 PM   #7906
monkeyracing's Avatar
Today's questions are about diffs and servos...
Balll diff I've got a ball diff I use in my mini. It's kept clean and well lubed, but it's kinda crunchy. Any ideas as to why that might be? Maybe because it's tightened down quite a bit?
Gear diff I've heard of people shimming the gear diff for a mini. Any ideas as to what size of shim to use and where I might find some?
Essentially, I'd like to have smooth, predictable diff action, with a decent degree of lock up. Are those two thing mutually exclusive in minis?
Steering servo I read something this morning about someone using a mini servo in an M-03. I've tried this, but the servo is too small to reach between the two mounting points. Any ideas how I might accomplish this one? I thought about just building an adaptor of some kind, but haven't actually tried it yet.
Any ideas you guys have would be appreciated.
Thanks!
Stab it and steer.
monkeyracing is offline   Reply With Quote
Old 12-19-2008, 02:28 PM   #7907
caltek1's Avatar
Trader Rating: 35 (100%+)
monkeyracing,
Ball Diff: I build as per instructions and use lots of tamiya anti wear grease, this will make the diff very smooth. As Defmondo pointed out, do not over tighten otherwise you will strip the diff. Some people also insert an extra cone washer to make it a little tighter, however that may go against your TCS rules.
Gear Diff: Add thicker washers to each side of the diff, or if you have extras add a second washer to each side. The costly way to make the action stiffer is to pack with tamiya anti wear grease, however this loosens up after a short time. Just use the kit supplied as a guide for size. Whem you get new bevel gears for the diff, normally has replacement washers with it.
SERVO SAVER: I have recently fitted the Tamiya M-Chassis Aluminum Horn and Hi Torque servo saver to my Mini and it works great. It is the same as the kit supplied plastic horn in alloy and uses the Hi torque servo parts and springs. This will give the same throw as the original, but is now stronger.
When you use smaller servo's and servo savers you end up affecting your steering on the car. I use a full size digital servo. I have found that the plastic servo posts are better replaced with alloy posts. This limits the amount of flex when turning the steering lock to lock. Some also have four mounting screws for the servo, which gives more rigidity to the assembly.
Just my thoughts.
Calvin.
caltek1 is offline   Reply With Quote
Old 12-19-2008, 04:34 PM   #7908
KREATOR1's Avatar
Send a message via Yahoo to KREATOR1
Any of you guys tried larger pinion than 20t with the sportune black can motor?
TA04ss / TA04TRF / TB EvoIII/ TB02 /DF02 / M03L / TRF414m2 / TRF415 / TRF415MS / TRF415MSX / MRE
KREATOR1 is offline   Reply With Quote
Old 12-19-2008, 05:56 PM   #7909
caltek1's Avatar
KREATOR1,
You can fit a 21 tooth in without doing anything to the chassis, just bolt in the normal position for 20 tooth. Larger can be fitted, however you can only put one screw in to hold the motor.You would also need to use a spacer so that you do not strip the spur gear.
I have never tried this myself, but have seen it used. Was fast in a straight line, but couldn't corner due to excessive speed.
However this goes against the spirit of mini racing. Personnally I think its waste of time, but each to there own.
Regards,
Calvin
Old 12-19-2008, 06:47 PM   #7910
edwintklee's Avatar
Trader Rating: 23 (96%+)
Originally Posted by caltek1 View Post
KREATOR1,
Regards,
Calvin
fot your info, i have got to know some are runing with 23t pinion...
I am a Red Star, Blue Star, Fans......
edwintklee is offline   Reply With Quote
Old 12-19-2008, 07:10 PM   #7911
SERVO SAVER
Nah, not concerned about the servo saver. I use Kimbrough large and extra large. Gotta love those things.
My concern is about how to line up the mounts on a mini servo with the mounting points on an M03 chassis. I hear of people using smaller servos, but haven't found any pictures or instructions on how they did it.
I'm thinking that gluing a couple of servo posts together (side/side) would add the extra bit of reach I need to make it happen.
Jim
Stab it and steer.
Old 12-19-2008, 07:10 PM   #7912
KREATOR1's Avatar
calvin,
I did strip my spur gear using 22t pinion and fry the black can motor
on my last race.
Now i got my fresh set of gear and chassis and not planing to do the mod anymore. But if you guys got to know how to modify the motor holes. plz share with me.
Old 12-19-2008, 08:30 PM   #7913
caltek1's Avatar
KREATOR1,
I have seen a 25 tooth pinion fitted into a mini. You only use one motor screw. The motor will need to be offset within the housing, meshed with the spur gear and then you place a wedge into the side of the motor, so that it can not move if you hit something. The other option is to drill out the motor screw holes and use a washer.
As I said, I have only seen it, never tried it.
Regards,
Calvin.
Old 12-19-2008, 08:37 PM   #7914
caltek1's Avatar
monkeyracing,
I use the Kimbrough large servo saver on one of my mini's but I will be changing over to the new M chassis servo saver.
I have included a photo of it fitted to my mini. You need to use the Hi torque servo saver parts as well as the new horn.
regards,
Calvin.
Old 12-19-2008, 10:21 PM   #7915
xrayroooahhhh's Avatar
Jim.....
Stop by the table and I'll show you the shimmed gear diff!!!! You can pretty much dial in whatever feel you want......if you know where/what to shim!!!
Big charity race tommorow.....I have to remember my camera.....
CU later,
R
Thanks!
-ROOH RACING-
www.donerite.net
xrayroooahhhh is offline   Reply With Quote
Old 12-19-2008, 11:47 PM   #7916
monkeyracing,
regards,
Calvin.
Again, I'm not concerned about the servo saver. I've got that part nailed. No problems at all.
My question is in regards to fitting a mini servo (not the saver, just the servo) to the M-03 chassis.
For example: I have a regular sized servo on the car now. I want to fit a HiTec 225mg, which is a mini servo to the car.
Can you offer any advice on that?
Stab it and steer.
Old 12-19-2008, 11:54 PM   #7917
SchuMi2's Avatar
Trader Rating: 34 (100%+)
Jim
Jim
You can run a piece of carbonfiber 3/8' wide from original servo mounting holes on the chassis and drill 2 holes in the required position for the mini servo. This should work fine. You will need to shim between the carbon plate and chassis and also use servo mounts that sit flush with the bottom of the servo. Shimmed up correctly and it will sit at the same position as a std servo. You can also lower it a little if you want.
SchuMi2 is offline   Reply With Quote
Old 12-20-2008, 01:27 AM   #7918
caltek1's Avatar
Jim,
Not sure why you want to run mini servo. I have seen a few of the standard servo's broken when hit by another mini. I would think these would not be as strong.
I did understand your question, just wanted to show the new mini aluminum servo saver fitted to a mini.
Sorry I have never seen a Mini here in aust fitted with a mini servo. it wouldn't meet our mini rules, built as per instructions.
regards,
Calvin
Old 12-20-2008, 01:52 AM   #7919
monkeyracing,
regards,
Calvin.
I've heard that the Hi torque saver doesn't last as long as the Kimbrough, any inputs on this?
The blue aluminium saver looks really cool though!
stocker is offline   Reply With Quote
Old 12-20-2008, 01:56 AM   #7920
cannon's Avatar
The blue alloy horn replaces the part of the hi torque servo saver that wears out. And is the correct length for the Mini
www.feralbatteries.com ........... new website
cannon is offline   Reply With Quote
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 04:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-01-2011 11:08 PM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 08:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 06:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 07:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
