Like Tree21Likes
Old 11-27-2008, 09:27 PM   #7786
Yeah, tyres seem to wear rather quickly on this beast, esp when brushless powered!!
Do Take Off RP or Ride or Spice have better durability than X-patterns?
stocker is offline   Reply With Quote
Old 11-27-2008, 10:28 PM   #7787
caltek1's Avatar
Trader Rating: 33 (100%+)
No. The tyres all tend to wear the same. It is caused by the low ride heights used to stop traction rolling of your car. The only way to prevent it is to alter your ride height or replace the standard camber link which would then deem the car illegal.
Choice is yours. I just put up with the wear and run til the tyre is thru to the insert.
later
Calvin.
caltek1 is offline   Reply With Quote
Old 11-28-2008, 05:07 AM   #7788
Benzaah's Avatar
Trader Rating: 21 (96%+)
Originally Posted by stocker View Post
What should be the normal wear pattern on the front tyres? Mine are X-patterns and show more wear on the inner part.
We run Clockwise on a rough bitumen track. this is what a set of X patterns looks like after 2 rounds. 2 qualifiers and 3 finals each round.
AERCCC - ARCR - RRCSA
Adelaide RC
Walter Rc Hobby
Benzaah is offline   Reply With Quote
Old 11-28-2008, 05:19 AM   #7789
OK, so it looks like I'm probably on the right track. So with the belt showing like that, we should probably swap front to rear and continue using the set?
Old 11-28-2008, 05:54 AM   #7790
Benzaah's Avatar
You could try and rotate the tyres so that they wear evenly and last a bit longer. Ive been swapping the fronts over left to right to get a little longer out of them but 2 meets is the most ive seen on the surface we currently run on. Personally i've found that either 32 or 36 slicks on the back and the X patterns on the front work best. With the X's now unavailable im not so keen on using the last 3 pairs i have willy nilly. I'm going to try the Glue on the side walls trick with slicks up front and see how i go.
Adelaide RC
Walter Rc Hobby
Old 11-29-2008, 10:12 PM   #7791
doriftu's Avatar
has anyone used these IP 4000 20C stick packs before? How do they perform?
http://intellect-japan.com/SHOP/ip4000.html
thanks
six-shifter.blogspot.com
supercharged-e36.blogspot.com
doriftu is offline   Reply With Quote
Old 11-30-2008, 01:33 AM   #7792
tony gray's Avatar
Thought everyone might be interested in what we did to our Sport-Tuneds after the Metro Masters finished this afternoon...It was our last event for Sport-Tuneds because we're going all brushless next year!
Bye Bye Sport-Tuneds...
tony gray is offline   Reply With Quote
Old 11-30-2008, 02:12 AM   #7793
Drifting101's Avatar
Tony,
Did you really ask to look at every can today?
::Mi4::17.5::::::M03R::HW 3000kv::::::T4::7.5::::::HB Cyclone D4::5.5::
"Why follow, when you can lead?"
Schumacher
Drifting101 is offline   Reply With Quote
Old 11-30-2008, 02:19 AM   #7794
mangoman's Avatar
Wow, is that a new run-in procedure?
Besides i'm sure you guys have more than that!
Hot Bodies Cyclone!!!
www.smaracing.org
www.rchobbies.com.au - www.feralbatteries.com.au
craig mcphee ( WHERE'S MY BEER )
mangoman is offline   Reply With Quote
Old 11-30-2008, 02:22 AM   #7795
tony gray's Avatar
Originally Posted by Drifting101 View Post
Tony,
Someone had to check em Matt...so I did. Thats my job.
Yeah but we sold the rest... Hee hee
Old 11-30-2008, 02:37 AM   #7796
Fair enough.......I got brushless in my mini already
Schumacher
Old 11-30-2008, 07:11 AM   #7797
edwintklee's Avatar
Trader Rating: 23 (96%+)
what a waste.....so what type of bl systems are you guys running?
13t + hobbywing ezrun? i have got the 9t version is it too fast?
I am a Red Star, Blue Star, Fans......
edwintklee is offline   Reply With Quote
Old 11-30-2008, 11:53 AM   #7798
tony gray's Avatar
13T/3000kv Hobbywing systems. An almost perfect match with none of the hassles!
The 9T is WAY too fast.
Old 11-30-2008, 07:27 PM   #7799
edwintklee's Avatar
ok....is there a method to tune down the 9t? have any1 tried?
if the motor too fast its sure gonna roll over..
Old 11-30-2008, 07:31 PM   #7800
tony gray's Avatar
Not possible to 'down tune'
You need another motor I'm afraid. The 9 turn is way way too fast.
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 04:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-01-2011 11:08 PM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 08:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 06:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 07:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
Currently Active Users Viewing This Thread: 4 (0 members and 4 guests)
