hi. i was wondering what i can do to reduce traction roll....
i can't keep up corner speed as much as i want on a sweeping corner coz of traction rolling entering the corner... if not for it rolling i could easily pilot the car around at 3/4 throttle, but i can now only do it at 1/4 throttle... which is costing me probably about 1/2 a second per lap.....
i already got the electronics within the center....
what sort of setup idea ideas can help with rolling??
MO3 chassis are like that, easy to get traction roll. You can minimize the traction by some of these :
1. lowering ride height like 4mm front, 6mm rear. ( use tamiya short springs )
2. stiffen up front springs
3. use smaller diameter tires, tamiya have normal super slick for mini ( Not 60D tires ).
What tires are you running? I've learned that if you have M grips up front, they tend to expand after a while. This leads to a roll in high speed turns. A couple of guys told me to try different tires, I have "A's" in the front and "S's" in the rear. I'm thinking of trying S's in the front also just to see what it's like. I was stumped for months trying to figure this out. The car works great now.
i use s on the front and hpi x-pattern on the rear...
M up front are ok for large turns, but just dont work on the tighter corners coz they push way too much and make u run wide.
slam the front via:inside the shock give it about 1/4 travel 60w oil white springs ,slam the back the same way but give it about 1/2 travel yellow springs 30wt Mgrip ft S grip rear glue the side walls ft & rear run the body as low as u can and drive it 1st no dope add as needed rear 1st then ft keep tires clean at all times....it works I won TCS mini in Cinci and 3rd at Trackside
Novak & TCs Mini Cooper winner M03L,M03R,TRF 415,LRP,Futaba 3PK super,Mini Mafia ILLINOIS Chapter Team ,Xray | RC America| Hudy |Jaco | Schumacher U.S.A.
Speed Passion
Core R/C
Here's a few pics of my new Alfa. Just for fun. Nobody races them around here.
It's got a few upgrades already:
1. Manta Ray Diff
2. Tamiya Universals
3. Hollow Carbon Gear Shafts
4. S.S. Hinge Pins
5. M04 Motor Heatsink
6. Ball Bearings
On the way:
1. Lightweight Kingpins
2. Titanium/Alum screw mix.
3. Red and Blue locknuts-red on left side of car , blue on right.
On a personal note, I wish Tamiya would re-release some bodies from previously released but now discontinued cars like the Fiat Abarth, the Renault Alpine and VW Beetle. And more upgrades-re-release the discontinued M04 sway bars and motor heatsink. Maybe even come out with a new M04 based Porsche 911 RSR and BMW CSL?
I just got done building my M03. I put bearings, a ball diff and cva shocks on it. My question is, should i have put limiters or something in the shocks because they seem pretty long and the thing is riding pretty high.
Losi Micro Baja
Losi XXXT
Kyosho RB5
Kyosho ZX5 for sale
I like to take photos, check them out.
http://www.flickr.com/photos/randerson07/
Yes, get some silcone o-rings and put them in the cva shocks so they don't extend too much. I use 2 or 3 o-rings per shock.
I just used the plastic spacers that came with the shock kits. My mini rides real low I will be going lower.
Peace Aaron(W-W)
Team Associated FT B44 - S&N's Trackside - Dirtheaven - Mini Acres
Schacht Design Works - RC Scoring Pro - LiveRc.com - RMS Graphix - MRT PTX
IRT Member #193, IRT Est: 1999 - Team Mediocre - "Just good enough"
1st Win: June 26, 2008 - Trackside Dirt Oval
Rest In Peace: Mom 44-07, J.Goetsch 80-09, S.Just 55-09
Anybody on this forum running at SoCal? Over the last 2 months we've been running Mini's on Tuesday night. Lot's of fun; have had between 5-8 drivers each week. Running silver can motors. Not overly fast but driving has been close and fun. SoCal is holding their Grand Prix Nov 5th, would love to have as large a showing as we can.
well i dug through my pile o stuff, and found an unopening package of AE shock downstops or limiters or whatever you call them, its riding pretty low now.
hopefully today or tomorrow ill get it painted and post some pics.
Losi Micro Baja
Losi XXXT
Kyosho RB5
Kyosho ZX5 for sale
I think too many o rings for suspension is not suggested, especially if you run in bumpy and dusty tracks. Why ? First of all, you reduce the volume of oil inside ( the plush feelling is gone ). Secondly, you need some droops to make the cooper stick to the ground and feeling stable during cornering. I suggest to use Tamiya shorter spring set OR simply remove the adjustable collar so the front and rear suspension could have some droops ( droop = the amount of shock collapse as soon as the tires touch the ground ).
