Old 10-26-2008, 08:27 PM   #7576
yamdali's Avatar
Send a message via Yahoo to yamdali
Default CA the sides
Originally Posted by Low_E View Post
We got the side-grip out of the front-ryres (to prevent griprol) by applying some CA-glue on teh side of the tyres, which made the sides harder and less grippy.
We just had to do this in the beginning because after some time, the CA-glue-coat weared off, but the front tyres settled themself and the car stayed balanced. All I ever had to do was apply a bit of 5 of 10 grams of lead in the back to prevent massive oversteering which made the car go 180 in corners.
Do you apply CA to both sides of the front tyres?
Pak Ya
yamdali is offline   Reply With Quote
Old 10-26-2008, 08:42 PM   #7577
minidriver's Avatar
and which insert do you use then in the front-S-grips?
I guess the duoble stuffing makes them harder and thus loosing some grip in the front to avoid griprolls.
Is this correct?
Fronts double stuff: inner layer: Tamiya 53295 (closed cell foam sedan insert) with about 3/16ths of an inch removed from the width (to make them about 24 mm wide), and 1.25 inches removed from their length. Contact cement the ends together. Over this place a blue tamiya 24 mm sedan shaped insert 53434, in which you have cut apart, removed about 1.25" from the length, and contact cement back together. Run on layer of black electricians tape around it (it isn't nice to have it come apart once you've glued up the tire). If you are using suzuki wheels, no mods needed. If you are using wheels that have a reinforcing rib running from side to side (such as the black graphite reinforced ones), cut a "v" into each rib, to form a channel for the shaped insert - if you don't do the cut you will end up with a tire that is too high in the center.
minidriver is offline   Reply With Quote
Old 10-27-2008, 05:57 PM   #7578
ioyasm's Avatar
Default tires
what i do is with a dremel take the outside wall off of tire were it is square and run a bead of ca just on the outside tread of tire and then wipe of excess and the car dosent roll in the corners we also slam our cars as low to the carpet as possible without scubbing .and they work great also use oneway bearings and just drive into the corners and go also just using m all the way around with stok hard and blue inserts in front and stock hard foams in the rear
ioyasm is offline   Reply With Quote
Old 10-28-2008, 05:18 AM   #7579
Core Creations's Avatar
Trader Rating: 91 (100%+)
Send a message via AIM to Core Creations
If anyone is looking for some wicked fast silver cans...I have about 6 or so for sale...drop me a PM
Core Creations paint thread
Mini Mafia Kansas Chapter - where the monster minis grow!
Core Creations is offline   Reply With Quote
Old 10-28-2008, 12:32 PM   #7580
R1wurks's Avatar
does the LRP QC3 have an advantage to use on a mini for a tcs setup?
thanks in advance
R1wurks is offline   Reply With Quote
Old 10-28-2008, 04:37 PM   #7581
Trader Rating: 76 (100%+)
Originally Posted by Barger View Post
guys...try Powers slicks
www.harrisrc.com
I use 32s and 36s...he also has premounts and posts anywhere in the world
Thanks Barger.
Team Powers 36's Mini pre-mounts now in stock along with tires,(36) rims and inserts
The rims have been changed from a five spoke to 8 spoke Available in white only.
Txs
Do you won't free Post on your items, PLEASE contact AUSTRALIA POST to confirm your eligibility and enter your code number here. Otherwise standard rates apply. Why don't people haggle or complain with o/s postage but always want local postage for free or moan like their left hand was cut-off, Come on guys Aus post do have set costs , it isn't the seller trying to rip you off.Items must be sold. All reasonable offers considered
addicted is offline   Reply With Quote
Old 10-28-2008, 06:38 PM   #7582
Drifting101's Avatar
thanks in advance
Over what??
::Mi4::17.5::::::M03R::HW 3000kv::::::T4::7.5::::::HB Cyclone D4::5.5::
"Why follow, when you can lead?"
Schumacher
Drifting101 is offline   Reply With Quote
Old 10-29-2008, 01:59 AM   #7583
R1wurks's Avatar
over all others.
Old 10-29-2008, 07:43 PM   #7584
Trader Rating: 28 (100%+)
Hi Guys,
Just putting together a new kit and the transmission is binding with the 2 halves together. I've tried loosening the screws but no luck. When one half is off it spins smoothly.
I remembered reading somewhere (possibly on rc-mini.net) about some plastic that can be sanded down if this occurs, but I can't for the life of me figure out where it is. I've built 2 kits before this one and didn't have this problem.
Any help much appreciated.
Cheers
Ashley
Ashley Cobb is offline   Reply With Quote
Old 10-29-2008, 08:57 PM   #7585
Figured it out - the bearings on the diff that supports the outdrive weren't seated properly. in one of the holes there was a plastic dag that a hobby knife trimmed out and it's fine now.
Cheers
Originally Posted by Ashley Cobb View Post
Hi Guys,
Cheers
Ashley
Old 10-30-2008, 04:42 AM   #7586
over all others.
It will work very well i think
Ashley-I have also had that problem with a chassis or two........other ways to get the bearing in better is gentle persuation (in other words a hammer) jk
Schumacher
Old 10-30-2008, 04:53 AM   #7587
I've used screwdrivers on bearings before, which they don't like (ie they explode and little bits go everywhere)
So what I did was I made a DIY bearing puller (TM)
Get a bolt with a small enough thread to fit through teh bearing, with the head of the bolt on the inside where the diff is, then you put a panel washer and nut on the outside (where the outdrive normally sits) and just gently tighten the nut till it seats properly.
No being rough involved
Old 10-31-2008, 04:06 AM   #7588
Any feedback on the Tamiya #53222 super slicks? I read somewhere that they were pretty OK. How do they compare with the Team Powers?
stocker is offline   Reply With Quote
Old 10-31-2008, 04:39 AM   #7589
tony gray's Avatar
Is BLEURGHHHH! a word?
Cos thats what they are.....I burned mine in the fireplace. True!
tony gray is offline   Reply With Quote
Old 10-31-2008, 06:06 AM   #7590
KDR
Default BFTR II
BFTR II, The Turkey Srikes Back. Sunday Nov. 9th
Today is the last day to pre-reg for this race. The mini class is filling up fast. We will be running hand out motors for all Mini's, F1's and Vintage Classes. Race flyer and rule sheets are attached.
You can pre-reg via paypal at
beach_lover91320@yahoo.com
or snail mail posted marked by today at
Steve B.
4950 North Street
Somis, CA 91320
Please PM me for any questions.
Steve
steveb@roadrunnersrc.com
http://roadrunnersrc.com
File Type: pdf Big Fat Turkey Race Rules II 10-15-08.pdf (22.0 KB, 54 views)
Steve B.
HB Team Driver*Sweep Racing Tires*Speed Passion Team Driver
hotbodiesonline.com
KDR is offline   Reply With Quote
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 05:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-02-2011 12:08 AM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 09:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 07:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 08:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
SEO by vBSEO 3.5.0
