Like Tree2Likes
Old 09-23-2008, 08:07 PM   #7276
tony gray's Avatar
Originally Posted by Kail View Post
Haha, we were racing on stock tyres with no inserts. Hence, the tyres became slicks by the half hour mark and they blew at the 1 hr mark. Haha... Isn't it interesting the kingpin got grinded ill they were gone? Haha
ZK, Tim told me what your car was like and now that I've seen it I'm amazed! Damn, that's cool....
tony gray is offline   Reply With Quote
Old 09-23-2008, 08:39 PM   #7277
Hyde's Avatar
Originally Posted by reenmachine View Post
Maybe if you post the exact same thing a few more times you'll get a different answer.
Your question was already definitively answered by an authority on the subject!
Lol don't be a smart one sir Lol just messin
Btw nice grammar.
Dayum ever since i bought a kawasaki sportsbike I've been lost when it comes to rc!!!!
Has anyone watched my m03r "unboxing" video on youtube? My screen name is rcpro17
also do m01's still exist? I've had one back in 01 but it got awayy. Do people still sell these still private party?
MyForum> www.uncovertruth.forumotion.com
Hyde is offline   Reply With Quote
Old 09-23-2008, 09:04 PM   #7278
Kail's Avatar
Haha yeap! Maybe you guys should 1 day try Rim only OPEN. Haha...
Kail is offline   Reply With Quote
Old 09-23-2008, 10:03 PM   #7279
monkeyracing's Avatar
LATC3: Here are a couple of items that you may find helpful, all lovingly typed out using proper grammar. (sort of)
These are general rules that I found can make a car a bit easier to drive, on most surfaces.
Tires: The rule of thumb is to have a little more grip on the front tires than the rears. I usually run type A slicks up front, and s grip radials at the rear. Another rule (that I don't really follow) is to have the tire inserts harder up front than in the rear tires. I have found that I can run hard inserts at all 4 corners without any problems. The difference in grip between front and rear is more critical.
Toe: Most will suggest having a very slight toe out in the front, with a little toe in at the rear, about 1.5 degrees is usual. I run almost neutral toe at the front wheels, and 1.5 in at the rear. I've found that too much toe out at the front wheels can make the car twitchy. The grippier tires up front will compensate for the lack of toe on turn in. The added bonus is that you get a little less drag having your front wheels straight.
Dampers: There are loads of opinions on what works and what makes a difference. The general school of thought is harder springs up front, with softer springs at the rear. Shock oil isn't terribly critical, but it can make a subtle difference in the way the car handles, especially at turn in. Again, stiffer at the front, softer at the rear.
Limiting travel in the dampers is probably more important than what weight of oil you use, however. A couple of O-rings inside, under the piston, and one outside, on the shock shaft can help a lot. The O-rings inside limit droop, and the O-ring outside, if your car is setup in typical fashion, will be just enough to keep your car from bottoming out. Hitting bottom on your chassis is an absolute no-no. If you bottom out, you lose traction and control.
In any case, these are things that I've found that have helped me. They may not be right, and I can't guarantee any of it will work for you. I know guys running totally stock minis that kick my butt on a weekly basis. Some of those guys are even running the stock kit tires. (show-offy bastards!) I suppose then that these tips just make the car a little easier to drive if you're as lame as I am at RC driving.
Jim
Stab it and steer.
monkeyracing is offline   Reply With Quote
Old 09-24-2008, 05:18 AM   #7280
Drifting101's Avatar
What dyno are you guys using and those red dot are those the ones that the guy in the US runs in?
Who is this man, and are those bananas loaded?
And is that a forest of Sport-Tuneds?
Click here to read about Tims latest trip to Japan, and also to check out our HUGE Sport-Tuned Dyno test....
Oh and lots of new additions to the Mini Fans area, and also some other new pics of our own cars in the Gallery.
::Mi4::17.5::::::M03R::HW 3000kv::::::T4::7.5::::::HB Cyclone D4::5.5::
"Why follow, when you can lead?"
Schumacher
Drifting101 is offline   Reply With Quote
Old 09-24-2008, 05:25 AM   #7281
rccardr's Avatar
The red dots to which they refer in their article are DEFINITELY not the ones that we sell.
Aside from a few limited runs for special customers (and you know who you are!), we use only Johnson 540J silver can cores- totally legal for TCS competition and beloved by racers all around the world.
I've never lost.
I've just been a little bit behind when time ran out...
RED DOT MOTORS- Fastest Titan 12T and silver can 540 motors in the known galaxy!
rccardr is offline   Reply With Quote
Old 09-24-2008, 03:07 PM   #7282
tony gray's Avatar
Robitronics Pro Master Dyno. Not that it matters anyway.
The readings should be taken only as a comparison between individual motors, not as absolute data. And taken as such, the readings provided are relevant.
Old 09-24-2008, 03:47 PM   #7283
xrayroooahhhh's Avatar
Default Ball Diffs.....
What ball diff's fit the m-03....m04m's....just a list would be great....and if anyone has a idea of which one/one's seem to be best!!!
Any help.....thanks,
Roy
-ROOH RACING-
www.donerite.net
xrayroooahhhh is offline   Reply With Quote
Old 09-24-2008, 03:51 PM   #7284
reenmachine's Avatar
Trader Rating: 26 (100%+)
Roy
There are two that I know of: Manta Ray and TA03. I have had equal success with both. The splines on the Manta Ray one can sometimes be a tad loose, but a bit of loctite applied during assembly fixes it nicely.
I have a new Manta Ray one (still in the package) in the for sale section right now if you're interested. $22 shipped.
FS: Tamiya 53070 OP70 Ball Diff fits Mini Cooper and others NIP
Pete Waydo
2010 Big Fat Turkey Race Mini Cooper AAA Main Champion
*** currently in stasis ***
reenmachine is offline   Reply With Quote
Old 09-24-2008, 03:56 PM   #7285
Heck Roy, you should just call me on that one. The one that's hanging on the rack in the mini section at PM...that's the one! I've got a couple of 'em and they work well.
Jim
Stab it and steer.
Old 09-24-2008, 04:38 PM   #7286
MD
MD's Avatar
Trader Rating: 105 (100%+)
xrayroooahhhh - 3Racing makes one also.
MD is offline   Reply With Quote
Old 09-24-2008, 04:49 PM   #7287
tony gray's Avatar
They sure do, or you could just grab 30 bucks and set it on fire.
Either way the result is the same - a WASTE OF MONEY..
Sorry to be a bit negative there, but the 3 Racing ball diff is quite possibly the poorest quality item for an M03 we've ever seen. They are complete junk. AND...you have to mill out part of the chassis to get it to fit!
Our choice is always the TA03 unit. Much lighter than the Manta-Ray one so it spins up quicker.
Old 09-24-2008, 04:56 PM   #7288
MD
MD's Avatar
tony gray - That's good to know. I almost bought one on Ebay. Thanks for the information.
Old 09-24-2008, 05:34 PM   #7289
Hyde's Avatar
I bought my 3racing ball diff on ebay for $9. its fully adjustible and i think it spools up quicker then the ta03 diff. And i own two ta03 cars and four ta03 ball diffs, i think there's a huge difference.
The milling part does suck since i didn't wana chop my chassis. BUT i could still use any other diff besides the 3racing diff.
Also tony my problem was half stearing alignment but still has a unstable feel to it.
Old 09-24-2008, 05:35 PM   #7290
Trader Rating: 28 (100%+)
Ashley Cobb is offline   Reply With Quote
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 05:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-02-2011 12:08 AM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 09:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 07:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 08:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
Currently Active Users Viewing This Thread: 5 (0 members and 5 guests)
