Like Tree104Likes
Old 08-24-2008, 01:13 AM   #7111
caltek1's Avatar
Trader Rating: 35 (100%+)
Default MO3L
tyreguy,
Not sure what surface you are running on, however for bitumen, concrete I use the following.
TRF front
internal spacer
3 hole piston
TRF short yellow spring
50 wt oil
TRF rear
internal spacer
3 hole piston
40 wt oil oil
I also run thick swaybars front and rear. Ride height of 3/4mm front and 6mm rear. If front is to low then take up to 5mm. I also run approx 0.5 to 1 degree toe out and use Ride 3030 front tyres with a green insert and Pit Shimtzu rears with soft foam insert. Spice 32's work on the rear as well with foam insert.
Everyone seems to have a different setup for their mini's.
A great place to start with setup assistance is www.rc-mini.net/
Hope this helps.
Regards
Calvin.
caltek1 is offline   Reply With Quote
Old 08-24-2008, 01:18 AM   #7112
Mad Mackem's Avatar
Hi Calvin,
Are you using standard TRF shocks or the Mini variety?
Mad Graphics
TOP Racing Photon
TOP Racing Sabre
TOP Racing Rebel F1
Mad Mackem is offline   Reply With Quote
Old 08-24-2008, 01:41 AM   #7113
caltek1's Avatar
G'day Jeff,
I tried using the Mini variety built as per instructions, however I found that there was no droop. So I went back to the normal length TRF shocks. I also found that the TRF shock collars unwind make the shocks unequal in length. These usually ended up with no pressure on the spring. I use the TRF shocks with the o ring on the shock retainer collar.
I build these to 56.5mm length front and rear. I also only change the springs on the rear for tuning. I normally run zero or one degree rear hubs. Although I have found the one degree rear hubs tweak very easily, if I have to run rear toe in I have been using the MO3R or Yeah racing 1.5's.
Hope that helps.
Calvin
Old 08-24-2008, 01:43 AM   #7114
Herkimer Jitney's Avatar
Originally Posted by tony gray View Post
Cancelled your subscription to the brush-of-the-month club?....
Click here to read our review on the new Hobbywing 540 brushless system.
Hint - Cash up your credit card first because you'll probably want one after reading this.
Dude just read that article and i am so gonna get one of those systems. I cant beleive how cheap they are.
Herkimer Jitney is offline   Reply With Quote
Old 08-24-2008, 01:52 AM   #7115
caltek1's Avatar
I have been running a BL system in my Mini for sometime now. You don't have to worry about cleaning or comms drops etc.
Things to note though.
1. You are better off using the teflon coated 20 tooth pinion or you will go through a few mini spur gears. The standard alloy pinion does not hold up for long.
2. Due to more torque you will place more stress on the drive components.
3. Ensure you check your universals regularly.
4. Car pulls from corners quicker.
5. Tyre wear increases, however that comes back to how hard you mash the trigger.
I am still using the same pair of rides on the front that I fitted to the car in Mar of this year. Only changed when I ran at Castlehill due to different grip conditions. I thoroughly recommend the 3030 older style Ride tyres, great wear and grip.
BTW
I still get beaten by quick Sport tuned motors.
Regards,
calvin.
Old 08-24-2008, 02:05 AM   #7116
edwintklee's Avatar
Trader Rating: 23 (96%+)
Originally Posted by monkeyracing View Post
The stock Tamiya ESC is actually pretty good for club racing the Minis, as long as everyone sticks with a spec driveline. If you get into a situation where people are running different motors or "tuned" (cheaters!) cans like red dots, then you may be at a slight disadvantage.
The Novak XRS is a great upgrade ESC for minis. It's affordable, very small/light, and does offer a slight upgrade from the Tamiya ESC.
Jim
hey jim, thanks for the feedback, well, i been reading about red dots, do you mind posting photo or info i an read on "red dots"....
I am a Red Star, Blue Star, Fans......
edwintklee is offline   Reply With Quote
Old 08-24-2008, 02:20 AM   #7117
32819toon's Avatar
Originally Posted by Core Creations View Post
M03-210mm M03M-225mm and M03L-239mm
Thanks Core Creations ! Which bodies are available for the M03L 239mm wheelbase car ? Also, what width is the car ??
Thanks,
32819toon
32819toon
VBC Wildfire D08, Yokomo BD7 RS, Schumacher Atom, Tamiya M03, M05 (outdoor Mini), M03RWD, MF01-X, BSR M-Rage, ABC Gambado, Associated TC4 (outdoor car).
32819toon is offline   Reply With Quote
Old 08-24-2008, 02:26 AM   #7118
caltek1's Avatar
BMW Mini body.
There are others that are used on theMO4L, however these are not legal to run in Mini here in Aust.
See link. http://www.rc-mini.net/MiniWeb_Onlin...D7756B281E1090
Tamiya BMW M Roadster (240)
Tamiya VW (Classic) Beetle (240)
Tamiya Porsche Boxster (240)
Tamiya Mercedes SLK (240)
Tamiya BMW Mini (240)
Regards,
Calvin
Old 08-24-2008, 04:14 AM   #7119
32819toon's Avatar
Originally Posted by caltek1 View Post
BMW Mini body.
Regards,
Calvin
Thanks Calvin
32819toon
Old 08-24-2008, 04:34 AM   #7120
rcmarek's Avatar
Calvin, just out of interest, why are the other bodies deemed illegal? I assume there's no advantage running SLK body compared to Mini?
rcmarek is offline   Reply With Quote
Old 08-24-2008, 04:37 AM   #7121
FOXY923's Avatar
TCS rules state you have to run a fwd body on a fwd car. Same with rwd. Not sure if that is what Calvin is referring to?
Paris Junction Hobbies ~ RROL.ca ~ Lou's Speedway ~ SCAR
XRAY X10 Link ~ CVTA Sakura Zero S ~ XRAY X10 Custom Oval ~ Caster Fusion F18
RACE 4FUN
FOXY923 is offline   Reply With Quote
Old 08-24-2008, 05:22 AM   #7122
Trader Rating: 131 (100%+)
Thanks for the help whit the whole set up. The shocks I have are threaded and came with 4 white springs and 2 redish/orange springs. I will be racing on asphalt. That site you sugested is GREAT too.
tyreguy,
TRF front
internal spacer
3 hole piston
50 wt oil
TRF rear
internal spacer
3 hole piston
40 wt oil oil
Hope this helps.
Regards
Calvin.
tyreguy is offline   Reply With Quote
Old 08-24-2008, 07:19 AM   #7123
MD
MD's Avatar
Trader Rating: 111 (100%+)
A good place to start for the M03L is on the Tamiya America web site. At the top of the page you will see "articles." Click on that and then on the articles index you will see Radio Control Tech Tips. Click on that and near the bottom of the list is an article entitled "BMW Mini Building and Setup Guiide by David Beale." It's an older article but it's a good starting point. Some things have changed since then, but I still think it gives you some good basics.
MD is offline   Reply With Quote
Old 08-24-2008, 07:48 AM   #7124
just book marked it... thanks!
Old 08-24-2008, 01:27 PM   #7125
monkeyracing's Avatar
To be honest, I really don't know that much about them, only what I've read here.
To me it sounds like a cheater motor. There is only so much you can get out of these cans and stay strictly within the rules (guys, please don't get technical, I'm also referring to the "spirit" of the rules) and these seems to be pushing the envelope.
Just because a tweak isn't spotted during tech, doesn't mean that it's altogether legal or moral.
Jim
Stab it and steer.
monkeyracing is offline   Reply With Quote
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 04:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-01-2011 11:08 PM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 08:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 06:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 07:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
