Like Tree200Likes
Old 07-23-2008, 10:49 PM   #6931
Hyde's Avatar
well that's kinda true but not a big diffrence tho. because once i put my electronics WAYY in the front i have a small reciever so i put it on the front shock tower and the esc on the plastic/chassis servo mount and it kinda has a fishtail/drift then a spin out.
but i put everything in the middle then i got an ok feeling and everything was ok then i put it in the rear chassis and i got a WAY better little mini BUT seem to understear.
MyForum> www.uncovertruth.forumotion.com
Hyde is offline   Reply With Quote
Old 07-24-2008, 05:36 AM   #6932
nitro psyco's Avatar
Trader Rating: 30 (94%+)
Default Tamiya tires
i recently purchase a tamiya M03 and raced it twice with the tamiya slicks 600 and after 2 races i now have to purchase more tires . Are there any other tire & foam options on the market.
TEAM COPPERHEAD R/C RACING-MSRA-RACING.COM
TA05 T/C LRP SPHERE HACKER 17.5&13.5
TA05 VINTAGE NOVAK HAVOC 21.5
SLASH BOX STOCK-
NITRO TC3 ROSSI .12
nitro psyco is offline   Reply With Quote
Old 07-24-2008, 06:40 AM   #6933
Core Creations's Avatar
Trader Rating: 95 (100%+)
Send a message via AIM to Core Creations
The big difference on where the electronics are located is more important on carpet. You want it all as low as possible. On asphalt you want the car to lean some anyways and it's not really a big deal. I reccomend everyone I talk to to get the electronics inside the rear of the chassis not only for the CG but becuase it looks much cleaner and not hack.
Core Creations paint thread
Mini Mafia Kansas Chapter - where the monster minis grow!
Core Creations is offline   Reply With Quote
Old 07-24-2008, 06:48 AM   #6934
edwintklee's Avatar
Trader Rating: 23 (96%+)
Originally Posted by LATC3 View Post
well then ill try single foams that came with the xpats!
where do you mount your electronics? I've mounted mine in the front and always had good feel to the car!
i mount my electronics in the rear part, do move the weight to the rear, more traction?? well basicallly my local track guys are running on 1/10 gp foam 40 or 42, the have good grip, but look odd, big wheels on small cars? also they are running 23t bl , i am only using sport tune with 20t....basicaly the will ctach me at straight, but i try to lose them in the corners, because i am using stock tamiya tyre with out insert, not always i got away....hope to do better with new x pat.....
an1 use those cheap Yeah racing tyre from hk....its about 9 usd
what the cheapest mini tyre in the market?? but must be able to handle...
as i am using mo3, so my current knuckle its from tt01, i am converting to use m03m knuckle, looks harder....i think.....
many my local track that mo3r its better handling? what do you guys think? but they do have different design in swing arm??
I am a Red Star, Blue Star, Fans......
edwintklee is offline   Reply With Quote
Old 07-24-2008, 07:58 AM   #6935
Trader Rating: 28 (100%+)
On asphalt its just as critical.Most of the fastest guys in the TCS north American finals over the last couple years have mounted their electronics as low as possible.With Lipo, now its even more critical.Broken record here.Hell what do I know.
Team I'm Over It
racenut123 is offline   Reply With Quote
Old 07-24-2008, 10:03 AM   #6936
From what I've heard, quite a bit. Echo the advise although I mount my receiver side saddle so that the wt in the rear of the chassis can be adjusted w/out removing it each time
Granpa is offline   Reply With Quote
Old 07-24-2008, 10:25 AM   #6937
Like I said, I recommend all mini racers to put the electronics inside the chassis. I evenr route my wires all internally and keep the CG as low as possible. But I have also seen some VERY quick, well handling cars that didn't do that so...
Old 07-24-2008, 10:36 AM   #6938
reenmachine's Avatar
Trader Rating: 26 (100%+)
I keep my electronics mounted on top. The Futaba R603FF receiver and Futaba MC230CR ESC are very light, so I don't think it makes that much of a difference. I've also hard-wired the motor so there's not the weight of a bunch of extra wire and the bullet connectors. That's not much, but it all counts.
Pete Waydo
2010 Big Fat Turkey Race Mini Cooper AAA Main Champion
*** currently in stasis ***
reenmachine is offline   Reply With Quote
Old 07-24-2008, 10:56 AM   #6939
Hyde's Avatar
any touring car will tire will fit. you just have to cut half inch space/gap in the tire and wrap around the mini rim.
I HATE FOAMS ON MINI. if there the same size and they look scale then YES! huge tires on a mini sux.
can you picture 24'z on a rover mini cooper?
i use x patterns in the front. i heard that very hard or double works best but it didn't do anything. I'm going to make them midium foams or semi inflaided tire!
ill see what happens. but whever i switch from touring car to mini and go back to mini it seems like minis are more like toys compare to minis! but i love the mini and i can't wait untill tamiya makes a carbon convertion kit chassis for it! wouldn't that be cool?
Old 07-24-2008, 01:56 PM   #6940
I know Brumley was mounting stuff on the side too.Not a bad idea if the gear is secure.
Team I'm Over It
Old 07-24-2008, 03:05 PM   #6941
MD
MD's Avatar
Trader Rating: 118 (100%+)
I know some speed controls and receivers are just too big to mount inside the chassis, but I have seen racers take the guts of an inexpensive esc,, take the case off, and shrink wrap it to make it smaller to fit an 1/18 scale touring car. I suppose you could do that for a mini. I haven't done it myself.
MD is offline   Reply With Quote
Old 07-24-2008, 04:00 PM   #6942
tony gray's Avatar
The bottom line on mounting electronics is this...
The THEORY says that mounting everything inside the chassis will lower the C of G and therefore make the car handle better. And we ALL used to do just that.
In reality it makes so little difference as to be undetectable - on carpet and asphalt. We've run cars back to back with electronics mounted outside and inside. And I'd be lying if I said we could tell.
So...most of the rc-mini crew run their receivers inside the chassis, but leave the ESC's on top where they're easy to get to (and it helps keep them cool).
tony gray is offline   Reply With Quote
Old 07-24-2008, 04:20 PM   #6943
MD
MD's Avatar
Leaving the esc out where it's easy to get to makes a lot of sense.
Old 07-24-2008, 04:20 PM   #6944
Default balance
balance is probably important. depending on rest of car setup, mounting receiver on top deck might cause oversteer spinout. putting in rear chassis might turn a bad car to a great handling car... again depending on how it is setup and track condition...
the position of the 25gram transponder also makes a big difference.
thanks.
rccartips is offline   Reply With Quote
Old 07-24-2008, 04:36 PM   #6945
Hyde's Avatar
DO NOT take your esc or receiver out the the case! minis are ment for injoyment and low cost fun! why would you wreck your expensive electronics! mount outside the rear chassis on the side. I've done it and its good. also the motor has wieght on the left side of the car try mounting your stuff on the rightside and that's good for the minis that go left !
i know good spots where to mount them i just wanted to know where you guys mounted them. I've had some problems but there cured.
now i need a car that will NOT understear and something that has good stearing but NO mc'fishlail tail sandwitches! lol
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 04:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-01-2011 11:08 PM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 08:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 06:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 07:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
