Like Tree198Likes
Old 07-16-2008, 06:44 AM   #6886
Trader Rating: 76 (100%+)
Originally Posted by slammin View Post
Will Harris rc ship to the US?
Yes we do
Do you won't free Post on your items, PLEASE contact AUSTRALIA POST to confirm your eligibility and enter your code number here. Otherwise standard rates apply. Why don't people haggle or complain with o/s postage but always want local postage for free or moan like their left hand was cut-off, Come on guys Aus post do have set costs , it isn't the seller trying to rip you off.Items must be sold. All reasonable offers considered
addicted is offline   Reply With Quote
Old 07-16-2008, 06:30 PM   #6887
GeekSpeed's Avatar
Hey all. I am looking for a little bit of help on the setup for my M04L. I am having some trouble deciding on a couple of parameters, however. The track I run on is smooth, treated asphalt with good grip. Here is what I have come up with so far:
Front:
Camber - 2 degrees neg.
Toe - +1.5
Spring - Firm
Shock Oil - ?
Tire Type - ?
Insert - Firm
Rear:
Toe - 2 degrees
Spring - Medium
Shock Oil - ?
Tire Type - ?
Insert - Medium
Differential - Tight (ball diff, not locked)
As you can see, the tire choice and shock oil are where I am having the most trouble. For the tires, I am thinking I want a medium compound tire on the front and a soft compound tire on the rear (or perhaps hard in front, medium on rear), but I am not sure which brand/model of tire to go with. I have the stock M and S grips that came with the car, but I was not terribly impressed with them. I have heard someone mention M grips on the front and M slicks on the rear, but I am not sure. For the shock oil, I am thinking of going with something like 40 wt. on all 4 corners, but, again, I am not sure. The brand of the shocks is another question. I basically have 4 choices. There are the Tamiya CVA shocks, the Tamiya M-chassis aluminum shocks (p/n 54000), the Yeah Racing aluminum shocks, and the 3Racing aluminum shocks. The Yeah Racing and 3Racing units look good because of the price, but the Tamiya aluminums look good because they are TCS legal (not a big issue) and I know they will fit perfectly.
Can anyone offer up some opinions to help point me in the right direction? Thanks!
GeekSpeed is offline   Reply With Quote
Old 07-16-2008, 11:02 PM   #6888
Hyde's Avatar
these little shits are still the most scale rc's sold these days =]
MyForum> www.uncovertruth.forumotion.com
Hyde is offline   Reply With Quote
Old 07-17-2008, 06:00 PM   #6889
Xtant3150c's Avatar
Geek I used 3Racing shocks on my M04M and liked them alot. I ran 35wt. oil in mine with red springs rear and blue front.
I used RP36r's on my M04M. Was an parking lot track sprayed with soda/water mix so traction was pretty good.
Have not tried any other tires that are out now though?
space for rent
Xtant3150c is offline   Reply With Quote
Old 07-17-2008, 11:27 PM   #6890
GeekSpeed's Avatar
Thanks Xtant. I wasn't sure if I should run the same tires on both ends of the car. I think I will go ahead and try that and use the shock settings to try and get as close to neutral handling as possible.
Old 07-19-2008, 01:16 AM   #6891
tony gray's Avatar
For all of you who would like to see, we've just put online some footage taken today at the new Indoor carpet track at Radical R/C in Campbellfield, Melbourne, Australia
It's a brilliant little track for Minis (a bit of a squeeze for Touring Cars) and lots of fun can be had I can tell you.
Oh and despite lots and lots of carnage, very little was actually broken...
Check it out here
tony gray is offline   Reply With Quote
Old 07-19-2008, 01:27 AM   #6892
cannon's Avatar
Trader Rating: 35 (100%+)
Mmmmm Tony ,,, looks like a good little track for the 4WD Mini's
www.feralbatteries.com ........... new website
cannon is offline   Reply With Quote
Old 07-19-2008, 01:39 AM   #6893
tony gray's Avatar
Yes and No.... Good to drive them around there for sure (my RC18R was LOTS of fun around there) but the track is very unforgiving.
M03's are tough, but most of the 4WD Minis aren't quite so bulletproof...
Old 07-19-2008, 01:51 AM   #6894
cannon's Avatar
We are just about to revive the 4WF Mini class at the indoor Windsor track .... looking to run the class with Lipo and 17.5 BL motors
Old 07-19-2008, 06:05 AM   #6895
Registered User
UltegraSTI's Avatar
Trader Rating: 20 (100%+)
you guys wanna good cooper race. look no further than last wk's TCS barn-burner!!!!
http://youtube.com/watch?v=8uYfE7_fmtQ
R
UltegraSTI is offline   Reply With Quote
Old 07-19-2008, 07:17 AM   #6896
FOXY923's Avatar
Originally Posted by FOXY923 View Post
Anybody running the Orion 2400 lipo in their mini?
Nobody? Well, I am but just wanted to know if anybody else was to compare setups.
Paris Junction Hobbies ~ RROL.ca ~ Lou's Speedway ~ SCAR
XRAY X10 Link ~ CVTA Sakura Zero S ~ XRAY X10 Custom Oval ~ Caster Fusion F18
RACE 4FUN
FOXY923 is offline   Reply With Quote
Old 07-19-2008, 08:47 AM   #6897
Juanchoyo's Avatar
Default Carpet racing...
Hi guys after seeing the vid of Radical R/C track I'd like to know about the how-to of building a carpet track, It would be made for Minis obviously with silver cans and maybe TC w/ 10.5 ???? What do u guys recommend ? Measurements, and the most important is it a specia lcarpet type how's it's name???
FoxRC Hobby Club
http://foxrc.foroactivo.net/
"Mas que un hobby, un estilo de vida. Algo que corre en los circuitos de mis venas"
.....ChOoJuAaAnNnn, Sebastian, Juancho... como quieran XD.... o Sebastian Oviedooo...
Juanchoyo is offline   Reply With Quote
Old 07-19-2008, 03:04 PM   #6898
tony gray's Avatar
No idea of the measurements, but it's not very big, really if you were going to build a track you'd make it bigger than that anyway. All they did was just use all the room that they had available.
The carpet is called OZITE and its an industrial carpet. Its expensive though.
All they did was just stretch it out, then glue it down. The track markings are orange PVC pipe, held down with saddle clamps.
It's too small for Touring Cars, even one is a handful. But our Minis were fine there - Black Cans as usual, but we did try Silver Cans and the lap times were the same..
Old 07-19-2008, 09:44 PM   #6899
theDover's Avatar
R
That was one hell of a finish!
TEAM ULTRALINE / RickyRacerLidz
www.ultralinehobbies.com
Ultraline Hobbies RC Raceway @ fb
theDover is offline   Reply With Quote
Old 07-19-2008, 10:00 PM   #6900
Hyde's Avatar
aluminum shock towers braces were the most pointless but "lloookk" cool!
how's everyones minis going?
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 04:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-01-2011 11:08 PM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 08:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 06:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 07:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
