Like Tree100Likes
Old 08-12-2005, 02:16 PM   #646
minidriver's Avatar
slow4dr:
You can use a 17 tooth pinion in with the motor mounted in the 16 hole, 19 in the 18 hole and 21 in the 20 hole. The gear mesh is a bit tight, but it will work, as the gear slop of the "correct" size pinion is a bit excessive.
The Tamiya stock pinion gears wear fairly quickly. You can tell they are too worn when the gearbox starts making excessive noise, and examination of the pinion will find that the gear teeth become very sharp pointed. To avoid this, use the Tamiya optional pinion gears that are hardened alum - they hold up MUCH better than the stock (2 to a package) pinions. Tamiya still makes the 20T in the hardened version, and used to make the 19T as well (now discontinued, but still some around in shops or overseas). The tooth profile is a bit different on the hardenened gears, such that the 19 tooth will fit easily in the 18 tooth motor mount hole.
minidriver is offline   Reply With Quote
Old 08-12-2005, 02:50 PM   #647
RED-LINE M03's Avatar
Trader Rating: 127 (100%+)
Default 21 tooth pinion
Take a drill and a drill bit (5\32) and drill out your moter mount screw holes this will let you install a 21 tooth pinion and also get it to mesh with the spur gear. You will need two small washer's for the moter mount screws to hold it in place. I run a Trinity monster moter with a 21 tooth pinion and a TAO3 ball diff and this car is so fast and also handles great to in the tight stuff.
RED - LINE MO3
Originally Posted by Slow4dr
I guess three questions was a few too many. I'll withdraw those and ask one; How do you fit something other than a 16/18/20 tooth pinion on an M03?
RED-LINE M03 is offline   Reply With Quote
Old 08-12-2005, 03:53 PM   #648
Good stuff guys... thanks. Sounds like a 20 tooth might be right on for my Epic ROAR stock motor.
Going back a few posts, anyone try the Robinson pinions?
Slow4dr is offline   Reply With Quote
Old 08-12-2005, 08:31 PM   #649
Wicked-Wayz's Avatar
Trader Rating: 19 (100%+)
Send a message via ICQ to Wicked-Wayz Send a message via AIM to Wicked-Wayz Send a message via MSN to Wicked-Wayz Send a message via Yahoo to Wicked-Wayz
Just to let you know any drilling or cutting of your chassis. This will make it illegal to run in the tamiya championship series. Also your pinion will need to remain tamiya brand. This is only if you plan on running in that race at all.
Peace Aaron(W-W)
Schacht Design Works Trackside Hobbies Dirtheaven CRC Hobbies MidWest Tri-Clone RC Scoring Pro LiveRc.com 92 Zero Designs
Wicked-Wayz is offline   Reply With Quote
Old 08-13-2005, 12:19 AM   #650
NOZ69's Avatar
Been busy during a 5 week break from racing (family commitments), totally rebuilt my mini with new shocks,tyres,rims,locked the diff (shoe goo) & even gave the chassis a coat of paint...YEAH i know it`s not going to last..BUT it will look "BLING BLING" till the first race anyway..
Cheers
Tamiya mini cooper-new-shocks.jpg   Tamiya mini cooper-new-shocks-back-.jpg   Tamiya mini cooper-new-painted-chassis.jpg
FT TC4, LRP TC Sphere, LRP X-11 13.5
SC10 4x4
M03M Suzuki Swift
Power by Feral
Sanwa MX-3 FHSS
NOZ69 is offline   Reply With Quote
Old 08-13-2005, 01:07 AM   #651
moot's Avatar
Cheers
your a homo!
pick you up at 7am tomorrow
moot is offline   Reply With Quote
Old 08-13-2005, 04:44 AM   #652
Cheers
Looks really cool except your right it won't last. Would be cool to be able to get the chassis in different colors.
Peace Aaron(W-W)
Old 08-13-2005, 04:46 AM   #653
Default one way diff
Has anybody tried taking the balls out of a TAO3 diff and locked it down to make a spool?
How did it work compared to the ball diff?
Old 08-13-2005, 02:43 PM   #654
killingtime I see what you mean with the short cvs shock and springs saw then on pushers car that thing was almost scraping the ground.
sportracer is offline   Reply With Quote
Old 08-13-2005, 02:52 PM   #655
NOZ69's Avatar
Originally Posted by moot
your a homo!
YEAH flogged you so much that you SOLD your mini
Cheers
SC10 4x4
M03M Suzuki Swift
Power by Feral
Sanwa MX-3 FHSS
Old 08-13-2005, 06:33 PM   #656
Sorry to whore up the thread again... anyone know the internal gear ratio of the M03? Trying to calculate rollout with these HPI X-Patterns. They are way small.
Old 08-17-2005, 01:44 AM   #657
highasakite99's Avatar
Is all up weight an issue in overall performance for my MO3, yes or no?
highasakite99 is offline   Reply With Quote
Old 08-17-2005, 05:55 AM   #658
Nova F1 Racer's Avatar
R/C Tech Charter Subscriber
From the Tamiya website....
http://www.tamiyausa.com/product/ite...oduct-id=58295
The reliable, user friendly, and fun M-03L chassis has been paired with an accurately recreated new BMW Mini Cooper Body. The M-03L chassis features a front mid-ship mounted motor and front mounted battery, to put more weight on front drive wheels. Requires a 2-channel radio and 7.2V battery.
Specifications
Chassis Type: M-03L
Scale: 1/10
Length: 13.86 inches (352mm)
Width: 6.61 inches (168mm)
Wheelbase: 9.41 inches (239mm)
Front Tread: 5.43 inches (138mm)
Rear Tread: 5.43 inches (138mm)
Weight: 1.94 lbs. (878g)
Chassis: ABS Monocoque
Suspension: 4 wheel independent
Damper Type: Plastic coil over friction
Drive Train: Sealed gearbox
Engine: Electric 540
Gear Ratio: 5.8:1
Differential Type: Bevel Gear
Wheels & Tires: 5-spoke / Radial
Body Type: Clear/Polycarbonate
This is DICK!!! And you're NOT!
RC Tech member #11
Aussie Rules Footy, Brisbane LIONS!!
[url]http://www.pitter-pat.com/[/url] for pet care needs in Northern Virginia
Nova F1 Racer is offline   Reply With Quote
Old 08-17-2005, 06:44 AM   #659
sosidge's Avatar
Originally Posted by Nova F1 Racer
Gear Ratio: 5.8:1
Although this isn't the internal ratio, it can be used as a basis for calculating a gearing constant with the standard spur.
Multiply 5.8 by the standard pinion, then divide that number by whatever pinion you want to use to get the ratio.
Old 08-17-2005, 10:59 PM   #660
NOZ69's Avatar
Weight is an issue with all race cars...the less weight the better..
But with the Mini you are limited to what you can shed.Best to get everything low as possible to lower the centre of gravity,which will reduce the chances of traction rolls,which is a BIG prob with the Mini.
Try & get the ride height about 3mm front & about 5mm rear,which is a good starting point.
Cheers
SC10 4x4
M03M Suzuki Swift
Power by Feral
Sanwa MX-3 FHSS
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 04:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-01-2011 11:08 PM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 08:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 06:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 07:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
Currently Active Users Viewing This Thread: 7 (0 members and 7 guests)
