Like Tree173Likes
Old 04-04-2008, 03:12 AM   #6526
tony gray's Avatar
One word - NORMAL.
All the Type A 60D's do it. And there's no real way around it. Raising the ride height helps, but then the car doesn't work...
Putting the moulded insert on the Outside (next to the tread) helps a little with a double stuffed set, but the bottom line is you gotta live with this sort of wear on Type A 60D's.
Getting 6 heats and 2 finals out of a set of fronts is actually pretty good!
tony gray is offline   Reply With Quote
Old 04-04-2008, 03:38 AM   #6527
Teehomo's Avatar
Trader Rating: 24 (100%+)
Thanks Tony. Coming from a touring car background I though I was doing something wrong. Anyway, is there a better tyre/insert/wheel combo available? I understand there has been a fair bit of change in this area lately with changes in compund and some manufacturers dropping right out.
Also, thanks for your efforts on the mini website. A truly helpful resource.
Teehomo is offline   Reply With Quote
Old 04-04-2008, 05:16 AM   #6528
rccardr's Avatar
Yep, Tony's right- that's a pretty normal wear pattern for Type A's, especially with the higher speeds on asphalt attained with a sport tuned motor. My guess is that your track also has a fairly long main straight with a left turn/sweeper at the end of it leading into the infield- that puts a lot of strain on the inside of the tire. You can swap the fronts left to right after each heat (although some drivers swear that the tires wear-in in one direction, but that's a whole other discussion) and that will extend their death, but at the end of the day they're just gonna wear out.
I've never lost.
I've just been a little bit behind when time ran out...
RED DOT MOTORS- Fastest Titan 12T and silver can 540 motors in the known galaxy!
rccardr is offline   Reply With Quote
Old 04-04-2008, 05:30 AM   #6529
todd8603's Avatar
Default Shock help
Help a little bit fellas,
Built my shocks(mini platics ones) the other night for my mini, VERY careful to assemble them with the 6mm spacers, install on the car check ride height and got it to 5mm. Checked uptravel and seemed too much 3 front and 2.5 rear. I was able to space the fronts to limit uptravel to just 1mm but rear spacing did not allow retainer on the shock. Had to install the spring then screw on end and retainer together. Is it possible that a car that turns so much has to have that much rear uptravel?
Racing Saturday and thinking I might be in for a quick shock rebuild to changes this but what do you mini gurus think?
todd8603 is offline   Reply With Quote
Old 04-04-2008, 08:46 AM   #6530
Turbonium's Avatar
Trader Rating: 27 (100%+)
Send a message via Yahoo to Turbonium
i dunno... my double stuffed As were ran for the entire 2006 TCS Memphis and the Beat the Heat race the same year, and still dont show any signs of the Death Groove yet. ill start with them this year as well... bur i do have a new set, just in case!
Wes
Team Novak
Turbonium is offline   Reply With Quote
Old 04-04-2008, 09:09 AM   #6531
rccardr's Avatar
Memphis and Laurel are different animals. Both are very easy on tires. Either that or you're just slow
Plus, we also run silver cans and I think he's running black cans = higher speed and more scrub.
I've never lost.
Old 04-04-2008, 09:53 AM   #6532
Turbonium's Avatar
tis true... i have been known to be slow at times! mainly when i race. whats the age limit to fit into the "Old Guys Rule" club? i may be there!
i forgot about the black can deal... im sure that would wear more.
Wes
Team Novak
Old 04-04-2008, 02:30 PM   #6533
Teehomo's Avatar
... My guess is that your track also has a fairly long main straight with a left turn/sweeper at the end of it leading into the infield- that puts a lot of strain on the inside of the tire. .....
Rccardr - you picked it like a nose. Long front straight (for a mini) where we hit top speed before half way, with a high speed left sweeper at the end. Looks like I'll just have to stock up on spare sets.
Thanks for ther help guys.
Old 04-04-2008, 03:58 PM   #6534
Scottrik's Avatar
Trader Rating: 244 (100%+)
Hey all,
I picked up a hardcase lipo pack that I'd like to run in at least one of my Mini's. Those of you who've done this with something other than the 3200 Orion know that the corners of the case interfere with the battery hole through the chassis. I know it's not TCS-legal, but what's the best way to relieve the battery corners into the battery hole in the chassis? If it was just either side of the chassis it would be easy-peazy, but the battery hole is really an oblong tube so as far as I can tell I'll have to notch both sides of that tube for it's entire width.
Thanks,
Scottrik
Congressmen should wear uniforms like NASCAR drivers so we can identify their corporate sponsors.
THE REVOLUTION WILL NOT BE TELEVISED -Gil Scott-Heron (1949-2011)
Scottrik is offline   Reply With Quote
Old 04-04-2008, 07:18 PM   #6535
jas
jas's Avatar
Default Tires for street running
Hi all,
What will be the good tires for general street running? I think the Spice, Ride, etc. are just too expensive if not for racing on a track, unless they can out last the inexpensive ones, then their cost can be justified.
TIA.
jas is offline   Reply With Quote
Old 04-04-2008, 08:07 PM   #6536
tony gray's Avatar
You're in HK? Then that's an easy question.
For $4.00pr you cant beat the Xpress tires (here) for bashing... Or the 3 racing equivalent which are $6.00....
Old 04-05-2008, 10:20 PM   #6537
jas
jas's Avatar
Thanks, Tony.
I don't know about the Xpress, but I've seen and touched the 3Racing, feels extremely hard... . May be that's why it's good for street use?
Old 04-06-2008, 09:06 AM   #6538
todd8603's Avatar
Default Anybody know?
This setup worked well on carpet with silver can.
Old 04-07-2008, 03:25 PM   #6539
Originally Posted by TryHard View Post
Well, had the frist run out with my Mini and it's exige this weekend. What can I say, it was excellent, car ran flawlessly all day. Only issues was when I bolted on brand new S-grips, (rather than the worn M's) way too much steering! Think I need to go to 6mm of shims in the rear shocks when running the S's. Still motor and battery performed faultlessly, and was really suprised with the level of brakes the car has
Did a bit of an endurance run at one point, and with a Orion 3200 LiPo, was at 20mins runtime before I decided to pull the car off, rather than risk the pack (even with a LiPo cutoff enabled on the speedy). Makes running the car easy, as just need to top up the pack for each run.
Interestingly enough, the motor was barely even warm, so really happy with it. Now just to get the BL2 motor, and away we go.
Oh, also picked up a foam bumper (by Square, here) for the mini too, works really well, and helps protect the shell wonderfully
Cheers
Ed
I see you are running 60D's up front, what are you running in the rear?
Also are you guys gluing the rubber to the rims?
Spoook is offline   Reply With Quote
Old 04-07-2008, 03:30 PM   #6540
TryHard's Avatar
I was running M-grip 60D's in the front, double stuffed, and the same in the rear, but only with a medium foam. I tried some S-Grips all round for the last run... way too much steering, so need to limit the rear droop more I think.
And yes, all my tyres are glued to the rims.
HiH
Ed
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 04:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-01-2011 11:08 PM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 08:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 06:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 07:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
Currently Active Users Viewing This Thread: 7 (1 members and 6 guests)
Blackgold
