Like Tree39Likes
Old 04-02-2008, 01:29 AM   #6511
tony gray's Avatar
So....exactly how much is the difference in weight between a 'normal' Mini Cooper shell, and the special new 'lightweight' one?
Go here to find out.
tony gray is offline   Reply With Quote
Old 04-02-2008, 02:39 AM   #6512
Sp Racer's Avatar
after reading all of Tim K spilling his guts out and letting out his secrets, it occurred to me he forgot ( or rather De Fina forgot) the little one about checking the magnetism of the motor with a TV set, a ruler and a permanent marker...
Also, I see no mention of the "Fanta" run-in method.....
10 yrs on RC tech ! wow....
Sp Racer is offline   Reply With Quote
Old 04-02-2008, 03:28 AM   #6513
abailey21's Avatar
Trader Rating: 36 (100%+)
Ok, so in my infinite wisdom I wanted to see how fast i could get my M03 and put a 6.5 brushless in it with LiPo (It went fast)
I cant seem to find the part numbers for the transmission gears so they can be replaced, I literally melted all 3 gears. So I'm looking for the spur, diff and center gears if anyone could help.
I tried the tamiya website and trying to download a manual or exploded view is a joke, and the mini site did have the part numbers that I could find last night????
K.C.C.O.
abailey21 is offline   Reply With Quote
Old 04-02-2008, 05:01 AM   #6514
caltek1's Avatar
Trader Rating: 33 (100%+)
adam,
The MO3 G PARTS (GEAR) set is Tamiya PNo 50794 or SP-794. Your mini was darn quick then. Should tell dragon7, just how fast.
Later
Calvin
caltek1 is offline   Reply With Quote
Old 04-02-2008, 05:41 AM   #6515
Something tells me dragon7 will think his is faster...
One good thing about D7, he'd doesn't lack self-confidence. I haven't seen him on here in a day or 2. Likely out smoking some-body (or some-thing).
eric7 is offline   Reply With Quote
Old 04-02-2008, 06:08 AM   #6516
abailey21's Avatar
His is most likely faster, but I was a good 47-53mph until the "meltdown"
Thanks so much fro the part numbers guys
K.C.C.O.
Old 04-03-2008, 01:30 AM   #6517
tony gray's Avatar
Originally Posted by Sp Racer View Post
after reading all of Tim K spilling his guts out and letting out his secrets, it occurred to me he forgot (or rather De Fina forgot) the little one about checking the magnetism of the motor with a TV set, a ruler and a permanent marker...
Quiet Lue, you're letting the secrets out that we're releasing next year!
p.s. We tried the Mentos with the Fanta and it didnt work.
Old 04-03-2008, 06:59 AM   #6518
bmr
Trader Rating: 27 (100%+)
Originally Posted by over gear View Post
anybody know where can i buy Spice inserts? i've tried ChampRC and RCMart... no luck
These guys have the Ride inserts is that helps you any.
http://rc-mushroom.com/index.php?cPa...a&filter_id=76
Great service from RC Mushroom.
bmr is offline   Reply With Quote
Old 04-03-2008, 07:52 AM   #6519
rcarmchl's Avatar
Trader Rating: 15 (100%+)
are the edges of these inserts rounded?
Blizzard Concepts ~Big-Dog Graphics
Cyclone ~ Orion ~ LRP Sphere ~ S9550
M03 ~ Orion ~ LRP QC3 ~ S9550
RC18R ~ Castle Creations ~ Hi-tec
Slash ~ 9550 ~ SMC Power
8ight-T~9550~V-Spec
rcarmchl is offline   Reply With Quote
Old 04-03-2008, 08:55 AM   #6520
Try RC Market instead of RCMart.
Granpa is offline   Reply With Quote
Old 04-03-2008, 04:18 PM   #6521
Mad Mackem's Avatar
One of the new BMW shells. I like them a lot. Have to get one for myself. This one is for Mr Feral.
Mad Mackem is offline   Reply With Quote
Old 04-03-2008, 08:43 PM   #6522
bmr
I blew up the picture and it doesn't look like it.
I did find the Spice inserts at RCMart too. They look squared off also.
Old 04-03-2008, 10:11 PM   #6523
Spice inserts have a rounded edge. What's neat about them is they come in 2 different thicknesses and in 3 different harnesses(?). Work great in RP's and Spice tires and also for double stuffing Tamiya 60D's. Ride inserts do not have rounded edges and are thinner. Also the Ride inserts are softer. Also good for double stuffing 60d's when you want them slightly softer.
Old 04-04-2008, 12:48 AM   #6524
What about the standard Tamyia 60D insert into the splice tyres
Barger is offline   Reply With Quote
Old 04-04-2008, 03:05 AM   #6525
Teehomo's Avatar
Trader Rating: 24 (100%+)
Hi all. Just seeking some help on what I think is excessive tyre wear. The tyres below are Tamiya 60D's taken form my two minis. The one on the left is double stuffed, although the Tamiya hard foam is on the outer and the Sorex insert is on the inner. The one on the right is single stuffed with Tamiya standard foam inserts.
Both cars have had two race meets, so 6 heats and 2 finals each. Surface is asphalt with medium grip, track size is around 19-20 seconds per lap. Standard sports tuned motors, nothing out of the ordinary in setup.
Is this level of tyre wear normal for a mini, or is my tyre construction efforts lacking? If so, is there anything I can do to make the tyres last a bit better with tyre/rim/insert selection?
Thanks for your help guys.
Teehomo is offline   Reply With Quote
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 04:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-01-2011 11:08 PM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 08:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 06:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 07:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
