Like Tree81Likes
Old 08-09-2005, 04:31 AM   #631
414play's Avatar
I have tried out to lower the car ... but no way ... I'm using the standard oil mini shocks : "50519 C.V.A. MINI SHOCK" ... even If I full press the shocks I can't go very down in the ride height. I'm using stock spings without any sping load.
these shocks are too long for the m03, you need C.V.A. SUPER MINI SHOCKS 50746 or TRF SHOCKS 53571 both with short springs
414play is offline   Reply With Quote
Old 08-09-2005, 06:20 AM   #632
What part(s) are needed to convert an M03 to the long-wheelbase car?
Slow4dr is offline   Reply With Quote
Old 08-09-2005, 06:44 AM   #633
you'll still need to put spacers internally on the shock shaft to get the ride hight you want.
sportracer is offline   Reply With Quote
Old 08-09-2005, 07:02 AM   #634
killingtime's Avatar
Actually, using the super mini shocks and Tamiya short springs, there isn't a need for internal spacers. You will need spacers/clips on the outside of the shock to get the chassis off the ground though.
Mike Webb
rD Squared-MW Designs-C and R racing
Final Thoughts RC club R.I.P.
killingtime is offline   Reply With Quote
Old 08-09-2005, 07:12 AM   #635
Wicked-Wayz's Avatar
Trader Rating: 19 (100%+)
Send a message via ICQ to Wicked-Wayz Send a message via AIM to Wicked-Wayz Send a message via MSN to Wicked-Wayz Send a message via Yahoo to Wicked-Wayz
Using just the mini shocks & springs with the spacers/clips. They won't give the correct ride height of what you need. Your mini won't sit on the ground at all this way. You need to use spacers inside all the shock bodies. I have tried your method, if you want to tip over go that way. You want the arms to be horizontal, this keeps from anything in the front from binding.
Peace Aaron(W-W)
Schacht Design Works Trackside Hobbies Dirtheaven CRC Hobbies MidWest Tri-Clone RC Scoring Pro LiveRc.com 92 Zero Designs
Wicked-Wayz is offline   Reply With Quote
Old 08-09-2005, 01:43 PM   #636
killingtime is right if you use the short springs but I've got the onroad tuned spring #53440 which has soft,medium stiff,and extra stiffand for my son i'm using #53163 the onroad tuned springs for 4wd/fwd toung and rally soft,medium and stiff. not surewhat the short spring set comes with.
Old 08-09-2005, 04:54 PM   #637
Wrong you will need to use a spacer in the shock body. Well this is only if you don't want any binding & keep the arms horizontal. I have just used the mini shocks & springs with the spring clips. This doesn't give you a low ride height, you mini will look kind of like a rally mini. You should only be able to stick your index finger under the car. A mini needs to go as low as it possibly can with binding & hitting the ground. Try his idea & see how tippy your mini will get cornering. Then try my method that alot of people in my area have used for years. You will see a major difference in control & speed I know I did.
Peace Aaron(W-W)
Old 08-09-2005, 08:45 PM   #638
Per my exp. with the super mini shocks w/ the short Tamiya springs I DO have to use spacers on the exterior of the shock to keep it up. I'm using 2mm shims on the shocks to get 4mm of ride height.....and no spacers inside the shocks. Sportracer - I'll show you what I've done to the Cooper on Sat. in GB. If you want to break the shocks down to inspect, feel free I would suggest that you get the short springs, that way your adjusting your ride height with ext. spacers instead of the pain in the a$$ internal spacers.
Mike Webb
Old 08-09-2005, 09:10 PM   #639
I've updated my hop-ups list to include the new Racing Wing Kit, new Titanium Turn Buckle Kit, Aluminum Servo Stays, and other misc info. It's available here:
http://parametric.org/~gte024h/trickmini.pdf
gte024h is offline   Reply With Quote
Old 08-09-2005, 09:43 PM   #640
Turbonium's Avatar
Trader Rating: 27 (100%+)
Send a message via Yahoo to Turbonium
well, i wouldnt use internal spacers for setting ride height... you will ensure that there is no suspension movement. you can change the droop, or uptravel, that way, but i would prefer to use the external method for the height.
my Mini's have the TRF threaded shocks, and either the short flourescent set, or the short touring car springs on them, depending on the surface. i have no problem getting the chassis on the mat...
Wes
Team Novak
Turbonium is offline   Reply With Quote
Old 08-10-2005, 07:37 AM   #641
hell no I'm not going to rebuild any shocks if I can help it , do you have a part # for those springs and shocks, the internals are a pain in the a$$ but that was the only way to get the ride hight down for me shouldn't be using those TRF shocks on the cooper I guess. that's what I get for listening to Manta.
Old 08-10-2005, 08:23 AM   #642
You should know better than to listen to Manta!! Alright, the shock set I'm using is the #50746 CVA Super Mini Shock Unit Set, and the springs are #53333 Touring Car Tuned Spring Set(short type). As for the internal spacers..again, I don't use them but I do see thier importance if you want to set droop. I just don't see the need right now, for me.
Mike Webb
Old 08-10-2005, 10:18 AM   #643
Default Lots of gear questions
I see Robinson Racing sells metric 48 pitch pinions. How do these hold up compared to the Tamiya gears?
I have a TA03 ball diff on the way... Which gears wear out quickly once the TA03 unit is in the car?
Last, How would you gear a ROAR legal stock motor in an M03?
Thanks. I've learned tons from this thread
Old 08-12-2005, 01:14 PM   #644
I guess three questions was a few too many. I'll withdraw those and ask one; How do you fit something other than a 16/18/20 tooth pinion on an M03?
Old 08-12-2005, 01:44 PM   #645
with out hacking up the chassis tobee craft makes an adjustable spur gear don't know how oit works but saw it on ebay.
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 04:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-01-2011 11:08 PM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 08:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 06:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 07:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
