Like Tree1Likes
Old 03-22-2008, 09:13 AM   #6391
Suspended
Originally Posted by caltek1 View Post
dragnse7en,
I use the TAO-3 balldiff, built as per the instructions. When I place the screw in I use blue loctite to prevent it coming loose. This stops having to do so many diff rebuilds.
For tightness I do the screw all the way up and then back off about a eigthth of a turn.
The Exige system has not proven itself to the importer in the US, who is Shaun Palmer at Schumacher. I think they are waiting for a more robust system. Web-site is www.racing-cars.com
Hope it helps
Later
Calvin.
I'd certainly use loctite on my nitros, but really didn't think I needed it for this. I've never needed to use loctite on any of my ball diffs. But it seems like a good point. For the manta ray diff, the nut gets bottomed out all the way. That's what has worked for me tho. I'll be tearing my mini aprt later on this afternoon, and hopefully it's just the lock nut that came loose and nothing else. Otherwise, my cousin has a spare main gear and guts (minus rings and balls) for his
Tamiya Frog from 1985 - Kyosho Outlaw Ultima ST - AE RC10T (cow hide LOL) - Tamiya M03-L Mini Cooper - Tamiya 1/24 Tamtech Posche 962C - Tamiya 1/24 Tamtech Ferrari Testarossa - Tamiya TA05-R - AE TC5FT
dragnse7en is offline   Reply With Quote
Old 03-22-2008, 04:31 PM   #6392
tony gray's Avatar
Originally Posted by Xtant3150c View Post
Very Kewl pic Ashley!
Question for the M03 Bashers out there. Has anyone tried using RC18T Road Rage tires by Proline on their Mini? I have heard of people using the RC18T off-road tires on their Mini's for Rally Racing before so just wondering if anyone tried the on-road tires before?
Hmmm, good question..
Haven't done it myself, but I think it'd be fine for just pavement and car park bashing.
Wouldn't work for racing though, because you end up with squashed sidewalls to get RC18 tires onto Mini rims and the tyres move side to side a lot on the rims because of that. Fine on an off-road surface or for bashing, but would be weird on an on-road circuit where you want some precision in steering.
tony gray is offline   Reply With Quote
Old 03-22-2008, 09:42 PM   #6393
Trader Rating: 28 (100%+)
They said I shouldn't do it...
They said I couldn't do it...
But I did it...
Tony can you use these?
Taken at Meakin Park offroad, M03 with Northcraft Caterpillar, mini rims and proline mini bowties (thanks tony for the inspiration)
Ashley Cobb is offline   Reply With Quote
Old 03-23-2008, 12:05 AM   #6394
Xtant3150c's Avatar
Mahalo's for the info Tony!
Just what I wanted to hear. I had'nt seen the 18T tires on Mini wheels myself so I was not sure how they fit on there. But good to know that they would work for non-race useage.
Ashley once again Great Pics of the Caterpillar! Great Action Shots!
Xtant3150c is offline   Reply With Quote
Old 03-23-2008, 01:07 AM   #6395
tony gray's Avatar
Ash, those almost deserve a special page all of their own!
They'll be on the site soon...
Old 03-23-2008, 01:30 AM   #6396
Tony...pulled the MO3 apart and started again...think I found the problem..I was usihg a 3003 sevo(tried 2)but they both seem very eratic ..not centering...so I will try a digital KO (overkill I know)
with the splice tyres do you need to double stuff them?...I found with the Tamyia60 they got slightly lumpy and actually one front one has a small split on the inside where the rim is
Bob
Barger is offline   Reply With Quote
Old 03-23-2008, 01:35 AM   #6397
caltek1's Avatar
Trader Rating: 33 (100%+)
Default SPICE TYRES
Barger,
I am not Tony, however I have only used one Hard Tamiya foam insert in the Spice tyres. They work well on the rear of the Mini. A few of us run them at our local track.
I have only used them on the front once, however I had setup problems at the time. Most of us are running 60D's on the front with Sorex insert outer and blue or old mini black foam closest to the rim. With the tyres packed this way, I have run 6 x 5 min qualifiers, 3 x 5 min finals, 6 x 6 min qualifiers, 1 x 6 min final and 1 x 8 min final and am just starting to get a groove in one tyre. This does not include the practice times for three different events.
I know most of the other guy's have used a similiar insert, especially at Windsor.
Later
Calvin
caltek1 is offline   Reply With Quote
Old 03-23-2008, 02:34 AM   #6398
tony gray's Avatar
Bob, good timing... I only tried Spice tyres for the very first time this afternoon. Tried both 36's and 28's and both of them were setup with Spice moulded inserts, figuring that its usually best to utilise the stuff that they design themselves.
And..they worked very well. I'd certainly be happy to run them like that again with no hesitation.
They certainly do not need double stuffing. Thats a 60D only trick.
Latest updates - A Crash Test Mini for Tom March, and a Caterpillar out of its element from Ash Cobb.
Click here to check em out.
Old 03-23-2008, 04:42 AM   #6399
RJ Racer's Avatar
Default Meam Looking Mini
Hi there girls and guys, okay, I need one of those mean looking mini bodies I saw on the rc-mini site. I think they are marked as Chevron? You know, the ones with the big wing and big scoop and big guards. If so, where can I get one if they are still made. Hey Ash, you have raised the bar racing the Bug on the dirt track,,well done. Cheers from Rob J.
RJ Racer is offline   Reply With Quote
Old 03-23-2008, 08:11 AM   #6400
mkdut's Avatar
Trader Rating: 19 (100%+)
More importantly where can I get one of those awesome caterpillar bodies?
mkdut is offline   Reply With Quote
Old 03-23-2008, 02:49 PM   #6401
tony gray's Avatar
Rainbow Ten in Japan usually have both, but they are out of stock at the moment.
RC Mart in Hong Kong have the Caterpillar shell in stock though
Old 03-24-2008, 08:17 AM   #6402
etino's Avatar
Originally Posted by cate3 View Post
Hi, I had the same problem earlier tonight (newly installed SP Exige)
Re-programmed Exige using DNA seup unit (Thanks Calvin!) however, this did not fix problem.
Finally fixed problem by selecting another 'model' on my radio (an unused one) This forced radio to default settings. Turned on Radio, full throttle, turned on Exige...beep once or twice, released throttle...then throttle again, motor spun Ok, all seems ok now...and no more continous beeps!
I think that perhaps EPA's and all settings must be set back to default or maximum etc....in any case, this worked for me...hope it helps.
Cheers,
Carl
Thanks Carl, that changing of models on the radio does the trick somehow. Thanks again!
Tourers : Tamiya TA05, TA05R, F103GT, Yokomo MR4TC BD; HB Cyclone Hara Edition, TRF415 MSXXX
M-Chassis : Tamiya M03M, M03R
F1-Chassis : Tamiya F103RS, F201
1/12 Chassis : Kawada M300SX
Drift-Specs : Tamiya TT01D, TT01, TT01R; HPI Sprint 2; Yokomo MR4TC SSD Black Edition
Radio : Futaba 3PK Spektrum Pro, Sanwa M11 Specktrum Pro, Spektrum DX3R
Charger : FMA Cellpro 4S, MuchMore Silent Charger, iMax B5
Battery : LiPro
etino is offline   Reply With Quote
Old 03-24-2008, 11:41 AM   #6403
mkdut's Avatar
Question for those familiar with US TCS rules:
What can be done to the gear diff and still remain legal for TCS races? Fully locked? shimmed tight but still with diff action? packed with grease(tamiya or other) to tighten it up?
Basically, where is the line?
Old 03-24-2008, 12:57 PM   #6404
Does anyone have a pic of a HPI Honda Civic body mounted on a M03-M?
thanks,
eric
eric7 is offline   Reply With Quote
Old 03-24-2008, 03:18 PM   #6405
tony gray's Avatar
You mean like this?
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 05:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-02-2011 12:08 AM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 09:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 07:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 08:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
Currently Active Users Viewing This Thread: 8 (1 members and 7 guests)
osmax
