Like Tree1Likes
Old 03-17-2008, 11:54 PM   #6361
kidsid99's Avatar
Trader Rating: 53 (100%+)
Originally Posted by SirSwiftAlot View Post
The best setup I have found is putting the MO4 on the shelf and buying a FWD.
He already has a M03, I can't understand it either!
kidsid99 is offline   Reply With Quote
Old 03-18-2008, 11:08 AM   #6362
Originally Posted by RC MARKET View Post
Active new mini body Lotus 210mm
I must have missed this...who makes this body? Part number?
thanks
cherokee is offline   Reply With Quote
Old 03-18-2008, 03:45 PM   #6363
Xtant3150c's Avatar
thanks
http://www.active-hobby.com/
Xtant3150c is offline   Reply With Quote
Old 03-18-2008, 07:29 PM   #6364
shadow102's Avatar
Trader Rating: 21 (96%+)
hey new to the mini game finding a lot of valuable info so far. already got the trans bearings on the way and got some rs4 oil shocks retro fitted and going to get some universals the end of the month. The issues i am having right now is finding online hobby stores besides tower that have a m03 section for replacement parts/hop ups/bodies anybody have suggestions?
Hot Bodies Cyclone - - TeamTekin - - Spektrum - - Team Orion - - Futaba
www.nexusracing.com
www.go-rc.org
shadow102 is offline   Reply With Quote
Old 03-18-2008, 09:40 PM   #6365
Originally Posted by TryHard View Post
Could be, but then again, I was using mine indoors, and with it located in the chassis (so not getting a lt of airflow).
Running it with a 27t Monster, XXX Brushed, Red/green springs, on 20 and 18t pinions, depending on track. Still works fine
But, thats a moot point now, as the TEU-101BK is sitting in my TA03FS, as the mini is awaiting it's exige brushless
Cheers
Ed
When I installed my Exige system in my M03 I ran into a few problems. First the engine screws are too long. If you screw them in all the way the motor doesn't spin. To fix this I ran about 5mm shock spacer on the screws.
The other item and I am hoping someone can help me here. When I hooked the system up it ran in reverse. Should I switch the polarity and run the positive to the negative??? What is the fix?
Spoook is offline   Reply With Quote
Old 03-18-2008, 10:05 PM   #6366
Sidewayzzzz's Avatar
Yes, you should switch the red and black wire. black to red and red to black.
Right now u prob have faster reverse than forward.
After switching cables will be fine.
TRF415 | M03R | TA05R | F103GT | TT01 | Cyclone S | Cyclone WCE
Sidewayzzzz is offline   Reply With Quote
Old 03-18-2008, 11:01 PM   #6367
Try RCBOYZ. They have some Mini stuff and at a decent price. But like everyone else not a complete stock.
Granpa is offline   Reply With Quote
Old 03-19-2008, 07:19 AM   #6368
rcarmchl's Avatar
Trader Rating: 15 (100%+)
Oh trust me - you will understand when it leaves you standing.
Blizzard Concepts ~Big-Dog Graphics
Cyclone ~ Orion ~ LRP Sphere ~ S9550
M03 ~ Orion ~ LRP QC3 ~ S9550
RC18R ~ Castle Creations ~ Hi-tec
Slash ~ 9550 ~ SMC Power
8ight-T~9550~V-Spec
rcarmchl is offline   Reply With Quote
Old 03-19-2008, 08:32 AM   #6369
slammin's Avatar
Trader Rating: 86 (100%+)
Send a message via Yahoo to slammin
You will understand when your looking at my back bumper.
RC Addicts AR
Serpent srx4
Serpent srx8
slammin is offline   Reply With Quote
Old 03-20-2008, 07:24 AM   #6370
rcarmchl's Avatar
First Sid an now you huh? sid was so damn fast on sunday he could have driven away with it (it didn't hurt that the track only had 2 real turns to it), that is until he found the end of that pipe and tore the front end off his car!!! LOL
8ight-T~9550~V-Spec
Old 03-20-2008, 08:32 AM   #6371
shadow102's Avatar
I know its nothing highly important but i finished putting a set of nitro RS4 2 shocks on the mini last night. They fit perfectly on the car and just looking at pictures look very similar to the mini CVA shocks
www.nexusracing.com
www.go-rc.org
Old 03-20-2008, 02:26 PM   #6372
mjderstine's Avatar
Originally Posted by asw7576 View Post
Anything.
Tamiya TEU-101BK is okay esc for lightly tuned and sport tuned motor.
i just got the m03 from towerhobbies, and they are including the esc now. i use a 19t with no problem.
barely gets warm.
mjderstine is offline   Reply With Quote
Old 03-20-2008, 03:25 PM   #6373
RC MARKET's Avatar
thanks
http://rcmarket.com.hk/index.php?cPath=68_75
RC MARKET is offline   Reply With Quote
Old 03-21-2008, 10:23 AM   #6374
etino's Avatar
Default HELP!!! Exige beeps continuously
I just installed SP Exige, the motor beeps continuously and it does throttle or reverse. I bought SP 11.5R, and it is still the same. If my new Exige toast? The manual doesn't say anything about continuous beeps.
Please help, I'm running nuts.
Tourers : Tamiya TA05, TA05R, F103GT, Yokomo MR4TC BD; HB Cyclone Hara Edition, TRF415 MSXXX
M-Chassis : Tamiya M03M, M03R
F1-Chassis : Tamiya F103RS, F201
1/12 Chassis : Kawada M300SX
Drift-Specs : Tamiya TT01D, TT01, TT01R; HPI Sprint 2; Yokomo MR4TC SSD Black Edition
Radio : Futaba 3PK Spektrum Pro, Sanwa M11 Specktrum Pro, Spektrum DX3R
Charger : FMA Cellpro 4S, MuchMore Silent Charger, iMax B5
Battery : LiPro
etino is offline   Reply With Quote
Old 03-21-2008, 10:51 AM   #6375
Cool Exige - Continuous Beeps
Hi, I had the same problem earlier tonight (newly installed SP Exige)
Re-programmed Exige using DNA seup unit (Thanks Calvin!) however, this did not fix problem.
Finally fixed problem by selecting another 'model' on my radio (an unused one) This forced radio to default settings. Turned on Radio, full throttle, turned on Exige...beep once or twice, released throttle...then throttle again, motor spun Ok, all seems ok now...and no more continous beeps!
I think that perhaps EPA's and all settings must be set back to default or maximum etc....in any case, this worked for me...hope it helps.
Cheers,
Carl
cate3 is offline   Reply With Quote
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 05:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-02-2011 12:08 AM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 09:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 07:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 08:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
