Like Tree104Likes
Old 08-04-2005, 04:18 AM   #601
sosidge's Avatar
Probably a highly modified M-01 - that may be an Eagle Racing fibre chassis set.
Old 08-04-2005, 04:19 AM   #602
A Ilievski's Avatar
Trader Rating: 39 (100%+)
guys what hop ups should i get for my M-03 at the moment it has
alloy arms, alloy front nuckles, oil shocks, ball raced, carbon gearbox shafts, quick release battery holder, toe-in rear hubs, universal joints,
what else should i get, thats how i got the car.
Alex Ilievski
*AWESOMATIX * R1 WURKS * PLAIG BEARINGS*
A Ilievski is offline   Reply With Quote
Old 08-04-2005, 04:49 AM   #603
Wicked-Wayz's Avatar
Trader Rating: 19 (100%+)
Send a message via ICQ to Wicked-Wayz Send a message via AIM to Wicked-Wayz Send a message via MSN to Wicked-Wayz Send a message via Yahoo to Wicked-Wayz
I have no idea what that car is.
Well I am assuming you have a sway bar kit. Probably have some shocks already. Maybe get yourself a motor cooler the fin type. Well that is if you don't have it already. I can't think of anymore hop-ups for the m03 off hand. I am also not sure about the motor cooler. A few friends run them & recommened them is my motor gets warm. Mine does so I am think about trying it out. Tires & rims have some extra. Faster steering servo unless you have a fast one already. There not needed a basic servo works fine. This would be some what of a hop-up.
Peace Aaron(W-W)
Schacht Design Works Trackside Hobbies Dirtheaven CRC Hobbies MidWest Tri-Clone RC Scoring Pro LiveRc.com 92 Zero Designs
Wicked-Wayz is offline   Reply With Quote
Old 08-04-2005, 06:26 PM   #604
SpeedsterTC3's Avatar
Send a message via AIM to SpeedsterTC3
What are the best hop-up tires for the MO3. Or is the Kit tires good enough?
SpeedsterTC3 is offline   Reply With Quote
Old 08-04-2005, 06:42 PM   #605
The kits tires will do ok. I am not sure what are good tires. I think it all depends on your track.
Peace Aaron(W-W)
Old 08-04-2005, 08:58 PM   #606
I'm getting ready to order a set of HPI 4565's for my M03. For bashing around, the kit tires are fine. But for a prepared surface, these belted X-patterns look like a good choice. (if they suck, someone please chime in)
Slow4dr is offline   Reply With Quote
Old 08-04-2005, 11:20 PM   #607
rc geek's Avatar
the HPI's are awsome.
they give heaps of grip and they are long lasting too.
rc geek is offline   Reply With Quote
Old 08-05-2005, 12:46 AM   #608
A Ilievski's Avatar
2day i finally tested out my m-03 and i was suprised of how good it went. i wasnt expecting it to be as fast as it was. the only other hop ups that are gona go on my mini are the ta-03 ball diff and make it m-03l
Alex Ilievski
Old 08-05-2005, 01:50 AM   #609
180sx's Avatar
kid-tt01 if u make it a m03L u will have to buy a new shell thats like 60 bux
180sx is offline   Reply With Quote
Old 08-05-2005, 01:57 AM   #610
A Ilievski's Avatar
i dont mind buying a new shell but where can i get the part to make it a M-03l
Alex Ilievski
Old 08-05-2005, 02:27 AM   #611
rayman's Avatar
Good set up for me is blue springs Front and yellow springs rear, medium tamiya oil, swaybar front only. type a tires all around. ride height is critical, go as low as you can so you wont tip over on high speed corners. I know it sounds wierd that you have to put hard springs in a front wheel drive but this car just traction rolls a lot and you need to lessen it.
__________________________________________________ _____________________________
My 3D Gallery Website
rayman is offline   Reply With Quote
Old 08-05-2005, 08:12 AM   #612
I won't run anything but tamiya tires & rims for my mini. I try to keep it tcs legal all the time. You would probably have to ask someone who has a m03l already. Get the part number off the manual & order them from your lhs. You could always go to the lhs and ask them. Blue & yellow are way too soft for my track. I use the darker colored springs they are alot stiffer. Surely keep your mini as low as you can go with it. Keep the rear just a little bit higher than the front. I got a 5mm spacer in the front shocks & gonna try 6 or 7. I got a 5mm in the rear I am gonna try a 6mm spacer. The higher the shock oil the less bounce you will have. I have 90 front 70 rear, I might try 100 front 80 rear. I have the one hole/#1 piston in my all my shocks. I have m-type in the front & s-type in the rear.
Peace Aaron(W-W)
Old 08-05-2005, 08:52 AM   #613
Wicked- What type of surface do you run on? Part numbers for the stiffer springs? TIA
Old 08-05-2005, 09:22 AM   #614
Carpet or tarmac, I can't remember exactly off hand. I am hoping I have the colors right with the number. All springs came in pairs, cost me between $3-3.50 a pair. These are all the dark colors, all come in single packages(not one big one). I am gonna also pick up the TRF Short Damper Spring Set. Which is comes in one big package. I don't have the part number for that yet. These are all softer than the darker ones.
53633 TRF Short Damper Spring (Ex-Hard) Color: White
53632 TRF Short Damper Spring (Hard) Color: Dark Blue
53631 TRF Short Damper Spring (Medium) Color: Dark Yellow
53630 TRF Short Damper Spring (Soft) Color: Dark Red
Peace Aaron(W-W)
Old 08-05-2005, 12:40 PM   #615
Jam-ehz's Avatar
Send a message via ICQ to Jam-ehz
53333 - Touring Car Tuned Spring Set (Short Fluorescent Springs)
53440 - On Road Tuned Hard Spring Set (Dark Springs)
-=≡ Tamiya TA05 TRF415MSX F103R M-03R M-04 M-05 ≡=-
-=≡ CRC Carpet Knife 3.2 OFNA LD3 Pro Fastcats Spektrum ׀ווlı ≡=-
Jam-ehz is offline   Reply With Quote
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 04:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-01-2011 11:08 PM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 08:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 06:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 07:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
