Like Tree105Likes
Old 01-20-2008, 11:59 PM   #5971
Originally Posted by Herkimer Jitney View Post
Dude how come most of your posts are just running someone else down? Maybe Rainbow and jrrc arent the cheapest but your attitude on a lot of your posts really sucks.
watchout this bakagayjeans is con trying to rip off people. all his/her posts try to lure you away from jrrc and rainbow10..
minicrapper is offline   Reply With Quote
Old 01-21-2008, 12:36 AM   #5972
wallyburger's Avatar
hey minicrapper,
Where do you get off on bashing bakaguyjean?...stating he's "...trying to rip off people."?
Your abundance of wisdom and post/participation here is overwhelming...NOT...I'm sure you also have the ability to read the minds of other members through their postings. And maybe your just playing 'tag team' with Herkimer Jitney as the flavour of the moment?
bakaguyjean is a respected member here and in other forums outside of this one and even though I've never ordered from him before, he's made some very good points here and in past, as well in other forums.
His english may not be perfect but at least he tries and provides good information that we can read, and take in, if we choose to.
We all have our opinions and at the end of the day one can take it or leave it. However, it sounds to me you've got a chip on your shoulder to pick a fight for no reasonable reason - do it elsewhere on the little kitty forums where you have your 1000+ meaningless posts and let the rest of us members here enjoy the purpose of this thread without your non-productive comments.
wallyburger is offline   Reply With Quote
Old 01-21-2008, 01:20 AM   #5973
TryHard's Avatar
Hey guys,
Ran my mini for the first time in a while this weekend. Treated it too a new set of boots (M-grips), and followed some local advise over here, and Tony's guide, so had the fronts double stuffed, and the rears normal.
Worked a treat. Never had the car handle as well on the rug. It's a little lary coming into fast turns, with a bit of lift off oversteer, but I might try some more shims in the rear shocks to solve that. Ended up runnig quite a stiff setup.... was great for some two-wheeled fun, but I think I might move my esc and so on into the chassis now, also thinking the ride height was a little high.
But hey, it was good fun, and i was faster with 2wd/27t than some of the tourers at the club... hehe. Enjoyed it so much, I've already stated that if I have to run 27t at the club again (currently doing 10.5 in my tourer), I'll simply put the mini on track, rather than run my tourer!
Quick question though, has anyone tried double stuffing in reverse? ie, foam outside, molded inside? I would assume this would work for type A's being belted, but for M's and S's maybe not?
Cheers
Ed
Old 01-21-2008, 01:25 AM   #5974
joe of loath's Avatar
heres a tip from the mini racers at my track; (i will soon be joining their ranks )
go to the nitro racers and ask if they have any worn out foams. our whole club's minis (about a half dozen) all run on old foams. the cars grip better, don't traction roll, and best of all, the tyres are free
HPI E-Firestorm - Tamiya TA05 racer (carbon chassis, 10.5 brushless etc) - LRP Blast S10 BX - Revo 2.5r truggy conversion (in progress)
joe of loath is offline   Reply With Quote
Old 01-21-2008, 01:51 AM   #5975
tony gray's Avatar
Default I wonder what this is?....
Well boys, hands up who wants one of these?
tony gray is offline   Reply With Quote
Old 01-21-2008, 05:13 AM   #5976
Originally Posted by wallyburger View Post
hey minicrapper,
wallbanger=fish
Old 01-21-2008, 07:06 AM   #5977
ChuckWick357's Avatar
i want one
I live with Fear and sometimes SHE let's me Race!!
ChuckWick357 is offline   Reply With Quote
Old 01-21-2008, 07:29 AM   #5978
Core Creations's Avatar
Trader Rating: 93 (100%+)
Send a message via AIM to Core Creations
Anyone know where I can get a M04 swaybar set?
Core Creations paint thread
Mini Mafia Kansas Chapter - where the monster minis grow!
Core Creations is offline   Reply With Quote
Old 01-21-2008, 08:23 AM   #5979
mep
mep's Avatar
Trader Rating: 40 (100%+)
Hi Ed... you might want to go the oposite direction to make the rear end less tail-happy. Making the rear end softer helps to keep mine from oversteering on carpet. If you think your shocks are already a bit too tall, you may want to shorten the fronts & use stiffer springs(short blue recommended) and leave the rear shocks a couple mm taller with softer springs(red short recommended, or M04 front gold springs if you have access to them). The softer springs will squat quite a bit & cause the chassis to drag if the shocks are too low, hence the reason for making the rears slightly taller to allow room for pre-load spacers without actually adding tension... too much pre-load tenson on the rear shocks will make the spinning & traction rolling worse.
Good spring/shock combos I've tried on carpet:
1. Front 56mm, stock silver springs, 1 small pre-load spacer / rear 58-59mm, M04 gold springs, 1 medium pre-load spacer
2. Front 56mm, short blue springs, 1 medium pre-load spacer + 1 small spacer / rear 58-59mm, short red springs, 1 large spacer
Both of those settings work well for me with every tire option that I've tried on carpet; Spice 32R, soft Rides, Type-A slicks, and X-patterns... should be fine with M-grips too. Shock oil & piston valving doesn't seem to have a drastic affect for me, but I usually run 2-hole 50-weight front, & 3-hole 40-weight rear on carpet
mep is offline   Reply With Quote
Old 01-21-2008, 01:20 PM   #5980
TryHard's Avatar
I've already got short whites in the front, tried reds on teh rear, but prefered how the car responded with the yellows round the rest of the track. I'm pretty sure the car wasn't dragging... I have a lot more preload spacers then you suggest (had it so the arms were level at race weight), so I'll probably drop the car next time.
Still gives me something to play around with
Old 01-21-2008, 05:28 PM   #5981
ScionBox's Avatar
Wow!
My hand is up!!!
Since my Mini decided to catch on fire over the weekend, this lil' truck seems like it would be the perfect replacement!
Let's have some more details!
ScionBox is offline   Reply With Quote
Old 01-21-2008, 06:27 PM   #5982
tony gray's Avatar
There aren't any details. ABC don't have it on their website yet, and wont officially admit that it even exists...
And given their usual habits it will come out as a complete Genetic kit first, and then several months later as a spare part.
Old 01-21-2008, 07:22 PM   #5983
Hey anybody out there: any news on the Monster Mini body ie: cost, where to locate?
bowl806 is offline   Reply With Quote
Old 01-21-2008, 08:37 PM   #5984
mep
mep's Avatar
Sounds like you have it covered
Old 01-21-2008, 10:33 PM   #5985
oME
oME's Avatar
Default sticker
Guys do you have any paper patterns or cutouts for the hood and roofing of the suzuki swift? I bought this carbon fiber sticker and I am wondering if you guys have any pattern on doing this so that I could just follow and trace it on the sticker that I bought? Thanks in advance!
Itís not about winning the race itís about being on the race!
oME is offline   Reply With Quote
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 04:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-01-2011 11:08 PM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 08:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 06:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 07:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
