Like Tree163Likes
Old 01-04-2008, 03:28 PM   #5791
mep
mep's Avatar
Trader Rating: 40 (100%+)
I have a set of the tech arms, but I've never installed them. I got them from one of my friends when I bought out his m-chassis lot... he said that he had to sand & file them quite a bit to make them fit correctly, & not bind up on the hinges. That surprised me, because Tech makes a quality part usually.
mep is offline   Reply With Quote
Old 01-04-2008, 05:35 PM   #5792
cartix's Avatar
Trader Rating: 33 (100%+)
Thanks for the replies guys.
cartix is offline   Reply With Quote
Old 01-04-2008, 10:27 PM   #5793
oME
oME's Avatar
Default video
Originally Posted by tony gray View Post
What in the world is 'Double-Stuffing'? The supposed mystery trick for Tamiya 60D's...
Click here to find out how to do it.
Guys can you document a video???
Itís not about winning the race itís about being on the race!
oME is offline   Reply With Quote
Old 01-04-2008, 10:45 PM   #5794
tony gray's Avatar
It's not really that difficult to do. I wouldn't think it was worth spending the time filming it.
Have a go at it first, I think you'll find its easy.
And remember, you don't HAVE to do it.. Its just an option some people try. It certainly isnt necessary, and 90% of the time I don't do it.
tony gray is online now   Reply With Quote
Old 01-04-2008, 11:09 PM   #5795
bakaguyjean's Avatar
Tech has been slipping up on quality control. Most recently thier center shaft for the Yokomo Drift package cars hasnt had a pin in one of the ends.
We got four like this. Also some of the DD-M parts have rust on them.
A little disapointing as Tech is susposed to be very good at what they do.
My body projects blog http://rcbodyproject.wordpress.com/
bakaguyjean is offline   Reply With Quote
Old 01-04-2008, 11:14 PM   #5796
I suppose you have to ask yourself first, is there anything wrong with the standard arms?
I'd suggest not....
Standard arms require removeing alot of plastic between the rear hub and arm itself to prevent the three wheel Mini from happening. Small rocks can get stuck and jam up in between the hub and arm. Bad if you run on a circut that is out doors. Also the Arms need to be trimed if you would like the extra suspension travel for Rally.
Dont know to much about the Tech arms but there could be a better arm for the M03. You have Spice and Tech to choose from.
Old 01-05-2008, 12:02 AM   #5797
Trader Rating: 28 (100%+)
Okay so when you put the standard tamiya inserts, do you cut them shorter? I noticed after I glued my tyres it looks like there's an egg in them.
The inserts where very difficult to get in.
I'm a n00b when it comes to Minis
Ashley Cobb is offline   Reply With Quote
Old 01-05-2008, 12:11 AM   #5798
tony gray's Avatar
You probably didnt do the best of jobs there Ash.. There shouldn't be any eggs at all!
They fit fine - usually!
Old 01-05-2008, 12:14 AM   #5799
ScionBox's Avatar
Here's some pictures of my Mini, called 'The White Rat' because of the red headlights & white body. I recently put some Swift wheels on it and an HPI Mini body to fix it up a little bit. I just finished the TT-01R in the background a couple days ago... and yes, I do need to trim the body posts on it.
Under the lid it's pretty much stock. I plan on buying the Suzuki Swift kit in a couple of months and will eventually tear this old chassis down to keep the spare parts.
ScionBox is offline   Reply With Quote
Old 01-05-2008, 12:32 AM   #5800
inserts just seemed way too long for the tyres... buggered if I know :P
Old 01-05-2008, 12:33 AM   #5801
Thumbs up
[QUOTE=ScionBox;4040232]Here's some pictures of my Mini, called 'The White Rat' because of the red headlights & white body. I recently put some Swift wheels on it and an HPI Mini body to fix it up a little bit. I just finished the TT-01R in the background a couple days ago... and yes, I do need to trim the body posts on it.
[QUOTE]
Shell looks nice man
Old 01-05-2008, 10:39 AM   #5802
Trader Rating: 47 (100%+)
I have the M-04M Alpha Romeo...I am wondering which TRF damper set is better. The 49355 Special Blue or the 53571 Flourine Coated? and why?
Horizon Hobby/Losi
Sanwa
Savox
HobbyWing
Hyperion
SUNA is offline   Reply With Quote
Old 01-05-2008, 10:56 AM   #5803
MonkeyNuts's Avatar
i would go for the special trf's as they will have aluminium shock collars (the bits that you adjust the ride height with)
liam
Tamiya FF03 Pro ~ Tamiya M06 Pro ~ Tamiya M05L JCW Coupe
MonkeyNuts is offline   Reply With Quote
Old 01-06-2008, 01:18 AM   #5804
Skitee's Avatar
Yes go for the Blue TRF shocks they just look so much better and have the aluminum adjuster, the new blue trf's also have a hard black coating inside the shock which is better than the flourine coating. new part no : 42102
Xray T4 2017 ~ ORCA Vritra VX3 ~ Motiv RC 4.5
Xray T4 2017 ~ ORCA Vritra VX3 ~ R1 Wurks 13.5
Xray X12 2016 ~ ORCA Vritra VX3 ~ Orca TX 4.5
POWERED BY SPEEDZONE USA
Skitee is offline   Reply With Quote
Old 01-06-2008, 12:08 PM   #5805
Tiptoe's Avatar
Default hehe
Suffice to say I approve of the white rat
Black mustang looks great as well, I'm a bit partial to yank tanks.
Never trust a rat...
Tiptoe is offline   Reply With Quote
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 04:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-01-2011 11:08 PM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 08:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 06:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 07:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
