Like Tree100Likes
Old 12-26-2007, 04:09 PM   #5686
Moderator
StephenSobottka's Avatar
Send a message via AIM to StephenSobottka
Default Novak Tires
What is the tire choice I should be using at the Novak race when the bite is rediculously high? Steve Key, Dave Weir?
~~Stephen Sobottka~~
SMC Racing
StephenSobottka is offline   Reply With Quote
Old 12-26-2007, 09:36 PM   #5687
over gear's Avatar
Trader Rating: 15 (100%+)
Questions??
Question. What's the different between the black and silver chassis? are they the same thing with different color? or there is a weight advantage on one of them?
over gear is offline   Reply With Quote
Old 12-26-2007, 09:39 PM   #5688
tony gray's Avatar
They're identical...
The only different ones were the VERY early grey chassis (in the first 12 months of production) which were slightly diffferent around the front shock towers.
tony gray is offline   Reply With Quote
Old 12-27-2007, 10:03 AM   #5689
Wicked-Wayz's Avatar
Trader Rating: 19 (100%+)
Send a message via ICQ to Wicked-Wayz Send a message via AIM to Wicked-Wayz Send a message via MSN to Wicked-Wayz Send a message via Yahoo to Wicked-Wayz
Sometimes the kit tires will work the best with the high bite. I think that is what they have all suggested before to me.
Peace Aaron(W-W)
Schacht Design Works Trackside Hobbies Dirtheaven CRC Hobbies MidWest Tri-Clone RC Scoring Pro LiveRc.com 92 Zero Designs
Wicked-Wayz is offline   Reply With Quote
Old 12-27-2007, 10:55 AM   #5690
mkdut's Avatar
Looking for a good starting set up for the M-03 on carpet. TCS legal.
mkdut is offline   Reply With Quote
Old 12-27-2007, 12:19 PM   #5691
MonkeyNuts's Avatar
Here is the setup i use on carpet which works very well for me (regular 'A' wins):
Front
Shock Oil - Orion 80wt
Spring - Short TRF White
RollBar - Silver
Rear
Shock Oil - Orion 50wt
Spring - TA05 Kit Silver (Med/Hard)
RollBar - Black
Toe-In Rear Uprights
I am running TRF Shocks with 3-Hole pistons and the ESC and Reciever are in the back of the chassis (Kit Speedo and Spektrum)
HTH
Liam
Tamiya FF03 Pro ~ Tamiya M06 Pro ~ Tamiya M05L JCW Coupe
MonkeyNuts is offline   Reply With Quote
Old 12-28-2007, 01:42 PM   #5692
tony gray's Avatar
Nothing new to post, just wanted to get the Mini thread back onto the front page....
Old 12-28-2007, 04:34 PM   #5693
KDagh1's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to KDagh1 Send a message via MSN to KDagh1
Default Inside spacers
When using TRF Flourine dampers (53571) how many spacers should I put on the inside of the shock? I considered 12mm but that barely leaves ANY travel at all. The Tamiya 'Built to Win' Article mentions 4 3-mm o-rings in each damper but the black o-rings I have are not 3mm tall, they are closer to 1.5 - 2mm.
Any help would be greatly appreciated.
Thanks,
Khal
KDagh1 is offline   Reply With Quote
Old 12-28-2007, 04:58 PM   #5694
Thanks,
Khal
Use 3 of the black o-rings that you have. When they referred to 3mm O-rings, I believe they were talking about the ID
Granpa is offline   Reply With Quote
Old 12-28-2007, 05:51 PM   #5695
Customworksking's Avatar
Trader Rating: 73 (100%+)
Wink race
I just went over my cooper for the NOVAK who else is going ? 17.5 brushless time to drive
Team Xray | RC America| Hudy |Jaco |AKA
Customworksking is offline   Reply With Quote
Old 12-28-2007, 05:56 PM   #5696
Smile u
no,no u need to take the long road on this learn as u go !
Old 12-28-2007, 06:06 PM   #5697
ChuckWick357's Avatar
Questions??
HTH
Liam
Hummm how the hell did you get you kit ESC and a recever in the back of your chassis???
I live with Fear and sometimes SHE let's me Race!!
ChuckWick357 is offline   Reply With Quote
Old 12-28-2007, 06:07 PM   #5698
Thumbs up body
running my same old lid's
Old 12-28-2007, 07:59 PM   #5699
mkdut's Avatar
Front
RollBar - Silver
Rear
RollBar - Black
HTH
Liam
Thanks for the setup
What tire combo are you running?
Old 12-29-2007, 12:24 AM   #5700
bakaguyjean's Avatar
You have to use some modern Radio gear to fit back there. I have a Keyence speed control,and Sanwa reciever in the rear of one of my cars.
I run the wires through the center of the chassis,over the battery pack. you can also run your motor wires throung the chassisby drilling small holes between where the motor is and where the battery mounts.
The M03 can clean up very nice and hide all of the wires if you want it to.
My body projects blog http://rcbodyproject.wordpress.com/
bakaguyjean is offline   Reply With Quote
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 04:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-01-2011 11:08 PM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 08:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 06:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 07:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
