Tamiya mini cooper
#541
Originally Posted by Big Daddy Boomer
Wes you're my hero!
cya in Vegas!!!!
Wes
#542
pictures
does anyone have any pictures on it? i'd like to buy one online but i don't know what it looks like. sure,i know what a real one looks like though.i'm probably going to do some suearching.does anyone the pros and cons a bout it though? and can it take hop-ups? thanx if you reply to this and if you don't ranks anyways.
#543
Alot of ppl swap these 2 shafts for the Tamiya Carbon Fibre Shafts to save on a little rotating mass in the drivetrain.
#544
Good M URL
Not trying to post whore here, but I'm really getting into this little car. Are there any good M-chassis sites with pics or setups? All I've found are a few sites that list the Tamiya hop up's with part numbers.
You guys must get like an hour of run time with the silver can motor and 3300's. Can't wait to get mine.
#545
hi guys. i am new to electric. was wondering whats a good battery pack to get. i want to get something that is good as i want to get into racing seriosly with it. what should i be looking for?
are the g-maxx, speedmind, GP batteries good?
thanks
thanks
#546
I would personally take some Bulk GP3300 packs ... or if you have surpluss cash get you the GP3700.
e_lm_70
P.S: Here in Europe, Tamiya Stock Races are handled with HandOut Motor and HandOut Battery .... this should avoid advantages for people with expensive Motor/Battery ... but still charging/discharging properly a pack can make a visible difference !
#548
Originally Posted by cat007
Just wondering if anyone is intrested in out of production M-01, M-02 parts.
Gear box (A-parts)
Suspension arms (D parts)
motor heatsink hop-up
racing steering hop-up
and much more..
Pm if intrested and see if we can strike a deal.
Gear box (A-parts)
and much more..
ill send a pm.
#551
hi guys. what size tires/rims do i buy? what should i look for? that is race legal?
also when i buy rubber tires do i also need to buy the foam inserts? or should they come with it
#552
I`m currently using HPI X Patterns that came with the car..do i just repace with X patterns or is there a better tire choice.
Cheers
#553
If you are using for bash around ... I have found the Xpress Mini tire from rcmart quite cheap and already better then stock Mini tiries ... they are even little bit smaller in diameter ... that help on lower CofG, but reduce top speed.
If allowed you can also use standard 1/10 TC tires ... being bigger they will have a better top speed but also a worst CofG.
e_lm_70
PS: Going to make soon a TCS races here in Europe ... very curios to see how I will compete my M03 in a quite fast track against TL01 and TT01 ... where TT01 are alllowed to use 27T pinion and 55T spoor ... quite unfear top speed compared to the M03 capability .... M03 is allowed to be as light as 1300g vs 1450g of TT01
#554
Whats the diameter of mini 60D tires? I compared them to 1/10 touring car tires they're almost the same but touring car tires are lowprofile. Maybe the difference is only less than 2mm. I dont wana buy 60D type A anymore coz they're expensive and easily worn.
__________________________________________________ _____________________________
My 3D Gallery Website
