Old 07-18-2005, 06:18 PM   #511
RED-LINE M03's Avatar
Trader Rating: 127 (100%+)
Default TIRES
Which tires have more traction the HPI X pattern or the Tamiya Type A belted radials?
Thanks.......
RED-LINE M03 is offline   Reply With Quote
Old 07-18-2005, 10:52 PM   #512
nozauta619's Avatar
Thumbs up Thanks!
Thanks Turbonium, let me know, it would be cool to have a RWD Honda Civic.
Thanks Markus for the verification.
Anthony
Kyosho Blizzard EP / Tamiya DF-03RA / Tamiya TA-03F / Traxxas Monster Jams Maximum Destruction / HPI Pro 3
nozauta619 is offline   Reply With Quote
Old 07-19-2005, 01:40 AM   #513
highasakite99's Avatar
O.k. here’s one, does the heat sink on a MO3 really do anything or is it just a bit of a gimmick?
highasakite99 is offline   Reply With Quote
Old 07-19-2005, 03:20 AM   #514
highasakite99 : O.k. here’s one, does the heat sink on a MO3 really do anything or is it just a bit of a gimmick?
I have the M03 and heaat sink ... after around 10Min run with a sport tuned tamiya motor ... the motor was quite hot ... but also the heat sink was hot ... not as hot as the motor but still ... this means that it does help a bit on dissipate temperature ...
It also look cool and it doesn't cost much $$$
e_lm_70
PS: I got the Tobee Craft : 40530 M03-06 A high ratio gear set 36T
This kit come with a spoor gear that is 36T instead of stock 37T ... so I can gain from 37/20 to 36/21 ... that help a bit with stock motor ... this Tobbe kit could allow to replace the spoor with others : 37T,36T,35T,34T ... I would be interest to know where I can get the 35T and 34T ... RainbowTen has these spoor not in stock ... just the basic kit (40530) is available.
Anybody knows a good Internet shop for Tobee Craft M03 parts ???
This is the best link that I found so far for tobee: http://www3.kcn.ne.jp/~tobee/English.htm
e_lm_70 is offline   Reply With Quote
Old 07-19-2005, 03:22 AM   #515
NOZ69's Avatar
IMO, it`s a gimmick in regards to any heat dissapation..When you think it`s only connected to the motor by two screws it can`t take away that much heat.
But on the other hand it might add abit of strength the the motor mount.
Either way i think i`d put my money towards something that actually enhances the car..ie suspension,ball diff etc.
Cheers
FT TC4, LRP TC Sphere, LRP X-11 13.5
SC10 4x4
M03M Suzuki Swift
Power by Feral
Sanwa MX-3 FHSS
NOZ69 is offline   Reply With Quote
Old 07-19-2005, 09:13 AM   #516
minidriver's Avatar
Default heat sink
I think the heat sink is worth the money, not a gimmick, while the connection is only two screws, it does draw away significant heat from the motor even with just two screws (feel it after a run), and with the motor alone encased in plastic, the heat sink is good safety. It will keep your motor from fading at the end of a run due to heat buildup.
minidriver is offline   Reply With Quote
Old 07-19-2005, 12:32 PM   #517
CSeils's Avatar
Trader Rating: 48 (100%+)
Here's one. Which side does the gear on the ball diff go and what will happen if its on the other side?
CSeils is offline   Reply With Quote
Old 07-19-2005, 05:42 PM   #518
Nova F1 Racer's Avatar
R/C Tech Charter Subscriber
Did you see the pic I posted? If not please go back and view it.
Look for the LONG joint and it's the same in the manual.... On the right.
If you put it in backwards it will be off balance...
This is DICK!!! And you're NOT!
RC Tech member #11
Aussie Rules Footy, Brisbane LIONS!!
[url]http://www.pitter-pat.com/[/url] for pet care needs in Northern Virginia
Nova F1 Racer is offline   Reply With Quote
Old 07-20-2005, 02:36 AM   #519
I have a Manta Ray Ball diff on my M03 ... I have to say that the manual is fully unclear about which is the right orientation in the car.
Is this "Look for the LONG joint and it's the same in the manual.... On the right." also valid for manta ray ball diff ???
e_lm_70
Old 07-20-2005, 05:00 PM   #520
Default Tires
Thanks.......
Old 07-20-2005, 05:49 PM   #521
e_lm_70
Yes, looking at all the directions/pics it shows the long joint on the right. The right side is just like a real car...... passenger side.
RC Tech member #11
Old 07-21-2005, 12:00 AM   #522
moot's Avatar
errr...i doubt it. i have one on my car and it just doesnt make a difference.i have even used it with a 6 turn and 3600's running for 10 minutes (just) and it really doesnt make a difference.
shocks,tyres and rear toe in blocks are the best value for money.
moot is offline   Reply With Quote
Old 07-21-2005, 02:54 PM   #523
Default Gear Diff.
I have a gear diff does anybody know what kind of grease I could use to lock up the gear diff.
I used the tamiya diff grease and it is spinning way to free.
Some body told me to use 7000 weight silicone.
I think the silicone would leak out of the gear diff then into the gear box.
Thanks for your support.........
Old 07-21-2005, 04:20 PM   #524
moot's Avatar
i made a spool by jamming up the gears in the diff. it worked well.
Old 07-21-2005, 06:44 PM   #525
Put in/fill it with shoe-goo and let set over night..... (The orginal bevel gearing)
RC Tech member #11
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 05:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-02-2011 12:08 AM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 09:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 07:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 08:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
Currently Active Users Viewing This Thread: 7 (2 members and 5 guests)
Slap
SEO by vBSEO 3.5.0
