Old 10-09-2007, 05:22 AM   #5131
rccardr's Avatar
Won the B in some of the closest Mini racing I've ever experienced. Steve Key, Mike Adelman, Jay Helson and I were all in the hunt, went down to the third Main.
Setup was completely different than anything I've run before: M Grips with a foam insert in the back and a double stuffer S Grip in front. White springs in back and blues in front, same oil and pistons as we ran at the Nats. Rear sway bar. Also saw people running Type A slicks but I think they were a little more prone to tippage.
Rules were basically the same as TCS except for the blind draw motors each round, which worked out really well. As the weekend wore on, some got a little faster and others a little slower but they were all in the hunt. Good driving really made the difference: I gave my backup car to Marty Hageman and he finished fifth overall.
I've never lost.
I've just been a little bit behind when time ran out...
RED DOT MOTORS- Fastest Titan 12T and silver can 540 motors in the known galaxy!
rccardr is offline   Reply With Quote
Old 10-09-2007, 07:06 AM   #5132
CSeils's Avatar
Trader Rating: 48 (100%+)
A little help for an absent minded Mini'er.
I have a slight problem. I was taking my shocks apart (I have not done this for quite some time) and everything dropped on the floor. I had all of the inner spacers off of the pistons and now I can't remember what I had for the front and rear. What do I need for travel in the front and rear for carpet racing? I think I had inner spacers at 6mm in front and 4mm in the rear. Also, what is your ride height and how much droop should I have? (just in case I put things together backwards). Thanks.
I will be writing everything down from now on.
You can never go wrong with a Hooters Mini. But Mini Hooters are bad.
--- USVTA National Points Series Member #122 ---
customracingstickers@gmail.com - http://www.rctech.net/forum/painting-designs-graphics-photography/279695-usvta-trans-am-decals.html
CSeils is offline   Reply With Quote
Old 10-09-2007, 08:25 AM   #5133
forum fodder's Avatar
What tyres do the M chassis kits come with? In particular the RWD kits as they come with different rear tyres? Are they M grip radials or Super grip radials or is it dependant on the kit?
forum fodder is offline   Reply With Quote
Old 10-09-2007, 08:34 AM   #5134
Scottrik's Avatar
Trader Rating: 240 (100%+)
They come (at least the ones I've got) with M-Grip for the front and S-Grip for the rear.
Congressmen should wear uniforms like NASCAR drivers so we can identify their corporate sponsors.
THE REVOLUTION WILL NOT BE TELEVISED -Gil Scott-Heron (1949-2011)
Scottrik is offline   Reply With Quote
Old 10-09-2007, 10:40 AM   #5135
How does the handling compare to the FWD M03 cars (Mini's and Swift) on the standard kit tyres? On tarmac this is.
Old 10-09-2007, 06:43 PM   #5136
rccardr's Avatar
Carl-
6 in the front, 4 in the back. Single 2mm preload spacer on the front, & a 2mm+1mm spacers on the back should get you right with short sedan springs.
I've never lost.
Old 10-09-2007, 06:57 PM   #5137
akura2's Avatar
Send a message via AIM to akura2 Send a message via Yahoo to akura2
Default My Real mini on an RC car track
I was at Sun Valley Speedway (KZ Speedway) on Sunday 10/7/07 to practice with my RC Motorcycles. The guy that runs the track loved my Mini Cooper so much that he told me to run it on the track... I wasn't sure it would fit, but he kept telling me to do it so I did... Here's the video (an RC Car Action Editor was my co-pilot)
http://video.google.com/googleplayer...47303618&hl=en
Google video reduced the quality of the video to crap... but you get the idea
akura2 is offline   Reply With Quote
Old 10-09-2007, 07:31 PM   #5138
MD
MD's Avatar
Trader Rating: 105 (100%+)
Tony - Thanks for the information on the batteries. I have used the IB cells and and I have been very satisfied. I have heard different opinions on IB cells and EP. Max Amps has gone to EP cells instead of IB.
MD is offline   Reply With Quote
Old 10-09-2007, 08:06 PM   #5139
tony gray's Avatar
EP cells are fine in most other classes, especially mod.
But in a restricted motor class (Silver Can and/or Sport-tuned) you need the extra punch, and the EP's just dont have it.
tony gray is offline   Reply With Quote
Old 10-09-2007, 09:11 PM   #5140
MD
MD's Avatar
Tony- Thanks for the information. I found that the IB cells I have been running seem to have very good staying power throughout a race. I have found that I have been able to narrow the gap between myself and some of my opponnets cars in my local GT3 class. If I would quit making driver errors I might beat them.
Old 10-10-2007, 09:51 AM   #5141
Steven Key's Avatar
What is the part number for those new colored Mini rims from Tamiya
One of the drivers at the Mini Mayhem had an orange set of those on his Mini. He added orange to the colors he painted his Mini body and it really looked sweet.
I got to get me a set of those.
Steven Key is offline   Reply With Quote
Old 10-10-2007, 10:19 AM   #5142
Gouloises's Avatar
Send a message via ICQ to Gouloises
Default Question
Hello,
how know´s were I can buy such a lampe, or how it is called.
Gouloises is offline   Reply With Quote
Old 10-10-2007, 10:23 AM   #5143
Trader Rating: 32 (100%+)
Send a message via AIM to JDCrow Send a message via Skype™ to JDCrow
Originally Posted by Gouloises View Post
Hello,
http://www.ottlite.com/
JDCrow is offline   Reply With Quote
Old 10-10-2007, 10:39 AM   #5144
Gouloises's Avatar
thanks for your fast answer.
Old 10-10-2007, 12:37 PM   #5145
redlion's Avatar
Originally Posted by DRAG_ON View Post
53200 4WD Front One way Diff Unit, compatible with Tg-10, Tl01, Ta03,
Wes
redlion is offline   Reply With Quote
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 05:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-02-2011 12:08 AM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 09:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 07:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 08:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
SEO by vBSEO 3.5.0
