Like Tree173Likes
Old 09-21-2007, 10:19 AM   #5041
MD
MD's Avatar
Trader Rating: 113 (100%+)
Swift in the U.S. and Swoft in the U.K.
MD is offline   Reply With Quote
Old 09-21-2007, 11:25 AM   #5042
SirSwiftAlot's Avatar
Location: SOCAL the fastest mini cooper guys in the nation
Thats Funny! I found an MO3 on the for sale forum and a guy was selling a brand new MO3 never ran fully assembled with extras for a Hunsky
God deal but he never got back to me.
Plus you dont want to buy anything from Seattle everything up there is old and washed up. There years behind on technology put it this way Star Wars just got released at the movie theaters today.
SirSwiftAlot is offline   Reply With Quote
Old 09-22-2007, 10:13 PM   #5043
nikkiesteban's Avatar
Send a message via Yahoo to nikkiesteban
how can I minimize bump steer in m03m?
hello miss, puwede pa bind?
nikkiesteban is offline   Reply With Quote
Old 09-22-2007, 10:17 PM   #5044
tony gray's Avatar
If your suspension is set-up correctly bump steer shouldn't be an issue at all.
A well set-up Mini will only use a few mm of travel, and over that sort of distance bump steer is virtually non-existent anyway.
It only looks bad when you're holding the car in your hand and moving the arms up and down. On the track it has no effect.
tony gray is offline   Reply With Quote
Old 09-22-2007, 10:27 PM   #5045
thanks.. I have a question about the stabilizer turnbuckle of m03 it says that adjust it in 2mm)front and fully tightened(rear). what will happen if i will not make the front 2mm? will this affect the suspension and ride height?
Old 09-23-2007, 05:39 PM   #5046
Default I need Two (2) Mini's
Okay I am new to on road electric but want to get me and the wife in some mini racing I need two mini's in GOOD shape and if any extra parts NO electronics just rollers please let me know if anyone has anything thanks
Austin316 is offline   Reply With Quote
Old 09-23-2007, 07:45 PM   #5047
larlee's Avatar
Send a message via MSN to larlee Send a message via Yahoo to larlee
can someone advice what type of inserts to use for M chassis super slick tires?
i use 60D hard inserts but it always tears around the tire wall. using it on asphalt track.
TA05 | M03 | DF02 | DF03
larlee is offline   Reply With Quote
Old 09-23-2007, 08:56 PM   #5048
minimanintaiwan's Avatar
60D inserts not enough to fill out tires.
U need to use a rubber touring insert on top of foam insert or vice versa depending on track surface. A little difficult to stuff it in but can be done. rubber insert needs to be cut down and glued together to get right diameter.
minimanintaiwan is offline   Reply With Quote
Old 09-23-2007, 09:19 PM   #5049
MD
MD's Avatar
Do you double stuff the the rear tires or the front or both?
Old 09-24-2007, 07:43 AM   #5050
slammin's Avatar
Trader Rating: 88 (100%+)
Send a message via Yahoo to slammin
My car is super fast in in infield of the track put seems to be slower on the strights,I have tried different motors and still seems not to change it.Could it be my set up?I am using the ta03 ball diff.
RC Addicts AR
Agama A8t
Agama A215e
Agama A215
Agama A215T
slammin is online now   Reply With Quote
Old 09-24-2007, 09:54 AM   #5051
Nova F1 Racer's Avatar
R/C Tech Charter Subscriber
HPI Blue insert med-hard 24 mm for M grips ( 50683 ) in front and S grips ( 53254 ) in rear for asphalt tracks. We found that slicks really don't work that well....
This is DICK!!! And you're NOT!
RC Tech member #11
Aussie Rules Footy, Brisbane LIONS!!
[url]http://www.pitter-pat.com/[/url] for pet care needs in Northern Virginia
Nova F1 Racer is offline   Reply With Quote
Old 09-24-2007, 10:55 AM   #5052
larlee's Avatar
a touring insert(soft, med or hard?) on top of 60D hard inserts and squeeze into the tires? wow...isn't that a little too hard? how are you able to glue it?
Old 09-24-2007, 11:11 AM   #5053
larlee's Avatar
what is M or S grips?
is it these?
Item #50684 RC 60D M-Grip Radial Tires - (1pr)
Item #53254 RC 60D Super Grip Radial Tires - (M-Chassis) 1pr
Old 09-24-2007, 05:15 PM   #5054
tamiyarcracer's Avatar
Send a message via Yahoo to tamiyarcracer
is it these?
Your original question said SUPER SLICKS. Do you mean 53222 SUPER SLICKS or 53440 60D Reinforced Tire "A" slicks??
If it is the 53440 60D then use the tips that everyone is giving you.
If it is the 53222 SUPER SLICK (50D) then I would suggest trying to find Spice inserts they make 4 thickness (4.0mm, 4.5mm, 5.0mm & 5.5mm), and 3 firmness (soft, med, & hard)
With any luck you can run a non tamiya insert other than that you might have to make something.
I would suggest if you have to keep it Tamiya then you will want a 60D tire it is tall and you will the travel further everytime it makes a revolution. i.e. a hig top speed.
tamiyarcracer is offline   Reply With Quote
Old 09-24-2007, 10:05 PM   #5055
front + rear. same inserts all around.
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 04:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-01-2011 11:08 PM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 08:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 06:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 07:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
