Like Tree137Likes
Old 09-19-2007, 12:24 PM   #4996
Originally Posted by wallstreet View Post
And any tips for breaking in a motor so its fast ?
Is there a number to shoot for if i am running the motor on my gfx at 2 vlts
2 amps? 3 amps?
I remember reading that TCS Nats teched the black can for more than 1.9 amp draw which they deemed illegal. I guess if you can get a sliver can to draw 3 amps and its spins free with good rpms than its good.
Sydewynder is offline   Reply With Quote
Old 09-19-2007, 12:36 PM   #4997
Steven Key's Avatar
Core Creations The Type As are 60mm diameter and the Super slicks are like 53-54mm.
Core, "thanks man"
So bascilly the Super Slicks are narrower than the "A".
Why would anyone want the narrower tires?
Steven Key is offline   Reply With Quote
Old 09-19-2007, 12:57 PM   #4998
Core Creations's Avatar
Trader Rating: 94 (100%+)
Send a message via AIM to Core Creations
No...the width is the same....it's the overall diameter or the height thats different. The super slick is a smaller tire..so it has a much smaller overall rollout on a mini...not very desirable with a silver can.
Originally Posted by Steven Key View Post
Core, "thanks man"
Core Creations paint thread
Mini Mafia Kansas Chapter - where the monster minis grow!
Core Creations is offline   Reply With Quote
Old 09-19-2007, 01:24 PM   #4999
Steven Key's Avatar
Got it, that's why the super slick are available.
Thanks,
Old 09-19-2007, 02:06 PM   #5000
tony gray's Avatar
The compound is also different.
Super Slicks are much more durable and suited to warm to hot weather. Type A's dont like the heat so much at all...
tony gray is online now   Reply With Quote
Old 09-19-2007, 02:31 PM   #5001
Rock'sTC3's Avatar
Send a message via AIM to Rock'sTC3 Send a message via Yahoo to Rock'sTC3
where can you buy these hop up shocks/dampers and which are the best?
I believe TRF dampers work and are the better ones??
Rock'sTC3 is offline   Reply With Quote
Old 09-19-2007, 03:20 PM   #5002
SirSwiftAlot's Avatar
Location: SOCAL the fastest mini cooper guys in the nation
Originally Posted by maxepower View Post
Ed,
I too am running mini for the first time and my first build. Recieving a lot of help from lots of friends with mini. Without them I'd be lost. Here in Aliso Viejo,Ca. we are running the teflon spacer that come in the shocks on the bottom. I never throw mine away but I was told to run 3 on those spacers under the piston this is using the plastic shocks. Run 60 wt in the front and 35wt. in the rear. Short yellow in the front and short neon yellow in the back. I don't know if this set-up will work with yours but if you find one that works post it on you website! More info later!
Gotta go!
Max,
Try this set up on your mini I run this at socal and with a few minor adjustments from time to time my car is dialed.
Two hole pistons front and back
Three o rings inside the shock
80 front with white springs
40 rear with blue springs (sometimes red depending on track condition)
Silver sway bar up front
Black in the rear and some times I dont run one depending on track condition
Little bit of toe out for the front
Stock uprights in the rear
HPI X pattern belted with green HPI inserts all the way around (you have to cut them to size naturally)
Sometimes I will run a red insert up front depending again on track conditions
Pretty basic I hope this will help everyone seems to run a different set up but usually it ends up to be stiff/hard up front soft/medium in the rear. It just all depends on your driving style.
PM me if you have any other questions or need parts. By the way are running mid or short chassis.
Thanks,
Brandon,
Like a wise man once said "Only thy neighbors wife must be courted by her husband not you"
SirSwiftAlot is offline   Reply With Quote
Old 09-19-2007, 04:08 PM   #5003
Burlap's Avatar
Send a message via MSN to Burlap
Most hobby stores should have the shocks, or large online sites like Stormrhobbies, Speedtech or Tower Hobbies.
I have been using the plastic CVA shocks and been happy with them. My car performs as well or even better than my co racers who use the TRF shocks. However I have noticed that they need reoiling more often than the TRF shocks on my touring car.
Burlap is offline   Reply With Quote
Old 09-19-2007, 05:40 PM   #5004
tamiyarcracer's Avatar
Send a message via Yahoo to tamiyarcracer
Let me add to this!
The 60d is a belted tire, like what we run in the touring cars. The Super Slick is not and will / can balloon up
The 60d is the stickiest tire that Tamiya sells
tamiyarcracer is offline   Reply With Quote
Old 09-19-2007, 05:42 PM   #5005
Originally Posted by SirSwiftAlot View Post
Max,
Thanks,
Brandon,
Oh that's right hmmmm where did you finish at the Nats again???
Old 09-19-2007, 06:05 PM   #5006
Customworksking's Avatar
Trader Rating: 73 (100%+)
Can someone tell me what the difference is between these Mini tires
53222 - Super Slick 63 tires
53340 - Type A Slicks
u tell me u don't know this.....come on Steve all mini racers know....lol c u soon
Customworksking is offline   Reply With Quote
Old 09-19-2007, 06:39 PM   #5007
wallstreet's Avatar
Trader Rating: 20 (92%+)
Send a message via AIM to wallstreet
Kevin Bottoms....
will you be up for the mini mayhem race ?
I need to rack your brain on some things.
wallstreet is offline   Reply With Quote
Old 09-19-2007, 07:40 PM   #5008
I plan to ....going to iic as well
Old 09-19-2007, 08:20 PM   #5009
wallstreet's Avatar
good luck at the iic... every year something has prevented me from being able to make it.. Maybe ill get the chance next year
Old 09-19-2007, 08:27 PM   #5010
maxepower's Avatar
Originally Posted by tamiyarcracer View Post
Let me add to this!
Troy, YGPM!
maxepower is offline   Reply With Quote
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 04:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-01-2011 11:08 PM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 08:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 06:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 07:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
Currently Active Users Viewing This Thread: 9 (0 members and 9 guests)
