Like Tree61Likes
Old 09-16-2007, 01:32 PM   #4981
wallstreet's Avatar
Trader Rating: 20 (92%+)
Send a message via AIM to wallstreet
Does anyone sell a screw set for the mo3r that uses allen wrenches instead of philips head screws..
wallstreet is offline   Reply With Quote
Old 09-16-2007, 01:47 PM   #4982
tony gray's Avatar
You can use hex screws in a Mini (I've seen it done) but all the screws in the car are self-tapping and its not easy to find hex screws like that.
Not sure why you'd want to anyway? It's not like you pull the thing apart all that often?
tony gray is offline   Reply With Quote
Old 09-16-2007, 01:49 PM   #4983
wallstreet's Avatar
well, besided the fact my personal motor is dog slow.... a few screws kept comming loose
Old 09-16-2007, 08:14 PM   #4984
wallstreet- try some loctite blue.
kenchan is offline   Reply With Quote
Old 09-16-2007, 08:16 PM   #4985
wallstreet's Avatar
And any tips for breaking in a motor so its fast ?
Is there a number to shoot for if i am running the motor on my gfx at 2 vlts
2 amps? 3 amps?
Old 09-16-2007, 08:17 PM   #4986
Turbonium's Avatar
Trader Rating: 27 (100%+)
Send a message via Yahoo to Turbonium
i always build my minis with regular metric 3mm screws, and toss the self tappers. seems to hold better, and strips out less. you can use ally ones after prethreading with a steel one, for appearance and wieght... lol! as if the weight is really an issue... mostly for looks.
Wes
Team Novak
Turbonium is offline   Reply With Quote
Old 09-17-2007, 03:17 AM   #4987
H I
H I's Avatar
Trader Rating: 18 (100%+)
I use Champ made screws. 3x10mm hex head Ti screw - Parts No. TBT-1310 you need 3 packs of them to build one M03R (come in packet of 15) and 3x15mm hex head Ti screw Parts No. TBT-0315 (pack of 4 for body mount)
H I is offline   Reply With Quote
Old 09-17-2007, 04:02 AM   #4988
Default Spring setup
Hi TryHard,
Blue rear, yellow front is good. Yes front is heavier, but you want to prevent weight from transferring to the rear during acceleration. Softer front will give more grip during acceleration and turning.
Anyways, try many things to find the right setup for your driving style. But a pro did tell me his mini setup... blue rear, yellow front as a starting point. Also try 30wt, 3 holes, without the red thing in the bladder of the shocks.
Have fun.
Joel
P.S. Gear diff with anti wear grease. No need for ball diff.
rccartips is offline   Reply With Quote
Old 09-17-2007, 05:19 AM   #4989
TryHard's Avatar
Originally Posted by rccartips View Post
Hi TryHard,
Have fun.
Joel
Cheers.
Currently have the car setup with Yellow Front, Blue rear, and 50wt 2 hole in the front, 40wt 2hole in the rear. Feels pretty good so far, on a little try out last night. Going to have a run again tonight on a slightly larger/higher speed area, and have a little play.
And I've still got a gear diff in the front with the AW greese, feels nice and tight
TryHard is online now   Reply With Quote
Old 09-17-2007, 09:07 AM   #4990
All of the screws can be replaced with machine screws. I used buttonhead screws, mainly 3x10's and 3x 14's and 16's. the chassis screws should be tapped. the suspension ones don't need to be. Use a 4x6 flanged tube over the screws on the camber links (part#50593). You will need 2 bags. I'm with you on those philips head screws. You can buy all kinds of hardware at Mcmaster.com. They are a large industrial supplier that will sell to the public. It is amazing what they stock that we in R/c have been paying thru the nose for
Granpa is offline   Reply With Quote
Old 09-18-2007, 12:25 PM   #4991
TryHard's Avatar
well had a little play around with my mini again tonight... though not before rebuilding the shocks!
Now I'm using 35wt all round, with 2 hole pistons, and instead of the hard plastic spacer, I'm using 2 white o-rings, either side of a 1mm alloy shim (this following on from the build tips on the Tamiya USA site). As I'm using the short CVA's (the see through blue ones that come with the M03-R), means I can get the shock length happily to 57mm (the build tips advise 56.5). Also still using yellow f, blue R, in terms of springs and no foam above the blader.
The surface I'm mainly running on is very dusty, and I've found I'm too violent with the throttle let off and turn in, the rear will break loose... however on a grippier surface the balance felt pretty good So I'll leave it like that for now
I think heavier front oil might help a bit maybe up too 50wt again
I'm hopefully gonna give the car a run on some rug this weekend... got some roll bars if required (although they are off the car at the moment).
And the car is certainly nippy enough with the Monster Stock in... if anything it feels slightly overgeared with the 20t pinion on the tight area I'm running on, but hey.. who cares, 'tis quick
Still learning how to drive a FWD too... can't just mash the throttle like on the TC, smooth, keeping the corner speed up, seems to be the way forward
Laters
Ed
Old 09-18-2007, 01:04 PM   #4992
maxepower's Avatar
Talking mini newbie!
Ed,
I too am running mini for the first time and my first build. Recieving a lot of help from lots of friends with mini. Without them I'd be lost. Here in Aliso Viejo,Ca. we are running the teflon spacer that come in the shocks on the bottom. I never throw mine away but I was told to run 3 on those spacers under the piston this is using the plastic shocks. Run 60 wt in the front and 35wt. in the rear. Short yellow in the front and short neon yellow in the back. I don't know if this set-up will work with yours but if you find one that works post it on you website! More info later!
Gotta go!
maxepower is offline   Reply With Quote
Old 09-18-2007, 08:21 PM   #4993
maxepower's Avatar
Unhappy M-03 gears!
Looking for M-03 gears?
I'm in So.Cal.
Would like it for this weekend!
Anybody,Anybody!
Old 09-19-2007, 12:07 PM   #4994
Steven Key's Avatar
Can someone tell me what the difference is between these Mini tires
53222 - Super Slick 63 tires
53340 - Type A Slicks
Steven Key is offline   Reply With Quote
Old 09-19-2007, 12:24 PM   #4995
Core Creations's Avatar
Trader Rating: 93 (100%+)
Send a message via AIM to Core Creations
The Type As are 60mm diameter and the Super slicks are like 53-54mm.
Core Creations paint thread
Mini Mafia Kansas Chapter - where the monster minis grow!
Core Creations is offline   Reply With Quote
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 04:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-01-2011 11:08 PM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 08:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 06:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 07:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
Currently Active Users Viewing This Thread: 6 (0 members and 6 guests)
