Like Tree163Likes
Old 09-06-2007, 05:51 AM   #4936
tamiyarcracer's Avatar
Send a message via Yahoo to tamiyarcracer
Originally Posted by zipper View Post
Dose anyone have a 27Mhz FM receiver that would like to sell?
Glenn
what brand?
tamiyarcracer is offline   Reply With Quote
Old 09-06-2007, 09:53 AM   #4937
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
Anyone have any experience with mini coopers on rubber sedan tires . . .asphalt or carpet . . . Our local track allows all the mini varieties to run together as an open calss, and theres a couple brushless lipo recoils I'd love to be able to beat.
Old 09-06-2007, 01:09 PM   #4938
Sorry Andrew a well setup brushless lipo Recoil is going to be hard to beat with a front wheel drive mini cooper. Running cut down foams on carpet might be as close as you will get.
Sydewynder is offline   Reply With Quote
Old 09-06-2007, 01:14 PM   #4939
straightspeed's Avatar
Every week I race a Mini and a Recoil - different class's - and there's no way a Mini will keep up with my Recoil running a standard Sportwerks XLR8 motor, with 1400 cells, let alone brushless and Lipo. Once you start putting hot motors and high voltage cells through a Mini, terminal understeer and a complete lack of traction restricts the Mini. I'd love it to happen, running my Mini gives me the greatest pleasure, but I cant see it.
LEIGHTON BUZZARD MODEL CAR CLUB
straightspeed is offline   Reply With Quote
Old 09-06-2007, 01:46 PM   #4940
I didn't say teh recoil drivers were any good. Were actually pretty close in terms of lap times at the end of the race, its just that they have VERY inconsistant lap times. Im just looking for that edge to take my mini a few tenths faster per lap. Right now I have my mini really dialed within TCS rules, I'm just looking for some non-tcs legal changes that will get me more traction. I tried the sedan rubber tires and they were dialed on asphalt, so I thought I'd ask about anyone elses experience.
I have already upped the ante with a lipo, and I tried the cut down foams, but ti was too much traction, and with them cut down the roll out is less thatn the tamiya 60d tires (roughly 62 mm). Just looking for more : )
Old 09-06-2007, 03:54 PM   #4941
Originally Posted by tamiyarcracer View Post
what brand?
The TX is JR, but I think any brand should work.
Glenn
zipper is offline   Reply With Quote
Old 09-06-2007, 06:33 PM   #4942
rccardr's Avatar
Black can...
I've never lost.
I've just been a little bit behind when time ran out...
RED DOT MOTORS- Fastest Titan 12T and silver can 540 motors in the known galaxy!
rccardr is offline   Reply With Quote
Old 09-06-2007, 08:47 PM   #4943
sportsracer-5's Avatar
Originally Posted by rccardr View Post
Black can...
I second that. The black can motor makes my Mini even more crazy fun to drive. You won't beat the Recoils, but you'll have even more fun driving your Mini.
sportsracer-5 is offline   Reply With Quote
Old 09-06-2007, 08:52 PM   #4944
Originally Posted by tony gray View Post
Finally, it's here..
The TECH RACING DD-M Mini. Looks like a mini, but sure doesn't go like a Mini. Click here to read our full review on what might be the hottest Mini to hit the tracks for years.
Thanks for the review! I just have a couple of points on it. 1st off t-plate and floating rear suspensions on pan cars are completely different things. T-plate suspensions do not float, they flex. Floating rear suspensions are what you see on the old PB Sizzler and Lynx pan cars. The other is the rear diff...I find it unlikely they opted for no diff to increase traction. More likely they did it because it is a real pain to have a pan car style diff while using hex adapter style rims.
Old 09-07-2007, 06:10 AM   #4945
ChadRacing's Avatar
any video yet on the tech racing DD-M?
ReVtech / Trinity / EAMotorsports
HotShot RC / Nexus Racing
Xray T2 '009 w/Exotek Chassis, BMI DB12rr, Tamiya F104X1
Team Durango DEX210
ChadRacing is offline   Reply With Quote
Old 09-07-2007, 07:15 PM   #4946
tony gray's Avatar
Ask and you shall receive..
Just took me a little while to get around to editing it. Check it out on youtube here.
tony gray is offline   Reply With Quote
Old 09-08-2007, 08:16 AM   #4947
Tony what tires do you run on the DDM?
Old 09-08-2007, 01:29 PM   #4948
tony gray's Avatar
Still experimenting at the moment. First up were Pit 20/36, then RP 24/30. Yesterday the car was generating so much lateral grip that the tyres were literally getting ripped off the rims.
So I'm considering going to the same compound all round (normally a no-no on what is essentially a 12th scale) to see if that balances it a little better.
But that's all part of the fun with a new car...
Old 09-08-2007, 02:22 PM   #4949
GeekSpeed's Avatar
Hi everyone. I have just finished my second race with the M04L. Its a great little car, but it does have a few handling issues. I was hoping to get a little help with the setup. I run on a relatively high-grip indoor asphalt track (SoCal Raceway). Does anyone have some suggestions for a base-line setup? Right now the car is box stock except for ball bearings.
I was looking for parts and saw the 3Racing shocks on RCMart. I also see that they have shocks from Yeah Racing. Are either of these sets any good? What about tires? I have tried using S Grips on all 4 wheels as well as M on the front and S on the rear. Would slicks be a better option? I believe the touring cars at SoCal all run Sorex 36R. Is there a mini equivalent?
I am thinking that a ball diff might be in order as well. It seems to me that the more I reduce wheelspin, the less throttle-on oversteer I will get. Seem logical?
Anyway, any advice would be most appreciated. Thanks all!
GeekSpeed is offline   Reply With Quote
Old 09-08-2007, 02:28 PM   #4950
cartix's Avatar
Trader Rating: 33 (100%+)
Tony, what are the lap times compared to a M03?
cartix is offline   Reply With Quote
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 04:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-01-2011 11:08 PM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 08:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 06:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 07:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
Currently Active Users Viewing This Thread: 5 (0 members and 5 guests)
