Tamiya mini cooper
#4651
What differences are there in set up betwen the SWB and MWB cars on carpet at your track?
Civic and Miata are the right (225) wheelbase but don't fit.
Like on a lot of other things the body hits the servo mounts on an M03.
You can put the body on but it has to sit real high at the front and it looks crap...
The only 225mm alternative that I know of is the Audi TT from Proline. Only problem being that its been out of production for about 3 years...
The HPI Mini and/or VW Concept are both 210mm, they wont fit.
Solution? Pull out the spacer and run 210mm!
#4653
#4654
IS THERE A FIX AXLE FRONT DRIVE FOR MINIS??? PIC PLEASE.THX
#4656
i think im going to build the Alfa next...
#4659
Hi fellow mini drivers.
My name is Will. I am with Over Geared Racing. We are holding a Summer R/C Smack Down in Vancouver BC. Two day event. August 18-19 th.
1st day qualifying and 2nd day mains. The track is about 150 ft long by 60 ft deep.
http://www.overgearedracing.com/Gall...ackdown-p1.jpg
Any one in the pacific northwest area (Washington, Port Land, Vancouver BC (Canada)) would like to run in 27T Mini. It is pretty much a open class. Open tires and Batteries. Except it has to be a M-Chassis.
If so please let me know or PM me.
Will
Over Geared Racing
Will
Over Geared Racing
#4660
Here is a link to a chart of bodies for the mini, and what fits what.
Thanks to rc-mini.net
http://www.rc-mini.net/MiniWeb_Onlin...D7756B281E1090
#4663
cockpit update..
Here is the interior installed in a mini.
Now, my next project is to make a left-handed driver and maybe a single driver.
#4664
What’s up gang? I just got my M04L Beetle delivered on Monday and I have been working on it for the last couple of nights. Thus far, I have completed the front and rear suspensions and the gearbox. I have a couple of questions, however:
1. The left rear suspension seems to be binding. I am not sure why this is happening. I made sure that everything was not too tight and it does not look like I have any flashing or anything gumming up the works. Any suggestions as to what might be causing this?
2. I’m running the friction shocks for now and will probably do a few races with them. Does anyone have any advice on how to set them up to be as good as possible? I will be running on an indoor asphalt track with good grip.
3. Will a standard Futaba S3003 steering servo fit? What about a standard sized Futaba receiver (I need to buy these still, so I can’t test fit)?
Also, does anyone have suggestions for tires? I am hoping to keep it TCS legal.
Thanks!
Thanks!
